Can you put a 2001 2wd Body on a 2001 4wd Frame??
Discussion in '1st Gen. Tacomas (1995-2004)' started by Deere9798, Feb 26, 2016.
  1. Feb 26, 2016 at 5:50 PM
    Deere9798
    Deere9798 [OP] Well-Known Member
    Charles
    Western NY
    2001 Tacoma 4x4
    Hi, I am wondering if the entire body is interchangeable between the 2X4 and 4X4 trucks? And if not, what do you have to modify to get them to fit.
    Thanks,
    Charlie
  2. Feb 27, 2016 at 4:11 AM
    Deere9798
    Charles
    Western NY
    2001 Tacoma 4x4
  3. Feb 27, 2016 at 4:36 AM
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    I can't see why it wouldn't fit, the hole in the floor for the shifter is prolly the same too,
  4. Feb 27, 2016 at 9:33 AM
    Deere9798
    Charles
    Western NY
    2001 Tacoma 4x4
    That's what I thought. I would love to know if anyone else has done this. Thanks.
  5. Feb 28, 2016 at 5:42 PM
    Toyotafan1234
    Toyotafan1234 Member
    Cam
    I have a buddy who rolled his 4x4 ranger and put a 2wd ranger cab on it. I would think you would be able to do the same with a tacoma.
    Deere9798[OP] likes this.
  6. Feb 28, 2016 at 5:45 PM
    markmb45
    markmb45 Well-Known Member
    Mark
    Utah
    99 4x4 Reg Cab 3.4, auto, e-locker
    V6,Auto, e-locker 4runner dash, seats
    Yes they are interchangeable. Cut the hole for the shifter, the front fenders are different 2wd vs. 4wd (they'll work, but stock flairs won't fit) then your good to go.
  7. Feb 28, 2016 at 5:47 PM
    pofarm
    pofarm Well-Known Member
    Greg
    SW MO
    1996 Taco
    I know the earlier Tacoma front end was different between 2wd & 4wd. Don't know if the body mounts are the same. Not sure about your 01.
  8. Feb 28, 2016 at 7:18 PM
    Deere9798
    Charles
    Western NY
    2001 Tacoma 4x4
    Do you know if the body mounts will line up. Thanks again for you help.
  9. Feb 28, 2016 at 7:24 PM
    markmb45
    Mark
    Utah
    Yep the bodies are the same. Everything will line up fine. My buddy has a body shop we've use 2wd cabs on 4wd's several times.
  10. Feb 28, 2016 at 7:25 PM
    Deere9798
    Charles
    Western NY
    2001 Tacoma 4x4
    Sweet. Thanks for everything. I really appreciate it.
    _Charlie
  11. Feb 28, 2016 at 7:25 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    @Blackdawg swapped from a 4x4 to a 4x2 body, IIRC there were a couple of little things but it was close.
  12. Feb 28, 2016 at 7:26 PM
    Deere9798
    Charles
    Western NY
    2001 Tacoma 4x4
    Thanks, do you know if he has a write-up or build thread?
    _Charlie
  13. Feb 28, 2016 at 7:28 PM
    95 taco
    95 taco Battle Born
  14. Feb 28, 2016 at 8:38 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Body mounts will be the same. Every pretty much lines up. It'll be even easier if you are swapping two bodies with the same tranny. I put an auto tranny 4banger 2wd onto a manual v6 frame. Some things are different. But not drastically. Everything that was just needed drilled out. The tranny tunnel will need a bit modified too for the tcase shifter.
    As stated the fenders are an issue too. The 2wd ones are flat with no flair. Stock 4x4 ones have about a 1.5"-2" flair. But they will work.
