Can you put your transfer case in low gear without 4wd?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Flash333, Jun 29, 2011.
  1. Jun 29, 2011 at 10:39 PM
    Flash333
    Flash333 [OP] Member
    03 TRD SR5 Silver
    eh !! I would like to know if there is anyone out there that managed to mod his transfer case to be able to go into ''LOW'' without the 4WD, just to stay in 2WD but with low gear ratio:eek:???
  2. Jun 29, 2011 at 10:48 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  3. Jun 29, 2011 at 10:58 PM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Why would you want to?
  4. Jun 29, 2011 at 10:58 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    just take out the 4wd fuse in first gens
  5. Jun 29, 2011 at 11:17 PM
    Littlebro 5
    Littlebro 5 Well-Known Member
    Tyler
    Wilsonville or
    01 4x4 3.4L sr5 manual all-pro lift
    6" deck plate mod, sweet bed bar.
    i love 2 low.
  6. Jun 30, 2011 at 1:16 AM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    1st gens mod for this simple, think its called ''blue plug mod" think all u need to do is unplug a plug on the t case.
  7. Jun 30, 2011 at 1:22 AM
    DIRT YOTA
    Cory
    Camarillo, CA
  8. Jun 30, 2011 at 7:38 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    If you have push button 4wd you can do the mod above but if you have a j-shifter transfer case you have to go with a twin stick. I plan on putting twin sticks in mine soon.
  9. Jun 30, 2011 at 8:28 AM
    pittim
    pittim mittip backwards
    Pink slider.
    Because 1) Traffic sucks with a manual trans 2) Why use 4wd on the trails when you dont have to?
    NWToys is the old WATTORA, they split off for whatever reason. The writeup I used for 2Lo was on WATTORA, but that was like 2 years ago.
  10. Jun 30, 2011 at 8:45 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    i just keep my hubs unlocked :notsure:
  11. Jun 30, 2011 at 8:48 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
  12. Jun 30, 2011 at 8:50 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    so if you unplug the blue plug....you can have 2Hi, 4Hi, 4Lo, and now 2Lo?
    or do you lose 4Lo?
  13. Jun 30, 2011 at 8:52 AM
    JLee
    Jerry
    Bay Area NorCal
    You will not lose anything but you need to do the Grey Wire mod to have your locker
    I ran it 2Lo locked last weekend on some trails just to mess with it and it's a awesome mod and if you don't want it just plug it back in.
  14. Jun 30, 2011 at 8:57 AM
    pittim
    Pink slider.
    What the blue plug does is automatically engages the truck into 4wd when you put the case into Lo.
    So yes, essentially all you're doing is gaining 2Lo, not losing anything.
  15. Jun 30, 2011 at 9:01 AM
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    so what do you do if you have a j shifter?
  16. Jun 30, 2011 at 9:02 AM
    JLee
    Jerry
    Bay Area NorCal
  17. Jun 30, 2011 at 9:03 AM
    pittim
    Pink slider.
    twin sticks.
  18. Jun 30, 2011 at 9:05 AM
    JLee
    Jerry
    Bay Area NorCal
  19. Jun 30, 2011 at 9:09 AM
    pittim
    Pink slider.
    twin sticks are so much cooler tho
  20. Jun 30, 2011 at 9:12 AM
    JLee
    Jerry
    Bay Area NorCal
    Umm Yeah but way more money I'm going with duel cases in the future.
