Can you recommend Oil and Oil Filter for 2001 DC w/ 149k?
Discussion in 'Performance and Tuning' started by SlimDigg, Sep 18, 2010.
  1. Sep 18, 2010 at 5:59 PM
    SlimDigg
    SlimDigg [OP] Resident MMA Fanatic
    Calgary, AB
    2001 TRD Double Cab Limited 4x4
    OME 881, Bilstein 5100, Icon AAL, Wheelers Anti-Sway kit, aFe Pro Dry-S Air Filter, Deck Plate Mod, Rear Diff Breather Mod, GE Nighthawk Platinum headlights, Wet Okole Seat Covers, Husky Liners. LED Tail Lights
    Recently purchased an 01 DC with 149k miles and I'd like some Oil and Oil Filter suggestions please!
  2. Sep 18, 2010 at 6:00 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    has it ran syn? not that it matters......
  3. Sep 18, 2010 at 6:04 PM
    SlimDigg
    Calgary, AB
    No syn, I should have put, which syn oil do you recommend because i'll likely be going that route unless someone tells me it'll be bad in the long run.
  4. Sep 18, 2010 at 6:09 PM
    crf69
    Ohio
    ummm yeah
    amsoil......
  5. Sep 18, 2010 at 6:14 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    98 V6 4x4 limited
    Stereo, boobies
    I like Valvoline and the K&N Oil Filter.. since the filter has the 1" nut on the end it make it UBER easy to take on and off..
  6. Sep 29, 2010 at 5:10 PM
    SlimDigg
    Calgary, AB
    I hear amsoil helps the engine run at a lower temperature...Can anyone verify?
  7. Sep 30, 2010 at 10:13 AM
    turttletoy
    turttletoy Well-Known Member
    Overland Park, KS
    '00 TRD 4x4
    i used to run valvoline max-life. it has additives that helps recondition seals and reduce sludge. i recently switched over to penzoil high mileage, which does the same thing.
  8. Sep 30, 2010 at 10:53 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    ^^that^^ I also like Purolator or Wix
    It made my 98 3RZ run smoother and quiter. I cannot verify the cooler part though. I also used Wix filters.
  9. Oct 12, 2010 at 12:32 PM
    00tactrouble
    00tactrouble Active Member
    South Texas
    2000 Toyota tac prerun
    New Dakota A/T tires in 31x10.50-15", 2 coat Rhino Liner on the the bed, Mossy Oak package interior, 8" bazooka system pumping my jams, Platinum system plugs underneath the hood with Gates belts keeping it turning, 6" deckplate mod and amsoil is keeping this thing lubed year around.
    I am running Amsoil 10w30 on my yota (170,000) and ever since I first used Amsoil it runs cooler...less friction means cooler oil.
  10. Oct 12, 2010 at 8:03 PM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    I was a die hard Castrol GTX fan up until recently. Switched over to Pennzoil Platinum due to the rave reviews it gets on bitog and I'm now on the synthetic bandwagon.
    Longer OCI, great cleaning properties, better cold weather starts, and not expensive (~$20/5qt jug @ Wal-Mart).
    As far as the oil filter goes, I'm a big fan on the Toyota OEM. Other than those I'd pick Purolator PureONE or NAPA Gold.
