Can you reuse manifold gaskets?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bugzy08comer, Jan 18, 2021.
  1. Jan 18, 2021 at 1:09 PM
    bugzy08comer
    bugzy08comer [OP] Member
    08 Toyota Tacoma
    Can you reuse exhaust manifold gaskets?
  2. Jan 18, 2021 at 1:12 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    Exhaust... maybe, depending on miles and how crushed they are
    Intake, i wouldn't
    joeyv141 likes this.
  3. Jan 18, 2021 at 1:15 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    You can try if the only other recourse might be a 50 mile walk .
    I would not count on it
    tinker_troy likes this.
  4. Jan 18, 2021 at 1:16 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Can you? Yes. Should you? No, probably not.
    TomTwo, Dm93 and super_white like this.
  5. Jan 18, 2021 at 1:41 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    NO
  6. Jan 18, 2021 at 2:43 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    I reused mine that had 50k on them when I put headers on. Never had a leak with 105k it had on it. No longer own the truck.
  7. Jan 18, 2021 at 3:10 PM
    americanstig
    americanstig Active Member
    mike
    2011 tacoma acces cab
    stock
    I wouldn't
  8. Jan 18, 2021 at 3:25 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I would not.
  9. Jan 18, 2021 at 4:40 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    People have don’t it.
    I wouldn’t and you shouldn’t.
    I don’t like removing exhaust bolts, nuts, or studs any more than I have to.
    I’d hate to have the old ones leak, then break of a bolt while replacing the gaskets later.
    I guess the question is, what is your time worth?
    Wyoming09, Jimmyh, Dm93 and 1 other person like this.
  10. Jan 18, 2021 at 8:29 PM
    TacoTuesday1
    FL
    idk what they're made out of but some sealing car parts can be re-expanded by heating with a torch
  11. Jan 18, 2021 at 8:31 PM
    rtilton12
    rtilton12 Get gas and GO!
    Robert
    Texas
    2012 Toyota Tacoma TRD Off Road 4x4
    Trail gear front and rear bumper, RTT, hitch grill, 12k lb winch, drilled and slotted front brakes
    You’re talking about a few dollars to do the right thing. Treat the taco right and go the smart route
  12. Jan 18, 2021 at 8:51 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I wouldn't. I hate doing crap twice.
    Hate it!
    Dm93 and TnShooter like this.
  13. Jan 19, 2021 at 3:50 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    The best Answer is Maybe !
    It is your truck go for it you might get lucky.I would most likely break something then the extra cost of the gaskets would have ended up being cheap
    We all do what we need at times If I had to a small thin layer of Permtex # 2 on both sides
  14. Jul 31, 2023 at 6:10 PM
    TacoTuesday1
    FL
    Anyone else re-used their exhaust gaskets regarding catback, y-pipe
    mine are young, likely under 1yo
    if I ever have to re-use exhaust gaskets on another car
    though they're typically the flat sheet metal kind
    re-expanding them with a torch, installing with lubricant/grease, carefully torquing in pattern, has always worked
    Ideally I'd put all new hardware too but shit's like $40+ for a bag of bolts.
    IDK how Toyota is (FSM) for replacing. I know German cars it's mandatory required by manufacturer, to at least replace exhaust nuts.
    Mine aren't rusted to shit FWIW
    simpler to try refresh and re-use. Easy to find leaks. Get new IF they leak.
    Than to hunt down PN's, shop around, order, wait for mail, etc.
    I sure hope Yota dealer computer per VIN says what GRN package the truck is, or door sticker, to clarify which pic or what the GRN's even mean...
    I've even re-used oil drain plug washers in a pinch, it's not hard.
    You just put them on concrete, heat with torch enough to expand but not melt them, let cool, and install. You can see it expand.
    Practice on a spare one to see how long it takes to melt into a puddle of liquid, so you learn the feel of what heat time it takes/color.
    Or if you need, rub soap on it; if the soap turns black it's expanded
  15. Jul 31, 2023 at 6:14 PM
    Bishop84
    Bishop84 Well-Known Member
    I re-use exhaust gaskets all the time, especially when they are under warranty and backordered.
    Especially under 3 years old there's very little risk of an exhaust leak.
    Is it ideal? No. But why blow a ton of money for the same result.
  16. Jul 31, 2023 at 7:04 PM
    TacoTuesday1
    FL
    exactly. I just didn’t know how different if at all the Toyota ones are. I’m used to working with other brand gaskets that are not this type of aerated foamy mesh material. But at the end of the day heat expands so anything squished by bolting together can typically get re expanded again with heat on the ground.
    To replace everything even though it looks good, adds up costing extra as does the drive.
    often times manufacturers list parts as must replace simply for their warranty administrator to dig through your record of old parts turned in to find one nut missing, then try to deny paying for the entire 40 hour repair you did successfully (aka theft)
