Can you run front mudflaps with 255/85/16 or 255/80/17 ?
Discussion in 'Wheels & Tires' started by OZ-T, Jul 21, 2011.
  1. Jan 16, 2012 at 12:30 PM
    #81
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
  2. Jan 16, 2012 at 12:32 PM
    #82
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    Did you have to remove the flaps ?
  3. Jan 16, 2012 at 12:41 PM
    #83
    4Wheelin4Banger
    Randy
    Not yet. I haven't tried them at full stuff yet. If I have to I'll trim the bump.
  4. Jan 16, 2012 at 12:43 PM
    #84
    OZ-T
    Peter North
    British Columbia
    Cool
    Post up your results after you flex it a bit
  5. Jan 17, 2012 at 12:13 AM
    #85
    commando
    commando Well-Known Member
    Brandon
    Oregon
    2006 SR5 Double Cab 4X4
    3" spacer lift
    Subscribed.
    I really want a set of these for my 2006 DC, and my 285's are shot so it might be happening soon.
    Do these work any better on an aftermarket wheel with a bit less BS?
    I have stock 16" alloy's now...
  6. Jan 17, 2012 at 12:20 AM
    #86
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    they work great on stock wheels. Ninorth is running them. no issues and no rubbing.
  7. Jan 17, 2012 at 1:08 AM
    #87
    4Wheelin4Banger
    Randy
    I stuffed them as far as I could with a bottle jack under the LCA and it looks like it wont be a problem. At full lock.
    Mine are on the stock TRD 16" alloys and look like they stick out farther than the stock steelies did. Less BS would make them stick out farther, and you probably don't want to go wider than a 7" wheel. Maybe it's the straighter sidewall, but I think the tread on my 245/75/16s were centered on the mud flap and the 255/85/16s are at the outer edge.
  8. Jan 17, 2012 at 1:25 AM
    #88
    Yoytoda
    Roland
    completely stock
    i also notice your running 1st gen trd wheels. maybe the backspacing is different?
  9. Jan 17, 2012 at 1:34 AM
    #89
    4Wheelin4Banger
    Randy
    $100 for a set of TRD alloys I couldn't pass up the deal. I didn't know they they were 1st gen, just that they weren't the current ones. I'll measure the BS on the alloys and the steelies when I swap back to my commuting tires later today (280 mile/week).
  10. Jan 17, 2012 at 2:02 AM
    #90
    commando
    Brandon
    Oregon
    3" spacer lift
    That will free up some funds for some other stuff for sure, (I'm thinking...... new gears!) "EXCELLENT!"
  11. Jan 18, 2012 at 12:23 AM
    #91
    4Wheelin4Banger
    Randy
    Well I had to get them a little dirty today. I went up on the hill north of my house before taking it to the stealership for it's free oil change.
    Well I measured them when I did the swap out.
    1st Gen TRDs 4.5" BS
    Stock Steelies 5" BS
    2nd Gen TRDs 5.5" BS (according to the wheel specs thread)
  12. May 8, 2012 at 5:10 PM
    #92
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    So general consensus is these tires do not fit with stock suspension, even with trimming in the wheel wells. Correct?
  13. May 8, 2012 at 5:11 PM
    #93
    OZ-T
    Peter North
    British Columbia
    Correct
  14. Apr 18, 2013 at 6:32 AM
    #94
    Dibblit
    Dibblit Eh?
    Paul
    Fort McMurray
    11 Tacoma
    OME suspension ARB OBA ARB locker
    Had to loose the front mud flaps due to rubbing issues after installing Icon extended travel suspension and UCA. Had my caster set to 3.25* and trimmed a lot. During full compression of the shock the tires will rub on the fender liner, and if you caster is at 4* or more they will hook your front bumper (if you are running a stocker) and try to remove it for you. All my previous posts in this thread were based on a ready lift leveling kit with stock UCA's and caster set at 2.75*.
  15. Apr 18, 2013 at 7:01 AM
    #95
    nelztaco
    nelztaco Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    It's Alive!
  16. Apr 18, 2013 at 7:04 AM
    #96
    Bogg
    Bogg Well-Known Member
    Surrey, Canada
    07 TRD Sport 4x4
    I'm running 255s on stock sport rims and 1.25" wheel spacers to clear my UCAs. Stuffed no problems on driver side. Passenger side I rub my flares. Think it's due to my alignment tho. I'm running mud flaps by renotacoma (flexible kind) and tore off passenger side. I was going to regear to 4.56s but after talking with several members my highway mileage is going to suffer with them so still running stock gears for now.
  17. Apr 18, 2013 at 8:24 AM
    #97
    OZ-T
    Peter North
    British Columbia
    Wut
    You don't need spacers to clear the UCA's with 255 / Stock Sport Alloys
    :notsure:
  18. Apr 18, 2013 at 3:07 PM
    #98
    OZ-T
    Peter North
    British Columbia
    He is running 255's on stock Sport wheels , much like I'm running 275's on stock Sport wheels
  19. Apr 18, 2013 at 3:20 PM
    #99
    OZ-T
    Peter North
    British Columbia
    For sure the spacers are causing the rub
  20. Apr 18, 2013 at 4:34 PM
    #100
    Bogg
    Surrey, Canada
    07 TRD Sport 4x4
    Spacers to clear my total chaos UCAs
