Can you switch factory stereos ??
Discussion in 'Audio & Video' started by budisit, Jan 13, 2008.
  1. Jan 13, 2008 at 6:04 PM
    budisit
    budisit [OP] Active Member
    Buddy
    white, long bed, TRD, dbl cab
    Can the dealership switch my 6 CD changer OEM stereo out and install the upgraded JBL ?
    I have an 08 double cab taco.
  2. Jan 13, 2008 at 7:35 PM
    bledsoe3
    bledsoe3 Well-Known Member
    Portland
    '15 DCLB Limited
    SnugTop, Air Lift bags, Bilstein 5100's up front, AAL in rear, 275/70/18 BFG AT TA KO2, URD TCAI, URD Cat Back
    If they can, I'll make you a deal on the one I took out. I have everything except the wiring harness.
  3. Jan 13, 2008 at 7:41 PM
    budisit
    Buddy
  4. Jan 14, 2008 at 6:13 PM
    budisit
    Buddy
    What's the general concensus ?
    Does the JBL upgraded stereo (new 2008 taco) sound better than the base and the 6-CD changer system ?
    I know some will say it does not sound much better. But that might be as compared to an after market super system. I'm not interested in that. I am only interested in OEM.
    I guess I could test drive a new taco with the JBL in it and decide for myself.
    But then the question will be.........can the stereo be changed out at the dealership ?
    If I find the answers to these questions myself.....I'll post to all.
    BUDDY
  5. Jan 14, 2008 at 6:55 PM
    bledsoe3
    Portland
    '15 DCLB Limited
    I'll try to get a picture to you tomorrow.
  6. Jan 14, 2008 at 7:19 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    if u do buy the JBL headunit, dont take it to the dealer. u can swap out the headunits in 10 minutes tops w/ just simple hand tools. i installed my aftermarket w/ a seperate brain that i had to run under the seat, reverse and speed sensor wires to hook up, and run a GPS antenna and it was done in under an hour. i'm sure like everything else that u take a truck to the dealer for, they'll rape u in costs.
  7. Jan 15, 2008 at 6:02 PM
    bledsoe3
    Portland
    '15 DCLB Limited
  8. Jan 15, 2008 at 9:09 PM
    Leer
    Leer Well-Known Member
    Lee
    Hilo HI
    2015 Tacoma 4x4
    Does anyone know if the '08 Tacomas with the standard single disk system come prewired for the JBL system?
  9. Oct 20, 2008 at 7:37 PM
    hurricane
    hurricane Member
    Whitehorse
    speedway blue
    wheels,stereo, step bars,roof rack.
    I just got a stock JBL premium stereo with the little amp and found out one of the factory wiring pins doesn't fit. The one on the JBL is a 20 pin and smaller than the one from my 07 Tacoma.
    Anyone had any luck finding an adaptor?
    I like the stock look and got a good deal off ebay for the stock JBL.
    Mine is a Canadian truck if that maters in the wiring?
    Thanks,
    Wayne
