Can you take out???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sschulz, Feb 6, 2008.
  1. Feb 6, 2008 at 12:12 PM
    sschulz
    sschulz [OP] Member
    Oahu, Hawaii
    07 4X4 TRD Sport LB
    Can you take out the front bed storage compartments without breaking the tabs?? If so how?
  2. Feb 6, 2008 at 2:24 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i think i lucked up on one side and got them out w/o breaking the tabs, but on the other side i busted the 2 top ones off and had to put a screw in to keep it in and secure.
  3. Feb 6, 2008 at 2:27 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I believe you push down and pull out the top. I've had mine out a couple times to run wires and I think that's what I did. They popped out fairly easily so if you are forcing it, stop.
    I think they sorta rotate from the top into the bed once you push down on the bottom.
  4. Feb 6, 2008 at 3:43 PM
    sawdust
    sawdust Unapologetic Texan
    Frisco, TX
    07 TRD Offroad Radiant Red V6 Auto DC
    Homelink mirror, tailgate lock, 2ndary air filter removal, Access LE tonneau, Bugflector II, hitch-based bed extender, vent visors, suspension TSB, stall mat
    I got mine out without breaking tabs the first time. Not so lucky the second, but it stays put, so I haven't done anything about it.
