Can you tolerate the 4 cylinder?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xSpyderguyx, Jun 14, 2010.
  1. Jun 18, 2010 at 12:24 AM
    #121
    AKTACO420
    AKTACO420 Well-Known Member
    RETODD
    Anchorage AK
    2009 tacoma
    bucket seats grille craft mesh grille and lights behind grille
    I live in Alaska and there's big mountians and I rarely half to shift down I just give it more gas
  2. Jun 18, 2010 at 4:23 PM
    #122
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Except on sandhills, bogs, or deep mud, when the tire spinning power of the 6 is necessary. Don't get me wrong, I liked my 4cyl more, but off road it gives up a lot to the V6, especially where I live. Crawling and trails are the only time I find the 4 cyl to be comparable capability-wise.
  3. Jun 18, 2010 at 8:19 PM
    #123
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    No,I can't tolerate any 4 cylinder.
  4. Jun 18, 2010 at 8:23 PM
    #124
    bigcoffinhunter
    bigcoffinhunter Well-Known Member
    The 2.7 does what I need it to do. More power is always welcome, but I love the 4cyl. Hell it has more displacement than some sixes. It's a solid engine for sure.
  5. Jun 18, 2010 at 9:11 PM
    #125
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Had a 4 Banger Corolla. Pops has a 4 Banger Mazda B2200.
    I have no problems with either. They get you where you need to go. But fully loaded having the V6 is nice. Especially with a truck, you load it up and we'll see who gets better mileage.
    And being able to move a little more quickly if necessary is really nice. This is most apparent on my 200km work commute when I have to pass slow ass vehicles on a one lane highway.
  6. Jun 18, 2010 at 10:22 PM
    #126
    trumanpriest
    trumanpriest Member
    Mark
    St. Louis
    My 2010 Tacoma Access is the 4th Toyota 4 cylinder I have owned. My weekend car is a 350hp AWD Celica Alltrac (2.0l 3S-GTE @ 17psi). I was not disappointed at all with the 2.7. Feels right on par if not a little quicker than my wifes 2009 Yaris. For a daily driver and general home project/car part hauling it does just fine. Addmittedly with max AC it does seem to get a bit sluggish, far from intolerable though. I would never consider using it to tow my alltrac somewhere though or for off road work. Nice comfy econo utility truck for daily driving IMO.
  7. Jun 18, 2010 at 10:36 PM
    #127
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    It has an A340E with minor updates through the years. The 4 cyl wakes up when the trans. works the way it should. So far the factory trans is in need of desperate renewal and Toyota needs to forget about its limp shifting automatics and get in favor of firm shifting long lasting transmissions.
    If any of you have an automatic and are good with taking things apart an building things up make yourself a shift kit and see how much better the automatic wakes up and improves your performance.
    Read through the link you will be surprised.
    http://www.customtacos.com/forum/showthread.php?t=97198&highlight=tranny
  8. Jun 18, 2010 at 11:24 PM
    #128
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    I love my 2.7. i do wish they made a 4l regular cab cause id buy it...
    the 2.7 does everything i want. Im in the process of moving up to big bear up in the mountains and its been hauling all my stuff just fine and its a crazy drive up to big bear.
    some mentioned weight in the begining of the thread but that has little effect. The AC v6 is only 100lbs heavier...
    Oh and the 4banger tacomas have a higher payload capacity rating than a v6 according to toyota
  9. Jun 19, 2010 at 4:23 AM
    #129
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    This past two weeks my 2.7 2WD access cab has continued to impress me even more. I took a load of concrete to the dump and had no issues at all. The load weighed 1700 pounds. I also picked up two loads of 20 60lb bags of moter mix with no issues.
    I like that I get 22mpg on my daily commute to and from work with the power to merge on to the freeways at 60mph.
    The 2.7L Tacoma is a nice package that has a lot of style and power at a reasonable cost.
  10. Jun 19, 2010 at 7:53 AM
    #130
    gologit
    gologit Well-Known Member
    In the redwoods.
    2023 SR5 4x4 long bed
    Nothing major or fancy. Just stuff to make it work better for me. Running boards, seat covers, BakFlip
    I have an 09 4x4 with the four banger. No complaints. Is it a neck-snapping 0 to 60 hot rod? No...and it's not meant to be.
    I use mine as a work rig, lots of rough logging roads, off road, and steep ground. It hauls all the stuff I need for a day's work and does it without breaking a sweat. I load the hell out of it and usually bring home a little firewood at the end of the day along with all the other stuff that accumulates in the bed.
    I used a have an F250 and the Taco 4 banger does the same job at about half the price for operating expenses. I'm not sorry I made the switch.
    I can't see where the additional cost of buying and running of the 6 would make things any better than they are now.
  11. Jun 19, 2010 at 7:56 AM
    #131
    dogbite
    dogbite Well-Known Member
    Utah
    '10 double cab TRD OR
    OME lift, Leer shell, Beefed sliders, Extra 12V outlets for rear bench
    I have the double cab and there is no way a 4 banger would do the job for that truck.
  12. Jul 15, 2010 at 11:39 PM
    #132
    oscar m
    oscar m Attitude of BONZAI!!!
    canyons
    my cinco lugger taco
  13. Jul 16, 2010 at 12:49 AM
    #133
    seligman
    seligman Well-Known Member
    If you missed the other thread I started, Toyota is making a Double Cab non-Prerunner truck beginning in 2011. Both this and some Double Cab Prerunners will have the 4 banger 2.7L engine.
    How will the 2.7L engine handle 5 adults and some cargo? Figure 1000-1100 pounds.
    Every double cab using the 2.7L engine shows 19/25 MPG, a big plus in my book.
    Any reason why I shouldn't jump on this?
  14. Jul 16, 2010 at 4:19 AM
    #134
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    I don't see why not. The only time that I have ever wanted more power was going up a mountain road in WV with ~1000 lbs of weight including 7 kayaks on the racks. Unless you are someone who does a lot of serious offroading (mudding, etc) or like to tear down the highway there really isn't a need for the larger engine.
    Basically just go take a test drive. If you have to bring some buddies to weigh it down. Actually definately do that so you can make them do the rear spring TSB while you are there.
  15. Jul 16, 2010 at 4:27 AM
    #135
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    I bought the 4 cylinder 2 wheel drive more out of financial reasons than anything else. I would love a new V6 4 wheeler.. That being said. The only thing I do not like about my truck is when you are in cruise control at highway speed and you go up an incline the engine really hammers down for a few seconds to maintain speed. Maybe it would do better without the AC on. What I do now if I remember is turn the cruise off and throttle it myself. Other than that the 4 cylinder has all the power I need.
  16. Jul 16, 2010 at 5:10 AM
    #136
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    I am in my 4th Toyota 4 cylinder.
    As a daily driver, using the bed to tote plywood, mulch and firewood on the weekends it does just fine. 159 horsepower is good and the truck is "quick".
    My '06 AT 2WD, which I just traded, would get 30 - 31 mpg in highway locked in at 60 mph. The automatic was rated higher mpg than the manual.
    I just purchased a '10 SR5 AC with AT .... we'll see what that gets.
    It depends on what you want.
  17. Jul 16, 2010 at 10:12 AM
    #137
    seligman
    ^ that's why i dislike cruise control. It's fine on flat roads, but in the mountains it's hard on the engine not to mention unsafe for driving. Same thing in the rain or snow.
  18. Jul 16, 2010 at 10:15 AM
    #138
    Cappy Cap
    Cappy Cap Well-Known Member
    Boston
    08 Reg. Cab
    K & N Intake, Alpine S-10 Shallow Mount Sub, Alpine CDA-9884 H/U, Alpine Type-R Components, Alpine Amp, 3.73 rear end, Welded on Muffler, Bug Deflector, Rain Guards, LCE Short Shifter,
    love my 4 cyl
  19. Jul 17, 2010 at 3:28 AM
    #139
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    is this confirmed? are there any pics or what? a 4000 lb truck with a 159 hp motor...lol!
  20. Jul 17, 2010 at 3:31 AM
    #140
    seligman
