Can you tow a car with a 4cyl regular cab?
Discussion in '4 Cylinder' started by 08BlackTacoma, Jul 18, 2008.
  1. Jul 18, 2008 at 11:55 AM
    08BlackTacoma
    08BlackTacoma [OP] Well-Known Member
    South Florida
    09' Double Cab V6 SR5, Long Bed, TRD Sport
    I have a 4cyl automatic regular cab, i use for work. I have a Dodge Viper i go to the track with a lot, and i would like to tow it there, the car is about 3,300lbs i know they say the tacoma can tow 3,500lbs. How much does a trailer weigh about? 800lbs? more or less? do you guys think this is possible?
    Thanks
  2. Jul 18, 2008 at 12:07 PM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    Just a little over the limit, but on flat ground at lower speeds it would prob do alright; but if you happen to get in an accident and the truck is over the published limit you might be in trouble, depending on the circumstances/severity, and the officer(s) that show up and there opinion/mood. I would make surer to use or add if not equipped trailer brakes (surge or electric), and go ahead and add an aux trans cooler to the 4spd automatic OD; if you decide to tow.
  3. Jul 18, 2008 at 12:29 PM
    Mingy
    Mingy Well-Known Member
    Milton, Ontario
    V6 uble Cab TRX/Towing
    Lear cap.
    Thats a lot of weight, so you'd have to drive very cautiously.
  4. Jul 18, 2008 at 12:32 PM
    08BlackTacoma
    South Florida
    How much different are the brakes on a V6 that can tow 6500? If anything i think a trailer with brakes would help a lot.
  5. Jul 18, 2008 at 12:39 PM
    Mingy
    Milton, Ontario
    Lear cap.
    Ok, it would be on the hills and taking off, agreed, but as soon as you take turns, things can get dangerous as you get > 3,000 pounds unless electric braking etc., is used.
    Actually, I believe the 6 is a few hundred pounds heavier.
  6. Jul 18, 2008 at 12:41 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Load it up and go to a truck stop with a scale. So you know for sure how much it weighs. You can look on the web for truck stops with scales, in your area. It would probably be best to know how much for sure. Instead of putting to much strain on the truck from constant use.
  7. Jul 18, 2008 at 12:44 PM
    08BlackTacoma
    South Florida
    Forgetting the braking, say the trailer had electronic brakes. Does the car have enough power to drive on the highway and pull this load? I mean the track is about 80 miles away on a highway drive.
  8. Jul 18, 2008 at 1:00 PM
    LRH
    GA USA
    '07 2.7L PreRunner
    An access cab weighs a few hundred more, and the V6 adds a little more weight, and the brakes on the 6 lug trucks are bigger, but the brakes on the 5 lugs evidently meet the criteria for 3.5K towing, but most manufacturers (and states) call for trailer brakes once a certain trailer weight is achieved; usually +/- 2,000-2,500 lbs. Lots of folks totally ignore most towing rules, because everything works out most of the time; but 1 time not working out is all it takes for a disaster, so be careful, and also don't glaze the brakes, and burn up the trans; remember heat is an auto trans worst enemy, and most of the tow time the trans will not lock up the converter; thereby producing even more heat for the in-tank cooler to handle. I would not be afraid to hook up and just drive around town and head to a scale. CAT® Scales will allow at least 2 re-weighs after you enter the scale to get all 3 (or 4 if dual axle trailer) axle weights. Don't let the tail wag the dog.
  9. Jul 18, 2008 at 1:09 PM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    Sorry, I have no answers for you, but it looks like others are helping out. Can we get a pic of the Viper????
  10. Jul 18, 2008 at 1:20 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I would NOT do this. With just the car and trailer your over your weight capacity. Add in cargo, fuel, and yourself and your putting quite a bit of stress on the vehicle. Add in the fact that your doing this on a regular basis, doesn't sound like a good idea to me.
    I would sell the reg cab and look for a V6 with a towing package.
  11. Jul 18, 2008 at 1:33 PM
    LRH
    GA USA
    '07 2.7L PreRunner
    The above is not a bad idea, but if you like your truck and need the economy of the drivetrain and the compact size, look around for a used full size about 4-6 years old, as folks are dumping them left and right for cheap. Other than initial cost, insurance, and how much $$'s is the only other problem you would need to worry about. Save your Tacoma as your runabout and tow with the used full size, and maybe in a few years fuel cost will stabilize and you can sell the full size for about what you paid. The last time gas prices jumped several years ago, a guy I know bought 2 Surburbans, drove them for 2-3 years and sold them for close to what he paid.
  12. Jul 18, 2008 at 1:49 PM
    Mingy
    Milton, Ontario
    Lear cap.
    Thats what happened to me with a load of concrete - basically jackknifed and slid sideways into the ditch. Incredibly, do damage done, but I need to change underwear!
  13. Jul 18, 2008 at 1:57 PM
    RoadKill
    RoadKill Northern Alliance: padawan
    North of the border
    First gen 4x4
    285x70x17 offset rims+ 1.5 spacers, rear Timbrens + 3 inch lift add a leaf, Sway-a-way coilovers + camburg control arms, Fender flares (2.5 inch), clear lights, headers, sliders, roll bar
    I'd say forget it... unless your car is very light
    I have a suzuki samourai for off roading, id say about 2000lb.
    on a tandem trailer around maybe 800lbs max. The 3,4 V6 could use some help especially running up hills
    tho my tires are oversized and not helping this cause (33" ) I can't wait to get the supercharger on and prob change the transfer-case ratio or gears in diff
    note on brakes: its a must... I have electric brakes on the trailer but first outting was without since I didn't have time to wire the brake plug and the little samy in back was pushing hard at stop signs :eek: so forget about emergency braking in this situation.
    I had a 2,7 before and no way I could pull that thing with reasonable speed and take-off. Very good truck but has its limits
  14. Jul 18, 2008 at 3:09 PM
    08BlackTacoma
    South Florida
    thanks for the reply's everyone. i probably will not attempt to do this since it had mixed reviews and can be potentially dangerous. Who ever said to buy a V6 and sell mine, well that is not an option. My tacoma is a trunk i use for work, does the job very well at it too. If i was buying a truck to tow cars with, i would just go out an buy a dully
  15. Sep 21, 2008 at 7:17 PM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    ahh, u can do it, ive hauled a 2 horse bumper pull trailer, with 2 good sized horses with my taco! it was in some pretty good sized hills i guess u could say, wouldnt advise it to do too much though!
  16. Sep 21, 2008 at 8:26 PM
    08BlackTacoma
    South Florida
    Just out of curiosity, what do you think the weight of the loaded trailer was with the horses and all including the trailer of course.
  17. Oct 31, 2008 at 4:34 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    if you got the money for a viper you got the money for a v6....i think. i wouldnt try towing the viper. it would suck to burn the taco out or wipe them both out.
  18. Oct 31, 2008 at 4:42 PM
    Toynbyu
    Toynbyu Active Member
    I'd worry more about stopping than pulling.
  19. Oct 31, 2008 at 4:44 PM
    paintdiddy
    shithead
    silver bullet
    i would worry about stopping and going. wait ....just tow the taco with the viper
  20. Oct 31, 2008 at 5:04 PM
    devilsalmostfree
    Carl
    Loudon, Tn
    hmm, im gonna say bout 3500lbs, not too sure on that, dont really know what the trailor weighs, horses were 900 -1000lbs, it was a pull, & i had it in 4h & 2ng gear in the toughest part!
