Can you tow with a four cyclinder?
Discussion in '4 Cylinder' started by Hublocker, Jun 29, 2018.
  1. Jun 29, 2018 at 11:08 AM
    Hublocker
    Hublocker [OP] Well-Known Member
    I've got a 2015 4x4 with 30,000 km on it.
    I've got a moose hunt coming up and need to tow a trailer. First I'd have to install a hitch and then find/beg/borrow or buy a trailer.
    How much weight could I tow with my truck?
  2. Jun 29, 2018 at 11:18 AM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I bought a Curt and installed it, was easy.
    I then rented the small U-Haul trailer and drove 1500 lbs of stuff from WA to SC. Averaged 24 mpg too!
  3. Jun 29, 2018 at 11:41 AM
    Hublocker
    Thanks. Sounds good.
    05Taco4x4 likes this.
  4. Jun 30, 2018 at 6:06 PM
    Bowers86
    Bowers86 Well-Known Member
    Vancouver, WA
    2013 RC 2WD 5-speed
    Access Cab Buckets, OE backup cam, AFE Air Filter/Secondary filter removed/Fender Elbow removed, Magnaflow 11225, XII springs/4x4 leafs/XR Bilsteins, Prodigy P3 brake controller, 3.73 Third, Undercover Tonneau, Koomus CD slot iPhone mount, Paint matched rear bumper, Drag 18x9 et20 wheels, 3rd Gen Airdam.
    Without a brake controller, I'd personally keep it to under 1500lbs or so total weight. Your state may have laws that surround such topics too (towing without braked trailer), but I doubt many police would care unless you happen to get into an accident that might involve longer than normal brake distances.
  5. Jun 30, 2018 at 6:21 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Yep. 4cyls tow just fine. A moose won't overtax it. I've used a trailer in the mountains quiet a bit for moose or elk. I did have to get use to running lower gear/higher RPM.
    There's a thread around here somewhere about what people are towing with their 4cyl.
    LocoLocal and 05Taco4x4 like this.
  6. Jun 30, 2018 at 6:26 PM
    BKill
    BKill AKA Threadkiller
    Bill
    College Station, TX
    2013 Tacoma PreRunner
    The 2.7 is rated to pull 3,500 lbs, but that would be a load. I’ve pulled 1800-2000 lbs a couple times with mine, and it did fine.
    LocoLocal, 05Taco4x4 and BassAckwards like this.
  7. Jun 30, 2018 at 8:01 PM
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
  8. Jul 3, 2018 at 3:24 PM
    Hublocker
    Thank you everyone!
    Now to find a hitch and a trailer.
  9. Jul 5, 2018 at 4:58 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    I'm also rocking a Curt. I have been happy with it. I have only used it a few times though.
  10. Jul 5, 2018 at 5:01 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Depends on the moose. :)
  11. Jul 8, 2018 at 11:54 AM
    Hublocker
    I'm hoping for a younger bull moose, maybe 600 or 700 pounds of meat and bone to haul, not 1200 pounds.
    LocoLocal likes this.
  12. Jul 8, 2018 at 12:26 PM
    chevrasaki
    chevrasaki Active Member
    '14 AC 2.7 5MT 4X4
    I used to tow 900 pounds with my Chevy Cruze. It had a 1.4T engine that made 138HP and weighed 3,300 pounds. I think the 3,500 pound recommendation is correct for the 2.7L Tacoma as long as you pay attention to all of the other factors. Center the load over the axle, use weight distributing hitch, sway control, and trailer brakes when necessary. Consider aero drag and hills when planning your trip. Just don't be dumb when it comes to towing, there are a lot of ways you can do it wrong.
    Edit: I mean really, there's guys out there towing 30,000 pounds with their dad's King Ranch F-350
  13. Jul 24, 2018 at 9:41 PM
    Mike6024
    Mike6024 Member
    2002 Base Tacoma 2.4 Regular Cab Red 5 Speed
    Skyway likes this.
  14. Aug 13, 2018 at 2:17 PM
    taco21122
    taco21122 Taco2.7
    North Carolina
    2002 tacoma DC Prerunner 2.7l
    5% tint 32” LED bar New DEPO headlights Pioneer radio Kicker speakers Bilstein 5100’s 20x10 fuel turbos 295/55/20 toyo rts
    I tow a trailer with a zero turn on it all the time. You can definitely tell it’s back there, but it still goes from A to b.
  15. Aug 13, 2018 at 2:21 PM
    SellyKlater
    SellyKlater Well-Known Member
    Ponce Inlet, Fl
    2004 Tacoma 3.4L Double Cab TRD
    3" ome lift 883. Fnfx pros.
    I used to work at a trailer shop and we used an electric golf cart to tow 16 footers around the lot. We also used a 4cl s10 exclusively. With a brake controller you could tow nearly any trailer.
  16. Aug 15, 2018 at 6:05 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Also have the Curt hitch, great product. I tow and launch/recover a ~1300 lb boat almost every weekend and have no issues. Just avoid overdrive/5th gear and be cognizant that braking will be reduced without trailer brakes. Good luck.
