Can you turn the volume up on the BSM & LDW?
Discussion in 'Technical Chat' started by Caleb Smith, Dec 14, 2019.
  1. Dec 14, 2019 at 7:37 PM
    Caleb Smith
    Caleb Smith [OP] Well-Known Member
    2020 Magnetic Grey TRD Off Road Premium.
    Hello,
    Is it possible to turn up the volume on the Blind Spot Monitoring beeps & also, how would you turn it back down if it was too loud?
    Also, is it possible to turn up the volume on the Lane departure warning beeps & how would you turn it back down if it was too loud?
  2. Dec 21, 2019 at 6:32 AM
    Ricardowelch
    Ricardowelch Member
    According to what i read, here is the instruction i think you can refer. Hopefully it can help you.
    - For Blind Spot Monitoring beep, you can also adjust the beep volume by selecting “Settings” and scrolling to the “Safety Tab”. Once there, choose “Blind Spot Monitoring Volume” and select the desired volume.
    - Lane departure warning, you can turn on or off the Steering Assist feature, as well as adjust the sensitivity of the LDW system between high and standard. Other items that you’ll find in the menu include one that looks like a cup of hot coffee. This feature indicates the Sway Warning feature, which detects excessive swaying within the lane. You can turn this on or off, as well as adjust the sensitivity.
    fireftrjef likes this.
