Can you use a 245 spare with 285's ?
Discussion in 'Wheels & Tires' started by troy28, Dec 28, 2012.
  1. Dec 28, 2012 at 10:05 AM
    troy28
    troy28 [OP] Well-Known Member
    Capitol of Salty Roads
    Need help
    I have a 4x4 and upgraded to 285s. My spare is still a 245. I have already made sure my new lugs also work with my spare.
    If I ever need to use my spare to get to a tire shop are there any concerns running a 245 and the rest of the tires are a 285?
    Can you run in 4x4 like this with out damage?
    Can you use your locker like this?
  2. Dec 28, 2012 at 10:07 AM
    98tacoma27
    98tacoma27 is gooder 'en chicken Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+250k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    NO 4X4 OR LOCKER
  3. Dec 28, 2012 at 10:09 AM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    this guy put it in caps for a reason.
  4. Dec 28, 2012 at 10:28 AM
    BAMFTACO
    BAMFTACO CASH ME OFFROAD HOW BOUT DAT
    Jośe
    Woodlandland hills , CA
    Taco
    Lift- king 2.5 with light racing uppers,tc coil bucket gusset, 4 in spindles,timbern bumps all around ,wheelers 3 addaleaf, ato shackle flip kit with 6 inch HD shackles. Armor- tire gate, custom tube bumper, kr fab rear bumper,trail gear wiy 78 in sliders Performance-intake manifold spacer, hps silicone hoses Random stuff- kenwood head unit,b&m t shifter, hood bug deflector, rear dust lights with custom bed bar and hi lift mount.
    Op definitely consider getting a full size spare
  5. Dec 28, 2012 at 10:29 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    x2 even if it's a decent used one.
  6. Dec 28, 2012 at 10:38 AM
    Brian007Taco
    Brian007Taco 007Taco
    Don't ask!
    Tempe, Arizona
    12 OR 4x4 dcsb
    12 OR 4x4 dcsb 265/75/16 KO2's wrapped on MB352's. Toytec CO's with 5100's front and back, 1/2" block and aal. Derped Emblems. Tree Smashed Taco 06 OR AC Prerunner! OME 885 with 5100's in front, TSB and AAL with 5125's in back. 30" light bar in the valance.
    When I upgraded to 265's BG AT's I got a somewhat used BG Rugged Trail of the same size. I didn't see the need to get a new one since I wouldn't use it but a few times. I'm going on almost 2 years now and haven't used it once. I've put air in it twice, but that's it. Don't get a new one! Discount Tire is where I got it from, and it was a great price.
  7. Dec 28, 2012 at 10:58 AM
    troy28
    Need help
    Thanks for the quick info!! The full 285 doesn't seem to fit under the truck with out cutting out the tabs and everything. Even then I'm not so sure. If I am going off road I will throw a full size in the bed for the day. I wanted to make sure I knew what I could do and what not to do for around town.
    If I can't fit a 285 under the truck and 245 wont cause damage (no 4x4 no locker) then I'll just leave the 245 under for everyday driving.
    Thanks for the help!!
    Any know where to get a 3/4in tire iron that also has the hole to allow it to be used like a handle to let down the spare?
  8. Dec 28, 2012 at 11:00 AM
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    You could get a skinny tire of equal diameter for a spare if that would help fitment.
  9. Dec 28, 2012 at 11:56 AM
    troy28
    Need help
    My issue is the O.D. for fitment.
  10. Dec 28, 2012 at 11:58 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You can bend the tabs out of the way with a few strikes of a BFH.
  11. Dec 28, 2012 at 12:00 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Aren't supposed to use it on the rear, either? Thought I read that here. So if you had a flat in the rear you'd need to swap a front tire back and put the spare up there.
  12. Dec 28, 2012 at 12:03 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I wouldnt go very far with it on the rear, you can heat up the diff really quick doing that. Good call ;)
  13. Dec 28, 2012 at 12:03 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    You can of course. But it will damage things. If its on the rear, say goodbye to your diff if you are travelling a long distance on it. Put it on the front. If you're in 2wd it'll be ok.
