Can you use VHT smoke tint spray on the lower driving lights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NiceGuyEddie, Jan 12, 2010.
  1. Jan 12, 2010 at 8:10 AM
    NiceGuyEddie
    NiceGuyEddie [OP] Well-Known Member
    Chino, SoCal
    none yet
    I want to smoke out the lower driving lights but I am not sure if they are too hot. The main, upper lights have the plastic lenses, but there is a lot of air in there and they were not hot to the touch.
    Do the lower lights get too hot? It says nothing on the VHT can about heat or front driving lamps.
  2. Jan 12, 2010 at 11:16 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    I don't see why not.
  3. Jan 12, 2010 at 11:44 AM
    calfire88
    calfire88 WHITE TACO
    Jeremy
    so cal
    09 trd SPORT long bed
    BHLM, satoshi grille with K/C long range daylighters behind, 2 1/2'' procomp spacer lift on front, multiple aux lights, yellow fogs, black stock trd sport rims
    i tried it but did not like it at all. idk if it was the can i used or not but when the lights were on they looked purple lol. not cool at all
  4. Jan 12, 2010 at 3:29 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    FYI, those are fog lights, NOT driving lights...why would you want to tint your fog lights...you wont be able to see through all the fog we get out here in socal....just find a set of the black blanks that go in there....
    the lower bulbs are rated at 42w IIRC, and the headlights are rated at 55w, again IIRC. i know when i was doing my most recent retro, i tested the output of the stock reflector for a bit, and i was supprised at how hot the reflector bowl got. now mind you, there wasnt a constant stream of air cooling it down, nor an insulating pocket of air, but it got hot non the less.
  5. Jan 12, 2010 at 7:31 PM
    NiceGuyEddie
    Chino, SoCal
    none yet
    i wanted to tint them because i liked the look.
    okay, i will leave the fog lights as be. the rear brake light came out perfect, three coats of tint, two coats of clear, wet sand, polish, perfect.
  6. Jan 12, 2010 at 7:43 PM
    thekid1550
    thekid1550 Well-Known Member
    bronx ny
    trd sport
    weathertech digital fits,oem hood deflector,clarion nx409,metra dash kit,20% tint on front windows,ddm tuning 6000k hi/lo hids,ddmtuning 6000k fogs,trd 2nd gen intake,alpine pdx-5,subthump access cab box,tacotunes amp wiring kit,image dynamics idq10 2 ohm subwoofer
    if I were u I would use urethane clear coat with a splash of black tinting base and cut and buff it thats what I do at my body shop Ive used the vht and over time it turns like a chalky black color no good nice on taillights though
  7. Jan 13, 2010 at 7:05 AM
    NiceGuyEddie
    Chino, SoCal
    none yet
    thanks, the urethane clear coat i used is, um, i forgot, but the guy across the street works at a body shop and i used what he recommended.
    Krylon Crystal Clear? maybe?
    i am going to buy a new, replacement brake light lens while they are new and cheap, just in case for the future.
    thanks for the advice on the fog lamps, i was about to do it.
