Canada BS Thread
Discussion in 'Canada' started by OZ-T, Aug 27, 2011.
  1. Jul 14, 2019 at 4:27 PM
    #8481
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Go to Pete’s Meats for a pastrami sandwich. Nobody beats Pete’s meat ;) (that’s what their t shirts say)
    VE7OSR and Manfred like this.
  2. Jul 14, 2019 at 5:01 PM
    #8482
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    Get a 2 scoop Choco Chic ice cream in a waffle cone from the ice cream shop on the alley beside the Place d'Armes
    Kemosabe, VE7OSR and Manfred like this.
  3. Sep 16, 2019 at 7:07 PM
    #8483
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
  4. Oct 10, 2019 at 5:54 PM
    #8484
    scocar
    scocar Patron of the Farts
  5. Oct 10, 2019 at 10:42 PM
    #8485
    OZ-T
    Peter North
    British Columbia
    Turkey Lurkey
    VE7OSR likes this.
  6. Oct 18, 2019 at 2:02 PM
    #8486
    mgmdclb
    mgmdclb Well-Known Member
    The Maritimes, Canada
    2018 MGM DCLB Sport
    Anyone else notice there is no option for a 2wd Tacoma anymore on the Build your Own for the 2020's?
  7. Oct 18, 2019 at 7:25 PM
    #8487
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I called my local Toyota dealership to see how much it would cost to replace my front wheel bearings, just to replace the bearings and a couple of seals is $1600. I am not going there. I might try to do my own with the front hub assembly sold on here.
    Anyone had good luck with anything from Lordco for hub bearing assemblies?
    Hobbs likes this.
  8. Oct 19, 2019 at 7:54 AM
    #8488
    Roughneckin
    Roughneckin Well-Known Member
    Calgary, Alberta
    09 TRD
    That’s highway robbery. I had to get a local guy do one front assembly and he charged me $500 I believe in total. If I didn’t have to go back up to work the next day I would’ve done it myself and with those full assembly kits it looks pretty simple honestly. I was told that an alignment was a good plan after though just as an FYI.
    DavesTaco68[QUOTED] likes this.
  9. Oct 19, 2019 at 8:50 AM
    #8489
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    The Toyota garage says it’s 6 hours labour, and around 600 plus for the 2 bearings and seals.
    I’m going to look into other options including trying it myself.
  10. Oct 19, 2019 at 8:57 AM
    #8490
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    $1,600 is crazy for just bearing/seal replacement. There must be cheaper options...
  11. Oct 19, 2019 at 10:39 AM
    #8491
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    A small private garage that specializes in toyota trucks said $1000, that’s not as painful.
    Hobbs[QUOTED] likes this.
  12. Oct 19, 2019 at 10:47 AM
    #8492
    Hobbs
    Yep…
    That sounds more reasonable, although it's still a chunk of change.
    :anonymous:
  13. Oct 19, 2019 at 10:54 AM
    #8493
    2016Taco
    2016Taco Well-Known Member
    Greater Toronto Area
    2016 Blazing Blue TRD Sport Upgrade DCLB 4X4
    Dam I wish you were in the Toronto area, I would say come on over and we will film it for my Youtube Channel!!!!!!! I did wheel bearings on a friends Ford and that's getting some good views. People seem to like wheel bearing videos
  14. Oct 19, 2019 at 11:08 AM
    #8494
    Tacotim0321
    Tacotim0321 Well-Known Member
    Tim
    Southwestern ontario
    Red 06 access cab trd off road
    Roof top tent 33s on American racing wheels 3 inch lift
    What is your YouTube channel?
  15. Oct 19, 2019 at 11:38 AM
    #8495
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    Thanks for the offer! If you were my neighbor I’d be over for sure !
  16. Oct 19, 2019 at 4:00 PM
    #8496
    2016Taco
    www.youtube.com/c/garageking
    Sorry for the late reply but I was filming brakes on a Mercedes today. Check out my channel and see if you like. I got some good taco videos in there. I have a variety of material. Thanks!!!!
  17. Oct 19, 2019 at 4:29 PM
    #8497
    Tacotim0321
    Tim
    I'll be sure to check it out
    2016Taco[QUOTED] likes this.
  18. Oct 19, 2019 at 11:37 PM
    #8498
    2016Taco
    Thanks !!!!!!!
  19. Oct 21, 2019 at 9:43 PM
    #8499
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Thanks a lot, Ontario and Atlantic Canada.
    you guys are awesome.
    (not that I can talk, here, on Vancouver Island)
    2016Taco, 10MGM and bigmw like this.
  20. Oct 22, 2019 at 12:19 PM
    #8500
    OZ-T
    Peter North
    British Columbia
