Canadian 3rd Gen Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheRenegade, Oct 7, 2015.
  1. Dec 16, 2016 at 1:34 PM
    #2801
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Do you really need a block heater on Vancouver Island...?? I've had a Tacos for 11 yrs now and they have seen -40C with only very minor tendency to not start.... I doubt that you ever see anything below -15 on the Island. I would not bother with it... just keep the battery connections very clean, and if you don't use the truck a lot...use a battery "maintainer"...!!
    Joe23 likes this.
  2. Dec 16, 2016 at 1:36 PM
    #2802
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    might start but still.
    They're nice to have, even if its only -15.
    They work great not just for starting, but help the whole engine warm up much faster since its not warming from such a cold temp. Plus easier starting on the starter and battery etc.
    You should get one John, they're great haha.
  3. Dec 16, 2016 at 1:48 PM
    #2803
    over60
    Muskoka, Ontario
    Agree.... But I'm retarded...er Retired....!! I can wait till the sun is up and the driveway is blown....and if it's too cold for my liking... I'll go back in the house and throw a log on the fire... F Winter..!!
    bryanjoh, 69TACO16 and monteredondo like this.
  4. Dec 16, 2016 at 2:30 PM
    #2804
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    For the island, hell no, but for everywhere else I go with my truck in the winter time yup, spend a lot of time in the interior and also in AB.
  5. Dec 16, 2016 at 2:33 PM
    #2805
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    That is one long drive.
  6. Dec 16, 2016 at 2:33 PM
    #2806
    ThangzaTRD
    ThangzaTRD Well-Known Member
    SWO
    2016 TRD Sport BBPDCLB
    Pop n loc tailgate, LED Headlight, Foglights, Reverse and all interior lights. Weathertech floor mats. Carbon fibre tailgate inserts. Trifold hard top tonneau
    What are he chances of hitting a nail on a brand new tire on day 2?
  7. Dec 16, 2016 at 2:35 PM
    #2807
    aaen
    Northern Alberta
    I prefer the old type, plus i am extremely mobile (currently on the east coast) and if I forget that cord I am pouched. I was under the impression from the Toyota dealers I talked with the block heaters for the tacomas were oil heaters through a port in the back of the engine block, am I wrong on that?
  8. Dec 16, 2016 at 2:36 PM
    #2808
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    Actually pretty good I'm thinking, I hit one on day 2, but it was in the tread and didn't do any damage. Took it to the dealer and told them to pull it out. Didn't feel like changing a flat tire if I didn't have too.
  9. Dec 16, 2016 at 2:37 PM
    #2809
    aaen
    Northern Alberta
    Yup, but i am contemplating a move back to the east coast and I had 6-8 weeks off from work. So I figured I would go on an adventure and go see the folks.
  10. Dec 16, 2016 at 2:42 PM
    #2810
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    If it's the same as the Gen 2's, they use a frost plug location.
  11. Dec 16, 2016 at 3:02 PM
    #2811
    aaen
    Northern Alberta
    Yup just did some more research on it as well, finding all sorts of aftermarket ones from 30 to 90 dollars. And that nifty install video on one, thanks for that.
  12. Dec 16, 2016 at 4:38 PM
    #2812
    Joe23
    honestly can't speak for the toyota one. haven't looked into it too much just added it because I like having it.
    I have an oil heater on my VW because it was preowned and the original owner didn't opt for one. But if you buy new their heater is a coolant heater.
  13. Dec 16, 2016 at 4:49 PM
    #2813
    aaen
    Northern Alberta
    Did some further research on it and it is a coolant heater. Just plugs into a port on the engine, driver side behind the cat. looks to be a relatively simple install compared to the 2nd gens. May just buy the toyota one for 180 buck and install it myself.
    Joe23 likes this.
  14. Dec 16, 2016 at 4:55 PM
    #2814
    Joe23
    from what I understand oil heaters are easier to install since it just goes on the pan,
    but a coolant heater works much better.
  15. Dec 17, 2016 at 9:46 AM
    #2815
    Q1000
    Q1000 Well-Known Member
    Ontario, Canada
    2016 Alpine White TRD Sport (CDN Specs)
    Anyone having problems with there tonneau covers freezing to the tailgate?
  16. Dec 17, 2016 at 9:50 AM
    #2816
    aaen
    Northern Alberta
    I did when I had my tundra, I use to just carry a bottle of deicer, you can buy this at canadian tire, its for spraying the windows to facilitate deicing. Anyways, after a snow storm, I'd spray the edges of the tonneau cover and it would pop right up after a few minutes. Then I would use the spray again to help dry up the remaining water.
    You can also smear a think layer of grease, we use to use dielectric grease as I had a lot of it on the rubber seals. Doesn't need to be much just a thin layer. This will help keep it from freezing to the tailgate.
    69TACO16 and Q1000 like this.
  17. Dec 17, 2016 at 11:15 AM
    #2817
    over60
    Muskoka, Ontario
    Try using a silicone spray. I get mine at Crappy Tire.... I spray all the door seals and any other stuff like that... It will stop the freezing issue.....!! Spray it on a cloth and rub your door seals, tonneau seals, etc..
    Kevindust, 69TACO16 and Q1000[QUOTED] like this.
  18. Dec 17, 2016 at 7:28 PM
    #2818
    littlechilds
    littlechilds skyhawk
    Cowtown
    16 trd sport Upgrade package DCLB
    KO2 tires, TRD pro rims. BP skid plate, Extang 2.0 cover, dipped grill and badges
    Here in Calgary, we've had almost 14 days straight with temps below -25C for highs with -30C wind chills (only a couple -11 days)...not once did I plug in, not once did I have issues...takes roughly 5-10min to warm my truck up which I'm fine with.
    LEXICON likes this.
  19. Dec 18, 2016 at 8:36 AM
    #2819
    aaen
    Northern Alberta
    That is great news, I've had a few hard starts here on the east coast with similar temperatures, perhaps my battery is dying, would be odd as the truck is only 8 months old? Mind you it wouldn't be the first battery I had die on me on a new truck. My 2005 2nd gen taco's battery died within 4 months when I lived in PHX, actually now that i think about it they replaced it a few times that first year, think there was a bad batch.
    Anyways, I'm still going to install the block heater as there will be multiple days/week or so where the truck will not be started in minus 30 degree temps. It also puts a lot less strain on the engine.
  20. Dec 18, 2016 at 9:37 AM
    #2820
    the_dau
    the_dau Well-Known Member
    Vancouver BC
    2017 Inferno TRD OR DCSB
    go to the dealership. should still be under warranty
