Canadian 3rd Gen Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheRenegade, Oct 7, 2015.
  1. Nov 26, 2017 at 11:23 AM
    #4001
    Auroraboy
    Auroraboy Well-Known Member
    Dave
    London, Ont., Canada
    2017 Quicksand DCSB Off Road
    Husky Weatherbeaters, BAK Revolver X2, front bedrail, Salex console tray, Predator Steps
  2. Nov 26, 2017 at 6:19 PM
    #4002
    shadowsixniner
    shadowsixniner 2017 TRD DBLC TRD OFF ROAD
    Calgary, AB, Canada
    I'm having mine installed tomorrow, I'll let you know how it turns out in a few days.
    Holdfast4[QUOTED] likes this.
  3. Nov 26, 2017 at 9:45 PM
    #4003
    TacoTrooper
    TacoTrooper Well-Known Member
    James
    Vancouver, Canada
    2013 TRD Double Cab 6-spd manual
    2013 TRD Sport DCSB 6-spd manual
    I was curious about this also and wonder if it is hard wired or if they just run the cable to the 12V plug in the dash. 670 is steep, but does have the install included. Maybe you can get a better deal if you regularly service your truck at the dealer.
    It would be cool if a system could tie into the existing feed from the rear back-up camera.
  4. Nov 27, 2017 at 8:53 AM
    #4004
    Holdfast4
    Holdfast4 Well-Known Member
    Gord
    Alberta
    2016 TRD Sport DCSB 4X4 MT
    I agree, that would be cool. The only issue is that my back-up camera gets obscured by road grime and snow when the weather is bad. I like the idea of not having to install another camera though.
  5. Nov 27, 2017 at 9:26 AM
    #4005
    crunchiespg
    crunchiespg Active Member
    Backup cameras point too far down and are too short viewing for an effective rear dash cam.
    If you pay the $700 for the Toyota camera you are crazy. They will install it just the same as any other dash cam, because that’s what it is. It’s not a plug and play system.
    So why pay triple the price for an inferior product just because it says toyota on it?
    A clean install of a dash cam takes about 5 minutes if you can hide the cigarette lighter power supply. About 30 mins if hardwired.
    over60 likes this.
  6. Nov 27, 2017 at 10:20 AM
    #4006
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    ^ This.
    Please don't pay that price for a dash cam.
    over60 likes this.
  7. Nov 27, 2017 at 6:17 PM
    #4007
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    $49 at Walmart this week. HD dash camera, not sure if it fits in the GoPro mount, but comes with a dozen different mount pieces, hard to go wrong.
  8. Nov 27, 2017 at 6:25 PM
    #4008
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    You pretty much get what ya pay for in dash cams...!! Careful.
  9. Nov 27, 2017 at 6:28 PM
    #4009
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    True. I wouldn't argue with you, that's why I walked away from it. GoPro is the only way I would go if I wanted one, I don't think I need it that bad.
  10. Nov 27, 2017 at 6:31 PM
    #4010
    crunchiespg
    I don’t think the go pro is a very good dash cam though is it? The whole point of them is they auto start when you start the car and auto save any sudden shocks.
    There are some very good heap dash cams if you know what to buy.
  11. Nov 27, 2017 at 6:38 PM
    #4011
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    Agreed. Haven't done much investigation on this, but I'm sure you're right. Auto-start ones would be best. For me, I just don't see having this as a requirement, but then again the first time I need it I'll probably regret not having it. Some jackass would make it worthwhile to have a video. Maybe I should rethink the need. :rolleyes:
  12. Nov 27, 2017 at 6:57 PM
    #4012
    over60
    Muskoka, Ontario
    Agree...also no parking mode like a dash cam will give ya..!!
  13. Nov 28, 2017 at 9:41 AM
    #4013
    MikeLinterman
    MikeLinterman Toyota Certified Truck Master
    Edmonton, AB Canada
  14. Nov 28, 2017 at 10:31 AM
    #4014
    over60
    Muskoka, Ontario
    Sounds like the Toyota Dash cam will not record a "parking event" until it happens, and then record for 20 seconds...! (after the hit)
    My BlackVue "monitors" what is going on around the truck (without recording to the card)...and if there is a movement of the truck, the dash cam records 5 seconds PRIOR to the impact and continues to record......So I get Pre-impact recording of 5 seconds...... That's the way I understand it..!!
    The Toyota one just looks too pricy..... good quality video....BUT, NO rear camera video either..!!
  15. Nov 28, 2017 at 11:09 AM
    #4015
    MikeLinterman
    Edmonton, AB Canada
    Yeah it has a lot of great features and very high image quality but you would have to back into the parking stall each time to really protect yourself for hit and runs. With the BlackVue one, if you were parked at the mall all day wouldn't it possibly drain your battery with all the traffic driving around there?
  16. Nov 28, 2017 at 11:17 AM
    #4016
    over60
    Muskoka, Ontario
    No, it uses a Power Magic Pro... and you can set the amount of power drain you are willing to accept... I choose 12V as the "cut-off" point on the Parking mode.... Don't forget...it does not "record" in parking mode... it only monitors until a hit or movement...(shut down the "movement" part and only use "impact", and it will record less and use less battery... THEN it records to the SD card 5 seconds PRIOR and 20 after, I believe..! My camera will watch my truck for about 24 hours before shutting down parking mode maybe longer....never actually checked it out..! Could be longer....not sure..
  17. Nov 28, 2017 at 4:25 PM
    #4017
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    So it has some sort of time machine capability? :notsure:
    TeecoTaco likes this.
  18. Nov 28, 2017 at 4:36 PM
    #4018
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Indeed
    Tunngavik[QUOTED] likes this.
  19. Nov 28, 2017 at 5:00 PM
    #4019
    over60
    Muskoka, Ontario
    I guess it does...if you consider it sits there till needed and then kicks into action.... !!
    No, it is watching BUT not recording to the SD card..... till there is something/someone moving around or a "shock" event on the truck....THEN, it will write (record) to the SD card..(and record the last 5 seconds PRIOR to impact and then 20 secs or more).. This saves SD card space..!!
  20. Nov 28, 2017 at 6:02 PM
    #4020
    8102
    8102 Well-Known Member
    British Columbia
    2016 Toyota Tacoma Limited
    VLEDS LED Low Beam Headlights, VLEDS High Beam LED Headlights, VLEDS LED Fog Lights, VLEDS LED Triton Turn Signals and Brake Lights, VLEDS LED Interior Lights, Reverse, Licence Plate Lights, Stainless Steel OEM Exhaust Tip, Leer XL Canopy, Bed Rug, Diablo Grill Logo, mattgecko Engine Compartment Lights and Bed Lights.
    What the Blackvue does is record and if it detects a shock (Such as someone backing into your vehicle) it "Marks" the event so that it is not overwritten by future recording.
    It does the same if you are in a collision, it marks the event starting 5 seconds before the event.
    Then you or the Police can recover the chip download the video and review the event or collision.
    Pittrider likes this.
