Canadian 3rd Gen Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheRenegade, Oct 7, 2015.
  1. Dec 5, 2017 at 7:14 AM
    #4041
    Scruffie
    Scruffie Well-Known Member
    Arsie
    Surrey B.C Canada
    2016 QuickSand Access TRD OR Manual
    265/75/16Dura,SSO Hybrid,X20,CruisinSliders,Skids
    The plastic oem running boards worked great on my truck, to protect it from other peoples doors in a parking lot. But not so good at protecting my rockers. Ripped the front mounting bracket right off the plastic and rocker of truck on a rock on a trip up Chehalis. They have since been replaced by a beautiful, functional set of sliders from Jason at Cruisin Offroad in Chilliwack. Lots of proper metal prep, sand blasting and Zinc coating before being powder coated.
    vicali and Stocklocker[QUOTED] like this.
  2. Dec 5, 2017 at 7:21 AM
    #4042
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Sounds awesome. Post some pics!
  3. Dec 5, 2017 at 8:16 AM
    #4043
    Auroraboy
    Auroraboy Well-Known Member
    Dave
    London, Ont., Canada
    2017 Quicksand DCSB Off Road
    Husky Weatherbeaters, BAK Revolver X2, front bedrail, Salex console tray, Predator Steps
    Luverne (luvernetruck.com) makes powder coated stainless nerf bars and steps. A little pricey though, but you get what you pay for I guess. I considered their Baja set before I found the used Toyota aluminum Predator steps.
  4. Dec 5, 2017 at 8:20 AM
    #4044
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    Those n-Fab nerf bars clearly came with that finish from the factory. Not designed with Canadian or Northern USA road conditions in mind. The corrosion in the picture is not due to the coating being abraded by running over rocks, that is just salt/gravel spray. For sure you can just flapwheel/sand the affected area and repaint with rustoleum or similar, but ain't nobody got time to do that every year.
    If your application is sliding on rocks, you should 100% get painted steel and touch them up with a rattle can when you get home. Powder coat chips off, and all your protection is gone at that point. You will never be able to match a powder coat finish with a rattle can.
    The OEM Predator bars are not available in Canada through dealers. There might be a reason for that. As far as I know they are aluminum, so I am not sure why they are not considered fit for service here.
    My "real world" conditions are normal winter conditions, my nerf bars will be used as steps and parking lot body protection only.
    It is possible to powder coat stainless steel, but the prep is a specialty process and you might struggle to find a shop that can do it.
  5. Dec 5, 2017 at 8:23 AM
    #4045
    mrCanoehead
    Ottawa
    Thanks, I will check that out for sure. Have you gone through a full winter with the Predators? I am wondering what the reason is, that Toyota does not sell them up here.
  6. Dec 5, 2017 at 8:43 AM
    #4046
    Auroraboy
    Dave
    Yes - have gone through a full winter in southern Ontario - no issues. Check out Predator step pricing from a Minnesota Toyota dealer, and drive across the border. They literally install in 15 minutes. There are plastic plugs in the threaded female mounting holes under the truck. Pull the plugs and thread the mounting bolts in. If they are good enough for Minnesota, ND, SD etc. winters, they should work here.
    If you are more concerned about parking lot protection, you are better to get a set of running boards. They are wider and prevent door dings better, but to me, they are harder to use as steps, unless you are tall.
    These ones are plastic over aluminum - and available in Canada (https://tacomatownonline.com/collections/tacoma-3rd-gen-exterior-accessories/products/running-boards). Some other CAD members have them. Pretty reasonable price too. I think they came out with the Gen 2 trucks, but they fit the Gen 3's. I believe @over60 has them, and can chime in.
    Toyota US also sells the Cast Aluminum running boards (https://www.toyota.com/tacoma/accessories/exterior) - sometimes referred to as Shark boards. I think these were released for Gen 3. Not sure if these are available in Canada.
  7. Dec 5, 2017 at 9:44 AM
    #4047
    Rider Eh!
    Rider Eh! Well-Known Member
    Calgary, AB
    17 Tacoma DCSB TRD Sport V6 Manual 4X4
    I'm going to have to disagree with the statements that powdercoating helps. My Westin SS nerf bars had powdercoated hangers, most all of it was chipped off in a few months. Luckily you can't really see the hangers but they are looking pretty rough. I tried spraying with rockguard but that doesn't help either.
  8. Dec 5, 2017 at 11:10 AM
    #4048
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    You are right Dave.... I had those aluminum OEM boards on my 2006 for 10 yrs.... still in great shape when I traded....Dealer thru on a new set on my 2016 as well...! Good for door ding protection.... A little high as a step though... Ole lady uses them as a step but has to grab the Oh Shit handle and pull herself up..!
    I mainly like the road crap protection they give the bottom edge of paint.....:thumbsup::thumbsup:
  9. Dec 5, 2017 at 8:03 PM
    #4049
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    I've had the chrome OEM ones on my Gen2 and now the Gen3, they've beeen great, no rust. But I'm in BC, so can't compare to a Ontario winter, a lot less salt. They are a little close to the body for an actual step, but they do help on the door ding side.
    over60 likes this.
  10. Dec 5, 2017 at 8:30 PM
    #4050
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    Got them too. Trying to figure out how to extend them out a little
    over60 likes this.
  11. Dec 5, 2017 at 8:38 PM
    #4051
    Canadianguy91
    Sean
    2016 Limited
    I doubt it, but will take a shot..
    Any guys here in Halton Hills or more specifically, Georgetown?
  12. Dec 17, 2017 at 9:44 AM
    #4052
    TacoTrooper
    TacoTrooper Well-Known Member
    James
    Vancouver, Canada
    2013 TRD Double Cab 6-spd manual
    2013 TRD Sport DCSB 6-spd manual
    DavesTaco68 likes this.
  13. Dec 28, 2017 at 9:47 AM
    #4053
    arsegura
    arsegura Member
    Do you know where someone could get these decals?
  14. Dec 28, 2017 at 1:44 PM
    #4054
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    The 80's?
    Seriously though, I would go to a pinstripe shop if they even exist any more.
    Miraclejoe and over60 like this.
  15. Dec 28, 2017 at 3:50 PM
    #4055
    over60
    Muskoka, Ontario
    Is that you man...?? Nice tux and Mullet..!! :rofl::rofl::rofl:
    Tunngavik[QUOTED] likes this.
  16. Dec 30, 2017 at 10:55 AM
    #4056
    TyGuy1
    TyGuy1 Member
    Ty
    2017 Tacoma TRD Sport DCSB MT
    anyone in the Vancouver area want a set of OEM all-weather and fabric floor mats for a Double Cab?
  17. Dec 30, 2017 at 11:16 AM
    #4057
    lkmcfee
    lkmcfee New Member
    Vernon BC, Canada
    17 TRD Pro Barcelona Red
    Anyone in the Okanagan looking for a light bar for a 2016-18 Tacoma, I have a 30” CaliRaised light bar and everything needed to install it for sale, works great, wanting to sell because I’m installing a different light bar.
  18. Dec 30, 2017 at 5:49 PM
    #4058
    sodaryl
    sodaryl Well-Known Member
    Daryl
    Vancouver, BC
    2016 Blazing Blue DCSB M/T Sport
    -Relentless Off-Road sliders -265/70r17 Wrangler Duratracs -Diamondback HD -CCG Mesh grill -Pop & Lock PL8535 -BPF Heavy-Duty Front Tow Hook
    I see you have a MT... What did you replace them with?
  19. Dec 30, 2017 at 6:46 PM
    #4059
    TyGuy1
    TyGuy1 Member
    Ty
    With some husky tub style liners. They’ve been awesome so far
  20. Dec 30, 2017 at 8:34 PM
    #4060
    sodaryl
    Daryl
    Vancouver, BC
    Part # and where'd you find them? Husky's site doesn't even have the manual transmission front ones anymore :(
