Canadian truck - US dealers won't do frame rust check?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tbrady, Jan 2, 2021.
  1. Jan 2, 2021 at 9:25 AM
    tbrady
    tbrady [OP] Member
    Hi All,
    I just picked up a 2016 TRD Sport that came from Canada. Little did I know how problematic this could be...
    I was just at my local dealer in WA state and was told I have to take the truck to a Canadian dealer for the frame recall/campaign.
    Has anyone else had this experience?
  2. Jan 2, 2021 at 9:29 AM
    tbrady
    tbrady [OP] Member
    Ok, I just spoke to someone else at the dealer and they said the reason they can't do anything is because WA state is not considered a cold weather state and they don't actually have the compound. So... looks like we'll have to make a trip to get it checked.
    Bishop84 likes this.
  3. Jan 2, 2021 at 9:33 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Doesn’t wa-shit-ton state get a shit ton of snow each year?
    Bleep100 and BMH like this.
  4. Jan 2, 2021 at 9:37 AM
    averagejp
    averagejp Well-Known Member
    2005 Black Tacoma Extended Cab
    Work in progress
    OP, might be worth asking another dealer or calling the Toyota Customer Care line (the 800 number is in the warranty booklet if you still have it). May not get a different answer but worth a few more calls, especially with the border closed. If you open a case, and tell them you can't get to CA due to Covid, maybe they can figure out something for you. Also, not a bad idea to have a paper trail just so the timeframe on the replacement doesn't run out on you.
    Worth a shot ... and best of luck to you !
    Big tall dave likes this.
  5. Jan 2, 2021 at 10:32 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Gray market vehicles; it sounds common mfg denys warranty claims in countries vehicle wasn't built for/allocated to.
    Kev250R and vicali like this.
  6. Jan 2, 2021 at 10:35 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    I dont think the frame recall applies to 2016+ trucks.
  7. Jan 2, 2021 at 10:38 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    A service advisor/rep initially told me they couldn't do the tsb/frame inspection and treatment on a Canadian truck and when I explained to them that it's now registered in Michigan and was imported so it's been converted as required by law, they put me on hold for a min then came back and said no problem.
    Question for you, though, does your truck have automatic climate controls? If so, is the temp display in Celsius?
  8. Jan 2, 2021 at 10:40 AM
    Inoculum
    Inoculum Well-Grown Member
    Parts Unknown
    16’ Limited
    Just scheduled my 2016.
    dealer said it takes 4 days.
  9. Jan 2, 2021 at 10:44 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Working for large auto groups near the US boarder for many years I can tell you there is a difference between US companies and Canadian companies. Toyota USA and Toyota Canada are two different entities. Some warranty work can be done however something like a frame swap if the frame was found to be bad would infact have to go back to Canada to a deal to have the warranty work repaired and processed.
    Kev250R likes this.
  10. Jan 2, 2021 at 11:44 AM
    tbrady
    tbrady [OP] Member
    Yeah, the climate controls are in celsius. And like a lot of other folks I have searched high and low for a solution with no luck. I asked the dealer this morning and they said you couldn't change it. The pretty much blew me off... This is the same dealer I bought our Sequoia and Tundra from and I expected a lot better service than we got.
    And WA state gets a ton of snow on the eastern half of the state so not sure why we're not considered a cold weather state.
    BMH likes this.
  11. Jan 2, 2021 at 12:01 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    I would think there's a good chance, that Toyota America won't reimburse the American dealer for warranty work on a vehicle that was bought from a different corporation,,, Toyota Canada, so that's why they're not helping you. As @Lawfarin mentioned, there is a Toyota America and a Toyota Canada,,, two different entities.
    It's also believed they do this to protect pricing, since the value of the dollar isn't 1-1.
  12. Jan 2, 2021 at 1:01 PM
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    What?? WHAT?? You've GOT to be kidding me... WA. not a 'cold weather' state? Now I've heard everything.
    I live in the very north-east corner of WA. 40 miles from the Canadian border. It's currently 24* degrees out (Sat. - 1-2-2021 1 PM) and we just got 12" of snow two days ago. (That I'm still clearing from the doorways..)
    What dealer told THAT BS.??? I'd have a serious conversation with THAT guy... Are you on the west coast?
  13. Jan 2, 2021 at 1:08 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Not the first to have issues with Canadian trucks in US. Good luck.
  14. Jan 2, 2021 at 1:10 PM
    BMH
    Bruce
    Yes we do ... East of The Cascades anyway. Lived here for 20+ years now. What everyone seems to forget is 'Seattle Does Not Equal' the 90% of the rest of the state. We got (here) 12" of snow two days ago and I'm still doing 'clean-up' with our plow truck and just finished shoveling all the snow by the doors that slid off the roof, just to be able to get in/out ...
  15. Jan 2, 2021 at 1:14 PM
    BookieBob
    BookieBob Beer Drinker
    Racine,Wisconsin
    2021 Silver Sky TRD Sport 4WD MT
    yes.. I just got one
    VE7OSR[QUOTED] likes this.
  16. Jan 2, 2021 at 1:24 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Wonder if its similar like buying a polaris snowmobile in canada, and trying to get warranty on it in the u.s. Polaris won't accept a warranty claim on their sleds sold in canada. They told me it has to go back to a polaris dealer up there.
    FastEddy59 and Chew like this.
  17. Jan 2, 2021 at 1:25 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Some parts but none of it gets that cold.
  18. Jan 2, 2021 at 1:41 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    Don't they hardly ever salt the roads in WA, and when they do it's only specific roads needed for infrastructure maintenance/repair in the big cities? The cold doesn't corrode the frames, the salt+water does.
  19. Jan 2, 2021 at 4:01 PM
    tbrady
    tbrady [OP] Member
    Yeah, this was the Toyota dealer in Kirkland. She did mention that part of designating a state as a cold weather state also included whether the state used a lot of salt or not (which apparently WA doesn't use enough to qualify!).
  20. Jan 3, 2021 at 9:32 AM
    BMH
    Bruce
    Sounds to me like they're handing you a big load of crap... Just trying to worm their way out of fixing the problem. I'd ask her where she gets her stats from. Sounds like she's just pulling stats out of her butt. I'd also remind her that even though King County thinks it's the entire state of WA. ... It is not.
