Canadian Truck
Discussion in 'Technical Chat' started by rlee7421, Mar 26, 2019.
  1. Mar 26, 2019 at 9:35 AM
    rlee7421
    rlee7421 [OP] Member
    Randy
    2012 Toyota Tacoma
    I have a Tacoma that was sold new in Nove Scotia, I bought it used in the states, unaware of this till after the purchase. The speedometer and odometer doesn’t work, the dealer is telling me I need a part to convert it to American, but they are unable to me a part name or number. Any help would be appreciated.
  2. Mar 26, 2019 at 9:37 AM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    2001 XtraCab Tacoma TRD 4x4/2004 SR5 V6 4Runner
    Tacoma: Badlands basher front bumper Trail gear rear bumper Trail gear sliders OME Dakar’s OME 883 Coils Bilstein 5100s front Bilstein 5125s rear SPC Upper Control Arms Wheeler’s Extended brake lines ProComp 51 Series 15x8 3.5” BS 32x11.50x15 BFG KO2’s Honda CR-V windshield washer nozzles Hella 500FF fog lights Energy Suspension power steering rack bushings 4Runner: Hankook DynaPro ATM RF10 265/70r17’s TPMS Bypass mod RCI Skid Plate CBI Ditch light brackets 1.25” Wheel Spacers 2” Front Leveling Kit
    So they say it won’t work because it’s in the US now and it can’t read miles? :facepalm:Please go to another dealer that’s not retarded.
    Also it’s most likely something to do with the abs wheel speed sensors, harness, or skid ecu.
  3. Mar 26, 2019 at 9:43 AM
    rlee7421
    Randy
    2012 Toyota Tacoma
    Thank you for your input.
  4. Mar 26, 2019 at 1:30 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    My 2000 switches between Miles and Kilometers with the push of a button
    FishnTx and AxisCab like this.
  5. Mar 26, 2019 at 3:52 PM
    rlee7421
    Randy
    2012 Toyota Tacoma
    There are saying that I’ll need a part of some type to make it work at all. Right now the odometer and speedometer is not functioning
  6. Mar 26, 2019 at 3:56 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Canadian trucks have mph as well as km/h markings on the speedo.
  7. Mar 26, 2019 at 7:50 PM
    rlee7421
    Randy
    2012 Toyota Tacoma
    Once again the speedometer and odometer is not working
  8. Mar 26, 2019 at 7:52 PM
    Sharpish
    Brian
    There's no "part" to convert it to American is what I'm saying.
  9. Mar 26, 2019 at 7:54 PM
    rlee7421
    Randy
    2012 Toyota Tacoma
    I didn’t think there was either. One thing this truck has is an after market alarm system, I’m thinking when they wired it, they screwed up something.
  10. Mar 26, 2019 at 7:58 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Yeah if the speedo and the odometer are dead it’s most likely either the instrument panel is messed up or the wiring to the panel is. Check to see if any wires are cut in the dash that lead to the instrument panel.
    For whatever it’s worth the only difference between a US Tacoma and a Canadian Tacoma on the instrument panel is that it reads kilometres with mph on the inside of the dial in a smaller font.
  11. Mar 26, 2019 at 7:59 PM
    rlee7421
    Randy
    2012 Toyota Tacoma
    Mine does have the American speedo in it
  12. Mar 26, 2019 at 8:23 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I'd start by checking the GAUGE fuse. Any lights work in the cluster?
  13. Mar 27, 2019 at 1:01 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    It was how you worded the Question that confused me at least.
    Maybe Start with the year and some specs.
    It might be possible that the part in the cluster that shows mileage is burnt out that allows you to toggle between miles and kilometers .
    Might be why nothing works .
    Then if Those trucks VIN`s are not in The USA Toyota Parts data base some counter people are going to be clueless never having had this problem I can`t say.( Maybe just did not want to bother)
    Anyone have this happen to them from Canada trying to look up parts on American Toyota sites ??
  14. Mar 27, 2019 at 10:03 AM
    Sharpish
    Brian
    I'm pretty sure the part numbers are different for everything.
  15. Mar 27, 2019 at 11:56 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Thank you for Confirming what I thought
  16. May 7, 2019 at 12:23 PM
    JonnyAppleseed
    JonnyAppleseed Well-Known Member
    Grand Rapids, MI
    2010 DCLB
    Turning my Base into an SR5 one piece at a time
    Looks like this thread has been dead for a while, but I figured I'd throw in my two cents. I had a similar situation with the purchase of a 2010 DCLB CAN truck and not finding out until after the purchase and I took it to my dealer for the leaf-spring recall.
    However, my situation at the dealer has been a little different from yours. My dealer hasn't given me any crap, and with some body work I needed to have completed (I've been rear-ended twice), I haven't heard a thing about part numbers being different. Sounds like I've got the same speedo as you (analog dial with a digital odometer/tripometer) with MPH on the outside of the dial, KMPH on the inside and my digital odometer reading in miles.
    I'm going to have to agree with some of the earlier posters that even if the speedo/odo is broken, you should be able to use any parts available here in the US interchangeably with CAN parts. Kind of seems like you dealership is feeling a little lazy.
