Canadian vehicle now in the U.S
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hertel11, Feb 12, 2016.
  1. Feb 12, 2016 at 6:21 AM
    hertel11
    hertel11 [OP] New Member
    Todd
    2008 TRD sport double cab 4x4
    Ok, so I'm planning to purchase a 2008 TRD sport double cab 4x4. I recently discovered the frame rust service campaign and everything so I am concerned. I talked to a dealer and gave them the VIN. They said the only recall was on the leaf springs but the vehicle originated in Canada so they cannot perform the recall. I'm confused by this. Also, I live in OH which is part of the 20 state "salt belt" that was supposed to get frames replaced. I just don't know now whether or not to purchase this vehicle. I'm wondering if anyone has had similar experiences and how they were resolved. If I am to get recall work done I wouldn't want to have to have it done in Canada. Can someone please give some help/advice/guidance?
  2. Feb 12, 2016 at 6:26 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    You really should be able to get it done anywhere, try calling another dealer?
  3. Feb 12, 2016 at 6:31 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I personally would not buy any truck that was in the years effected by the frame problems. Sorry but I don't want to deal with it. It is asking for a freaking headache. Especially if this will be your only vehicle. Even if you have to frame swap, it can take months.
  4. Feb 12, 2016 at 6:40 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Remember, frame replacement only happens if they find large rust holes. Otherwise the dealer sprays a corrosion-inhibiting compound and typically does a very sloppy job (because warranty work pays little). Due to poor application, the spray may do more harm than good.
    Get the truck inspected before buying. If frame is in good shape, buy it. If there's significant rust, walk away. Note the rust starts from the inside, so the shop should use an endoscope to check the frame (suspect areas are next to the catalytic converters).
  5. Feb 12, 2016 at 6:49 AM
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    2021 TRD PRO 6MT Midnight Black
    You won't enjoy crossing the border to have work done if that is the case. It's not a Canada thing, it's a border crossing thing. That could get messy and complicated for you. I'm from Cleveland originally and used to live in Toronto...it is 3 plus hours to the Peace Bridge in Niagara or about the same to Detroit.
    Find a different truck!
  6. Feb 12, 2016 at 6:56 AM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    When I had my frame inspected for the rust, they didn't apply anything over the frame. Of course TN doesn't apply road salt very often, but my dealer sent me on my way without any "anti-rust spray".
  7. Feb 12, 2016 at 7:01 AM
    hertel11
    Todd
    Ok thanks guys. Aren't like nearly all years of Tacomas affected by the frame problems except for new vehicles? I will be buying this truck used most likely with no warranty so will that affect me trying to have the leaf springs that were recalled replaced and if needed the frame sprayed/replaced? I can't afford a brand new vehicle at this point so I was really hoping this would work out.
  8. Feb 12, 2016 at 7:45 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The frame rust campaign currently covers 2005-2008 models , but I expect its only a matter of time before it is expanded
  9. Feb 12, 2016 at 10:03 AM
    hertel11
    Todd
    Just got off the phone with Toyota Canada and they indicated service could be performed in the U.S. but the dealer will have to call Toyota Canada to confirm it can be repaired and falls under recall. They also told me according to the VIN that the vehicle already had been serviced in regards to the frame corrosion but could not tell me whether or not it had been replaced or just sprayed. He also said it has a 15 year warranty on corrosion to the frame because of the service campaign
  10. Feb 12, 2016 at 10:03 AM
    KenLyns
    Belly of the Beast
    There's a lengthy thread here about the frame rust treatment (68 pages) continuously updated with new information. Read through it all and be familiar with the campaign. There are both success stories and disgusting workmanship issues reported: https://www.tacomaworld.com/threads...aign-for-corrosive-resistant-compound.329708/
    As with any used vehicle purchase, have it inspected top-to-bottom, including checking the frame for severe rust. If you see severe rust, walk away and find another used Tacoma (plenty out there). Don't buy a heavily rusted truck and attempt to get the frame replaced by Toyota - too many potential roadblocks and potential problems down the line (effectively a single mechanic taking apart your truck and putting it back together).
    Leaf pack replacement, even if you have to get it done out of pocket at an independent shop, isn't cost-prohibitive (~$400). Work scope is relatively small considering the number of people here who have installed lift kits.
  11. Feb 24, 2016 at 4:01 PM
    eric801
    eric801 Well-Known Member
    Eric801
    BC Canada
    07 Trd
    bypass the dealer and call toyota.com
  12. Mar 8, 2016 at 4:44 PM
    eric801
    Eric801
    BC Canada
    07 Trd
    there are some good points brought up regarding your query
    here's more.
    I live in Canada and just sold my 07 to a guy in Washington state.
    the importation was easy. He did send me the following link that I had not been aware of.
    http://www.tacomahq.com/2629/driveline-vibration-expand-tsb/
    over all get the truck checked out properly as any prudent buyer should.
    Unfortunately I've had some less than great experiences in pre purchase inspections. i.e. they did a lousy job.
    Don't go to the sellers shop. Find your own and find out what they are going to inspect.
    shops here charge $100 an hour so you don't get much for $100. Also I have not been happy with CAA (automobile assoc) pre purchase inspections.
    Toyota will cover Canadian truck warranty in the states. If you go through with the sale register yourself as the new owner with Toyota.com
    re leaf springs, mine lost spring at 100,000 miles and I put in Firestone Ride Rites. Same price as new springs and I feel did a better job.
    good luck.
