Cannot figure out this squealing sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anthony250f, Jun 21, 2018.
  1. Jun 21, 2018 at 5:50 PM
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I can not figure out this sound. I originally thought ac Compressor since it only happened when the ac engaged. Well ac compressor was replaced but it’s STILL THERE. I’m starting to think alternator ? All the idlers and tensioner bearings are brand new
    https://m.youtube.com/watch?v=b25Kk2PBQxM
  2. Jun 22, 2018 at 4:48 AM
    709GADE
    709GADE Well-Known Member
    '09 Toyota Tacoma 4X4 SR5 DC LB - Pyrite Mica
    Toyota aluminium side steps, Toyota door sill protectors Extang trifecta tonneau cover, U-Haul Class 3 hitch, Black Weathertech's, Front mudflaps trimmed 4", OEM Fog Lights, WeatherTech Bug Deflector, 13" Stubby antenna, TRD Skid Plate, ScanGaugeII, Carriage Works Billet Grille, Plasti Dipped overhead temp/compass console, LT265/75/16 Duratrac's LR C
  3. Jun 22, 2018 at 7:34 AM
    anthony250f
    Anthony
    San Diego, CA
  4. Jun 24, 2018 at 9:57 AM
    anthony250f
    Anthony
    San Diego, CA
    Bumpppppp
  5. Jun 24, 2018 at 9:58 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's a new one. Almost sounds like a drag car at idle haha
    Sorry I can't be of more help. I have no clue.
  6. Jun 24, 2018 at 10:03 AM
    anthony250f
    Anthony
    San Diego, CA
    I removed belt and spun all of the bearing and they all sounded fine ?!
  7. Jun 24, 2018 at 10:07 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Remove the belt and start it. Is the noise still present?
  8. Jun 24, 2018 at 10:16 AM
    anthony250f
    Anthony
    San Diego, CA
    I’m gonna have to wait u til it makes the noise again. It is really intermittent and does not make this sound MOST of the time. Just came back from the garage to try to find it but it’s silent currently.
  9. Jun 24, 2018 at 10:22 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    When it returns try to spray some water or a light mist of wd40 on each pulley that may isolate it if the noise goes away when hit with it
  10. Jun 24, 2018 at 1:00 PM
    Tennessee YODA
    Tennessee YODA Damn pigeons
    Knoxville tn
    2008 red tacoma pre runner
    Bull bar nilight light and light bar grill vision rims replacement grill aftermarket headlights
    Got the same issue but does it with the ac off and on doesn’t do it all the time really started to see some correlation when it’s colder weather, it’s synchronized with the throttle more throttle the louder it gets , curious to what you come up with , cause I’ve had no luck diagnosing the issue
  11. Jun 24, 2018 at 2:13 PM
    WILLIAM ROBERT
    WILLIAM ROBERT Well-Known Member
    Edmonton
    it's blue
    Maybe it’s the alternator. Turn on all the lights, heater, accessories and see if the noise comes back. As stated before, when it happens try spraying WD-40 at the bearings/ alternator and see if the noise changes or goes away.
  12. Jun 24, 2018 at 2:13 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Get a stethoscope and poke around, they are like $10 at harbour feight.Screenshot_20180624-161122_1.jpg
    Tennessee YODA likes this.
  13. Jun 24, 2018 at 5:00 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    You ever take the belt off and check the idler pulleys and tensione pulley?
    lanomed likes this.
  14. Jun 24, 2018 at 5:18 PM
    Tennessee YODA
    Knoxville tn
    I have not , is that where I need to start? thought ab doing the wd40 also. It’s happens usually in the am when I’m leaving for work but not every day so it’s been hard to really have the time to check it , with it being so sporadic does that sound like it could be the idler and tension pulleys.
  15. Jun 24, 2018 at 5:34 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Thats where I's start. Won't cost you anything but a few minutes of your time. See if any of them wobble back n forth and see if they spin pretty freely without making too much of a crunchy sound. If it spins waaaay to freely, another sign the bearing maybe bad. If you find a suspected bad one, to save a few bux, bring it to a local bearing shop see if they can match the bearing, so far I havent had an issue doing that. A bearing is $10-$15, an idler pulley is about $40, a complete tensioner is $125+.
  16. Jun 24, 2018 at 5:37 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    14mm socket and breaker bar counter clockwise on tensioner to loosin the belt.
  17. Jun 24, 2018 at 6:13 PM
    Tennessee YODA
    Knoxville tn
    Will do thanks for the info man
  18. Jul 19, 2018 at 10:27 PM
    anthony250f
    Anthony
    San Diego, CA
  19. Jun 8, 2019 at 3:56 PM
    anthony250f
    Anthony
    San Diego, CA
