Cannot find a solution to poorly performing rear brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mxpatriot, Feb 16, 2017.
  1. Feb 16, 2017 at 10:05 PM
    Mxpatriot
    Mxpatriot [OP] Well-Known Member
    '06 4x4 AP LT and Locked
    The symptoms:
    Brake pedal is spongy. Depresses a little more than I'd like, but not down to the floor.
    E-brake is incapable of stopping the truck, even at a 2 MPH roll on flat ground.
    I can still get all four tires to lock up when I slam on the brakes; granted this is on icy roads.
    What I've done:
    Replaced rear brake shoes
    Adjusted rear brake shoes, multiple times. Set them as tight as I can get them and I still have a spongy pedal and ineffective e-brake.
    Replaced front brake pads
    Bled brakes
    Master cylinder is relatively new (less than 30k on it)
    Any ideas?
  2. Feb 16, 2017 at 10:11 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Do we have a cable adjustment?
  3. Feb 16, 2017 at 10:12 PM
    inwood customs
    Dave
    As for spongy feel..... stainless steel braided lines shoukd help some.
  4. Feb 16, 2017 at 10:18 PM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Rear disk conversion?
  5. Feb 16, 2017 at 10:26 PM
    inwood customs
    Dave
    Worse stopping from most the info i gathered on here about that swap
    RedRed likes this.
  6. Feb 16, 2017 at 10:36 PM
    Mxpatriot
    Already done a long time ago.
  7. Feb 17, 2017 at 5:15 AM
    jmgtp
    jmgtp Well-Known Member
    2013 2.7 4x4 5sp
    None
    If the ebrake can't stop the truck at 2 mph and you have a spongey pedal I doubt it's air in the system or expansion in the hoses. The shoes sound like they are out of adjustment. Adjust again!
  8. Feb 17, 2017 at 5:25 AM
    98tacoma27
    Ben
    Not Beech Creek
    I believe so. That's what I would do since the e-brake is a mechanical function and doesn't use the hydraulics.
    On my first gen, the e-brake seized so it wouldn't engage when the handle was pulled. I had to drive the pins out that hold the clevis where it enters into the drum. The clevis had corroded fast there. Worked like a charm after that. The spongy feeling though? That might be the booster.
  9. Feb 17, 2017 at 7:04 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    this seems to be a common issue with 2nd GEN trucks, mine does the same and ive read all the threads and fixs and it still has a soft/spongey brake pedal. Im thinking its something inherent in the design that causes this,only thing you can do to give the pedal an adequate feel is to make sure the rears are adjusted, bleed the brakes,replace or clean caliper pins,resurface the rotors and call it a day. I took mine back to the dealer where I bought it(used)49k miles after replacing pads,bleeding,adjusting and told them to test drive it, the technician said he has the same truck and it does the same and that's just how they are.
  10. Feb 17, 2017 at 7:07 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I do believe @Jimmyh has some know on rear brake adjustment.
  11. Feb 17, 2017 at 7:16 AM
    Pigpen
    Dan
    Northwest Montana
    2nd gens are notorious for having a "soft" brake pedal, even when the brakes work normally. If you spend any time driving a full size truck, our brake pedal can be downright annoying - except that the brakes will still perform just fine. I think that's a separate issue from your parking brake. The cable adjust for the parking brake is under the center console.
    MTopp, calico and Mush Mouse like this.
  12. Feb 17, 2017 at 7:25 AM
    Mush Mouse
    mush
    2013 SR5
    also if the rear brakes are adjusted correctly the parking brake should have between 7-10 clicks
    Pigpen[QUOTED] likes this.
  13. Feb 17, 2017 at 9:54 PM
    Mxpatriot
    Drove 20 miles today, tried adjusting the rear brakes again. Can't get then any tighter and I still have a low, mushy pedal with a non functional e brake.
    I think my step will be to replace the drums and wheel cylinders.
    Front Brakes working great, so I doubt it's the MC
    MTopp likes this.
  14. Feb 18, 2017 at 12:52 AM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    I know how you feel, I have a 06 that had a firm pedal until sept when I had the frame replaced, now I have the dreaded spongy pedal and have not been able to figure it out yet, as I have to rely on friends who have garage space work on the brakes, after multiple attempts at bleeding, it still has the spongy feel which I will get figured out eventually even if it takes forever cause I don't like the spongy pedal feeling.
    MTopp likes this.
  15. Feb 18, 2017 at 6:46 AM
    moondeath
    Pa, Gardners
    This is from a different thread, ABS can cause issues with bleeding.
    MTopp likes this.
  16. Feb 18, 2017 at 12:43 PM
    tomrtrd
    tomrtrd Member
    tom
    06 Tacoma 4X4
    ALARM @ REMOTE START, 2" LEVELING LIFT
    spongy brake pedal, is one of the pistons in the calipers frozen ? How are you adjusting the rear brakes , the star wheel ? the rotors and drums in spec? The wheel cylinders leaking?
  17. Feb 18, 2017 at 12:51 PM
    Mush Mouse
    mush
    2013 SR5
    if the wheel cylinders are not leaking they should be fine, why is the e brake non functional?
  18. Feb 18, 2017 at 1:08 PM
    Mxpatriot
    I don't know. My guess at this point is that the shoes aren't mating to the drum well. That's the only thing that I think can explain a non functional e-brake as well as poor pedal feel.
  19. Feb 18, 2017 at 1:14 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Make sure the parking brake cable fitting is not broken where it enters the rear drum backing plate.
  20. Feb 18, 2017 at 1:21 PM
    10MGM
    10MGM Well-Known Member
    2010 AC MGM 4x4
    If adjustment is correct and both sides are actuating I would give them a good burnishing using e brake. May have to adjust after a cool down.
