Cannot fuel up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by prokopto, Feb 21, 2021.
  1. Feb 22, 2021 at 5:04 AM
    Slow Internet
    Slow Internet 56k Modem FTW!
    Slow...
    1992 Dial Up Modem...
    Wiper Blades
    This actually happened to me like a year ago and was maddening. I couldn't find anything wrong.
    Went offroading one weekend and it fixed itself. So I guess something is hung open and needed a jar to correct itself.
  2. Feb 22, 2021 at 5:05 AM
    Markcal
    Markcal Well-Known Member
    The best time to fix the stuck winch that lowers your spare tire is before you need it after getting a flat tire, so I would add that to your to-do list after fixing the no-fuel problem.
    TRDSport10 and Gunshot-6A like this.
  3. Feb 22, 2021 at 8:35 AM
    prokopto
    prokopto [OP] Member
    2010 4 door trd sport
    Thanks Markcal, I had that on my to do list. Just got it done with Seafoam penetrator oil. Unstuck it in 20 minutes works like a charm now.
    Markcal[QUOTED] likes this.
  4. Feb 22, 2021 at 8:44 AM
    prokopto
    No nothing missing from the gas can but when I push a 4" zip tie into the filler neck it goes all the way. My mechanic is leaning toward the valve. It's throwing code P0453
  5. Feb 22, 2021 at 8:44 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    I have nothing helpful to add, but I love a good mystery. Good luck, OP.
  6. Feb 22, 2021 at 8:46 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Be careful throwing parts at it, evap codes usually require a little diagnosis
  7. Feb 22, 2021 at 8:59 AM
    prokopto
    The truck is throwing code P0453 which is an Evap. Can. code but my mechanic says that we should take it slow and not just waste money replacing parts because there are several little simple things that can cause that code.
    Also my fuel in over half a tank (I know that for a fact) but my fuel light is still on and the gauge is stuck below 1/4 tank. Is that because the sender is bad or because the problem throwing the evap code is disabling the fuel level sending unit?
    Gunshot-6A likes this.
  8. Feb 22, 2021 at 9:00 AM
    prokopto
    Amen! My mechanic said the same thing
    TRDSport10 and b_r_o[QUOTED] like this.
  9. Feb 22, 2021 at 9:01 AM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    I have a bmw that does this, but if I put the gas pump in the car upside down it magically works
    b_r_o likes this.
  10. Feb 22, 2021 at 9:02 AM
    prokopto
    Thanks, I will try to honor the unspoken trust of the forum by posting everything I can so that it helps other Tacoma owners down the road who may face this same issue.
  11. Feb 22, 2021 at 9:50 AM
    Sudsman44
    Sudsman44 Well-Known Member
    Abington PA
    2012 Tacoma Access 4x4
    Ranch cap w/ rhinorack bars, 5100s, Deaver AAL, 2” front receiver, Matt Gecko bedlights, yadda yadda…
    Also a problem with Fords. We have 2 F-250’s for work and they both have this issue. We had the fill hose replaced on one but it did no good. Some nozzles work better than others so we get gas only at certain stations. Giant PIA.
    prokopto[OP] likes this.
  12. Feb 22, 2021 at 9:52 AM
    prokopto
    Okay, question: Is there a flap or check valve/ gate at the bottom of the filler neck like one would expect as an anti siphon/ theft device? My dad used to call a siphon hose an Arkansas gas credit card. (Just a joke peace to all from Arkansas)
    Yukon DoIt likes this.
  13. Feb 22, 2021 at 1:37 PM
    Markcal
    1 down 1 to go... :thumbsup:
  14. Feb 22, 2021 at 1:50 PM
    camcruiser
    camcruiser Member
    cam
    08 silver taco trd
    did i read that right you had over a quarter and you burned all that up idling how long did this take
  15. Feb 22, 2021 at 2:04 PM
    #35
    prokopto
    I’ll get back to you. You may be onto something I have studied on this all day. Especially the member who suggested the fuel gauge was wrong.
  16. Feb 22, 2021 at 3:49 PM
    #36
    prokopto
    Okay, I have not investigated this theory yet (Plan on pulling the tank tomorrow) but here's what I think happened. Today I put an icemaker water line tube into the tank through the filler neck (to vent it manually) and was only able to put in a little over 1 gallon. Later I was thinking back over the whole two days that I did the stereo swap. (this swap included lots of other mods while I had the dash off like dual usb charging ports in the front and in the back seat).
    1. My drive way is on a grade so I usually back in so rain water will drain out of the bed. This makes the gas needle show less than actual levels in both of my trucks.
    2. My wife corrected me and we actually drove 181 miles the weekend before on that tank of gas. 181 divided by 20 mpg is 9 gallons. I dumped in 5 in the drive way with my gas can and then Friday at the gas station put in just over 5 more. (it was full)
    3. I got in the truck and the needle was still below 1/4 tank with the low fuel light on so I drove across the street to another stations with (and I quote myself) "a gas pump that works!" It was there that I did the clickity click thing and over filled the neck causing fuel to drain back into the evap canister. It was after the second gas station activities that the CEL light came on.
    I think Rick is onto something... the fuel needle may well be stuck and that lying needle caused me to over fill my tank.
    So will my evap canister heal itself and the light go away in time and can I just drop the tank and unstick the fuel sending unit? Any guesses about my hypothesis.
    Bill
  17. Feb 22, 2021 at 4:09 PM
    #37
    Yukon DoIt
    Yukon DoIt Opinionated Northerner
    Paul
    Yukon, Canada
    2006 White Tacoma DCLB 4wd Auto, 1988 Blue 4Runner 4wd Manual
    Stock-y
    I would drive it if it's full. Your needle might be wrong because of something you did behind your dash, I'd investigate that. I would think if you burn some gas and reset the cel that code would go away but maybe not. I haven't searched what happens with that code.
  18. Feb 22, 2021 at 4:12 PM
    #38
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    :ohsnap:
  19. Feb 22, 2021 at 5:08 PM
    #39
    prokopto
    MYSTERY SOLVED: Camcruiser and Rick's 2012 thank you both for asking and/or suggesting the simple obvious things. Thank you to everyone else as well for helping me narrow things down.
    It turned out to be a bonehead move on my part. Down at the kick panel there was a wire into which I spliced for the backup camera and I forgot to plug that harness back in.
    Just now I went out and pulled the kick panel and sure enough I found a harness unplugged and when I plugged it in the fuel gauge began to work. I'll give you three guesses what my fuel level is and the first two don't count! Yep... it is FULL and that's after I drove 30 miles round trip to Sam's to get my Hankook 265/65/r17's today. So I am responsible for the overfilled tank causing the 0453 code.
  20. Feb 22, 2021 at 5:35 PM
    #40
    prokopto
    Will the evap can get better on is own? Should I remove it and try to dry it out?
