Cannot take through car wash
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vijay, May 17, 2015.
  1. May 19, 2015 at 2:16 AM
    #41
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    i take mine thru the auto car wash all the time. tall antenna,
  2. May 19, 2015 at 2:19 AM
    #42
    DrFunker
    DrFunker Well-Known Member
    hand wash on delicate cycle. :D
    :bucket:
    Has this been said already? :rolleyes:
  3. May 19, 2015 at 2:24 AM
    #43
    Truck Yeah
    Truck Yeah OK, maybe just 1 more...
    Maryland
    2013 Silver TRD Sport Access Cab
    Toytec Boss 3" Lift, Dakar Leaf Pack, Light Racing UCAs, ECGS Bushing, 265/70R17 Duratracs, 17 x 9 Fuel Mavericks, Truxedo Low Pro QT, AntennaX 14" Billet, Weathertech Front Mats, Pop and Lock PL5400, OEM Chrome Exhaust Tip, OME Carrier Bearing Drop, OEM Bed Mat, NFab Textured Black Step Bars, OEM Mini Tie Down with Hooks, Tinted Front Windows, Stainless Steel Braided Rear Brake Lines, mattgecko Sliding Window Security Bar, OEM Black Badges, Depo Black Tail Lights, Winco Console Caddy, Turn Key Clamp Anti Theft Tailgate Mod, Devil Horns by Andres Diaz, Kenwood DDX672BH Receiver, Memphis Audio 6x9 Component Speakers in the Front Doors, Memphis Audio 6.5" 2 Way Speakers in the Access Cab Doors, Bazooka 6.5" Bass Tube, Kenwood Excelon XR900 5 Channel Amp, Custom Access Door Speaker Covers, Rokblokz Oversized Mud Flaps, Philips EcoVantage 750 Lumens GY6.35 Reverse Bulbs, ImMrYo Mirror Relocation Bracket, UltraGauge MX, SmittyBilt D Ring Shackle Hitch Receiver, BP Fabrications Front Recovery Bracket with D Ring Shackle Receiver, YotaMafia US Flag Decals, DirtyD510 Custom Weathertech TRD Decals, Plano Storage Full of Recovery Gear, Bed Storage Compartment D Rings, TRD Shift Knob, TRD Oil Cap TRD Radiator Cap, Amp Research Bed Extender, OEM Skid Plate, Rigid SR30 Lightbar in the Lower Valence with Rigid Mounts and a Mictuning Dash Switch, ACEkraut License Plate Relocation Bracket for the OEM Skid Plate, BumperPlugs, Rear Diff Breather Relocation Mod with Uni Breather, Redline Tuning Quicklift Hood Struts, Apex Fog Light Mounts with Cali Raised 18W Amber Pods, nd4spdbh Fog Light Anytime Mod, Wheelers Front Superbump Stops, Uni Breather Smog Air Pump Mod, tsumara Cup Holder, Bullaculla Trailer Plug Relocation Bracket, Salex Glove Box Organizer, Grid-It Center Console Lid Organizer
    I don't think 14" is a shorty. What is stronger and more rigid about it, is where it mounts at the base. We are still talking about antennas, right? Anyway, it seems to come with a longer adapter, but the antenna itself can still flex. It has been durable for me, and looks much better. To each his own.
  4. May 19, 2015 at 4:21 AM
    #44
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Interesting....I go thru Automatic car washes probably once or twice a year (in winter) and I don't do anything to my antennae and I haven't had any issues. My truck is 8 years old....
  5. May 19, 2015 at 4:41 AM
    #45
    Tacoma Mike
    Southern Maine
    I run every car and truck I work on through the car wash. The problem is the antenna not being tight when it breaks. Hand tight is not enough. Use the wrench provided for newer trucks or an open end wrench with older ones and get it tight. If you want to keep it finger tight then take it off before the car wash. The base of the antenna flexes if loose the snaps off the threaded stem. Yes you can get away with a loose antenna once in a while but I can always tell when the stem is bent when I try to pull the loose ones off for the wash. Don't try to bend then stem back. They break instantly.
    Make sure it's tight and you should not have any issues.
  6. May 19, 2015 at 10:39 AM
    #46
    jerzeyjoe
    jerzeyjoe Well-Known Member
    New Jersey
    08 Prerunner 2W
    Never took my antenna off. It's an 08, I got new. No problem.
  7. May 19, 2015 at 11:02 AM
    #47
    T4RFTMFW
    T4RFTMFW Well-Known Member
    The antenna doesn't flex at the base unless it has a spring mount, which it doesn't. The shorter the shaft of the antenna, the more rigid and brittle it is.
    Not a matter of opinion, it's how things work.
    Guarantee you take an OEM length antenna and a shorter antenna and the shorter antenna will snap first, every time.
  8. May 19, 2015 at 12:31 PM
    #48
    mAtTyG04
    mAtTyG04 Well-Known Member
    Edmonton
    2019 Quick Sand OR
    6112 Front Suspension, Fox 2.0 Rear Shocks, Nitto Ridge Grappler - LT285/75R17 C, Rear Blackout Tacoma Badge, De-badged, Icon Rebound Wheels, TRD Grill Gights, CBI Ditch Light Brackets w/ Baja Design Lights, Husky Liners, JBA UCAs, Geenlane Off-road Sliders, Tacotrooper Decal, DuraBump Rear Bump Stops, Pro-clip USA Phone Mount
    Take the ball off. Cut it down to the length you want. Put ball back on. Free stubby!;)
  9. May 19, 2015 at 1:56 PM
    #49
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    I take my truck through washes with the spiny things all the time. I also abuse the antenna with trees. never even thought twice about it. Mind you I don't listen to the radio either so meh
  10. May 19, 2015 at 2:31 PM
    #50
    T4RFTMFW
    I do. All day long. No issues with any OEM antennas I've ever had, the one aftermarket antenna (18") snapped the first time. :pout:
  11. May 19, 2015 at 2:39 PM
    #51
    Huckleberry55
    Huckleberry55 Member
    Leland
    2015 Inferno Orange TRD Tacama PRO
    Black Westin Bull Bar in front, Black Pro Traxx Nerf Bars, Black ERG window visors, Bushwacker fender flairs
    if you read the reviews from the Detroit show. You should be able to look up 2016 Tacoma reviews. Of course that's where I read the info. It wasn't on a Toyota site
  12. May 19, 2015 at 2:43 PM
    #52
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Any particular reason you can't come up with a link? There are many articles on the Detroit Auto Show about the Tacoma, all of them just state that it will be a 3.5L Atkinson Cycle V6 with D4S injection system. Similar to the 2GR-FSE, perhaps you read the HP rating for that and though it was for the Tacoma, there is no stated HP or MPG ratings for the 2016 Taco yet, or there'd be more threads bitching about it.
  13. May 19, 2015 at 2:44 PM
    #53
    Huckleberry55
    Leland
    UGH, I don't understand were you guys haven't read the info on the 2016 Tacoma. Its been uncovered at the Detroit show and the info is out. What part do you think isn't true ? And yes was a antenna wrench in my glovebox. Oh maybe it only comes with a new pro ?
  14. May 19, 2015 at 2:46 PM
    #54
    bzzr2
    bzzr2 Well-Known Member
    this thread is pretty dumb. uh er umm i can't go in da carwash cause duhh antenna duh... hahahahaa
  15. May 19, 2015 at 4:17 PM
    #55
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The part where you claim the new engine will make 305 horses. Provide a link to a reputable source or shut up about it.
    I've also highlighted wrong information regarding the current-gen Taco in your earlier post, quoted below:
  16. May 19, 2015 at 8:30 PM
    #56
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    I use a local car wash just like this. No issues so far and I don't take my antenna off. I think you have to make sure you parked in the center though. ;) You can practice parking in the center with the lines in a parking lot. Most people need more practice at doing this.
    I only use the touchless car washes. The friction car washes rub/beat the dirt off. I'd rather rinse it off. Easier on the paint.
    Biggest hazard to my antenna are the shelves in my garage. They are about an inch too low and the antenna clips them as I pull in and out. It's flexible. Likely takes more beating driving down the interstate.
  17. May 19, 2015 at 8:40 PM
    #57
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    So SpeedyTech straight up called you out asking why you can't provide a link. And your response to bewilderment that he can't find it on his own?
    If it's so easy to find just Copy+Paste the link already. If you're right simply prove it and make everyone else feel dumb already. Unless of course you're making crap up. It's easier to provide the link than keep farting around with indignant posts.
    Car & Driver Magazine has a write up here: http://www.caranddriver.com/news/2016-toyota-tacoma-official-photos-and-info-news
    I'd imagine they'd do everything they can to keep up to date. They said Toyota wasn't ready yet to release specs. Car & Driver said they believe there will be a 40-50hp gain in the 2016 motor (236 + 50 = 286). That's speculation and has no actual substance.
    So where are you getting your 305hp figure besides thin air?
  18. May 19, 2015 at 8:59 PM
    #58
    Leppz
    Leppz Well-Known Member
    Vancouver, BC
    2014 DCLB Sport Premium
    I have the same antenna on my truck. I originally bought mine just so that I could clear my old garage door without slapping my antenna around. I've kept it on since I've moved into a house with an oversized garage. I like the look and as far as i can tell it hasn't affected my reception either.
  19. May 19, 2015 at 8:59 PM
    #59
    Speedytech7
    Lol, I don't think you read my previous posts, that car wash hits my 4ft CB antenna, not my normal antenna. My parking is stellar, I only back in. :rofl: I was telling another member about my shenanigans.
  20. May 19, 2015 at 9:02 PM
    #60
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    LOL Oh okay. Yeah a 4ft CB antenna is a different story. Sorry I missed that one. :(
