Canoe & Foam Blocks Over Roof on DCLB
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChukarBob, Jun 21, 2018.
  1. Jun 22, 2018 at 9:33 AM
    Zoop
    Zoop Well-Known Member
    We do an annual 600 mile (one way) trip up to Canada in an '02 with a Y bar on the hitch, which I see probably wont work for you. If you've got a topper, the foam blocks should be fine being strapped down all the ways you described. Otherwise yeah, looking like you'd want a rack or bars at least. You could build a bed frame to support the back possibly. Interested to see what solution you work out! Good luck!
  2. Jun 22, 2018 at 9:33 AM
    phsycle
    phsycle Well-Known Member
    CA
    Seriously? :rolleyes: What a ridiculous, dishonest, immoral thing to do.
  3. Jun 22, 2018 at 9:35 AM
    phsycle
    CA
    I would also look at bed racks as well. Home Depot sells them.
    https://www.homedepot.com/p/TracRac-TracOne-800-lb-Capacity-Universal-Truck-Rack-27000-01/203346592
    Thule also makes one, but they're expensive. Maybe try Craigslist.
    Also, just as an FYI--you do have a front tow hook, but it's under the front bumper. I'm sure your paint will get scratches from the rope if tied at this point.
    There are products out there that provides other tie off points:
    https://www.amazon.com/Shoreline-Ma...coding=UTF8&psc=1&refRID=VWA541R9ERN2HBTPTKGB
  4. Jun 22, 2018 at 9:51 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    I transport my Swift pack boat 13.6 (cross between a canoe and kayak) with just 4 foam blocks and two cam buckle straps.
    Get them down tight, put a rope from front handle to the tow hook in the front to tie it down for extra long trips.
    Just stop and readjust if it starts to move.
    I noticed no matter how hard I strap it down from how Swift suggest to transport it still shifts if there's enough of a cross wind, in no way like it will come off but enough that its worth adjusting.
  5. Jun 22, 2018 at 11:54 AM
    HoboDave
    David
    Carlsbad, New Mexico
    2023 Toyota Prius
    I used the foam blocks for my kayak and they never moved. Probably because I had the ratchet straps so tight that one of them cut into the hull and left me a nice gash.
  6. Jun 22, 2018 at 12:19 PM
    ZKH
    ZKH Well-Known Member
    northern Kentucky
    2018 TRD-OR DCLB A/T 4x4 BBP Prem+Tech
  7. Jun 24, 2018 at 9:10 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Mines only 12' aluminum, but it doesn't budge. I just use 2 straps & the foam blocks.
    But in your case I'd consider using front & rear straps too.
    TacoLpastor likes this.
  8. Jun 24, 2018 at 9:23 AM
    Jleeb
    Jleeb Well-Known Member
    Vermont
    2017 DCLB OR SUPERwhite.
    Stock
    https://www.amazon.com/ROLA-59742-H...a+bed+rack&dpPl=1&dpID=41X3sSHzigL&ref=plSrch
    300 bucks and feel more secure on your trip home.
    vicali likes this.
