canoe tie down with out a rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by boghobo, Apr 8, 2011.
  1. Apr 8, 2011 at 6:18 AM
    boghobo
    boghobo [OP] New Member
    Upper Bucks county, Pennsylvania
    011 no frills 4x4
    On my old ford truck I used to rest my 12 foot canoe up on a diagonal with the bow resting on the cab and the stern resting on the tailgate (tailgate up). I would put foam pads under the gunnles then strap it down tight. Never had a prob even at high speeds for extended periods.
    With the summer season only a few moons away, I am thinking about doing the same on my new 2011 reg cab Taco, but am hesitant. I bought the extra pair of D ring tie downs and am considering installing them in the front of the bed where the factory recommends but it worries me to put all that torc to the plastic bed. I would also throw some straps to the tie down cleats and maybe if I have enough rope left tie the bow.
    any thought out there on the strength of the d rings mounted where the factory recommends?
    Thanks, Boghobo
  2. Apr 8, 2011 at 6:32 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    You can add extra d-rings up front using the bolts that attach the bed to the frame. These are very strong and you'll have no issues holding that canoe. You could even add the d-rings with the backing plate anywhere in the bed, and I'm sure they will also be strong enough. The composite material is tougher than people think.
  3. Apr 8, 2011 at 7:11 AM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    I have the D-rings in mine and have tied down the wifes motorcycle ( Shadow 750) with no problems at all.
  4. Apr 8, 2011 at 1:03 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    I thinking about what to do too. I wonder if I can just tie into bed with gate open and put a red flag on the end sticking out into traffic.
  5. Apr 8, 2011 at 10:08 PM
    boghobo
    011 no frills 4x4
    Will post pic of tie down on first run down the river!
