Canopies side effects?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDsport253, Feb 13, 2013.
  1. Feb 13, 2013 at 2:51 AM
    TRDsport253
    TRDsport253 [OP] Well-Known Member
    Edgewood, Wa
    2021 TRD sport 4x4
    TRD Wheels TRD Skid plate
    So I've been on market for a Leer Canopy for quite sometime now. Looking to buy used but may go with brand new. With the Cap installed will my truck squat or no change in ride height in the rear? I know these leaf spring are weak as is. Will the leaf springs weaken over time as I plan to leave the cap on for the rest of the life of the truck? Will I see decrease of increase in MPG's? Lastly, am I better off buying a 4runner?
  2. Feb 13, 2013 at 3:04 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    4th Toyota truck & all have had shells.
    Won't effect MPGs, will lower rear (try to get a TSB leaf pack from someone upgrading).
  3. Feb 13, 2013 at 3:06 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    More weight=less MPG, you can remove a cap, your springs are pushing 10yrs old(it won't hurt them), and put weight=to cap and see how much it squats(it will a little).
    Research your purchase well. There are many options out there. I was amazed at the options and accessories out there for the ARE caps. My wallet picked the base model, though. I have no opinion on the Leer, never had/saw one.
  4. Feb 13, 2013 at 3:13 AM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    I've had two Leers on different trucks. Never had an issue with either of them. The rear end will sit slightly lower but not much. The cabs don't weight that much. I've put them on myself on a full sized truck. You may have a slight decrease in MPG but not much. Probably 1mpg less.
    Why ask about a 4Runner? If you want a truck, keep what you have and put a cab on it. If you want an SUV, sell your truck. I personally go for the truck.
  5. Feb 13, 2013 at 3:18 AM
    TRDsport253
    Edgewood, Wa
    2021 TRD sport 4x4
    If I can't find someone selling the 4 leaf TSB pack is there any other options?
  6. Feb 13, 2013 at 3:24 AM
    4Wheelin4Banger
    Randy
    Ever consider lifting it?
    Your suspension is getting old and a good lift will replace it.
    Tacoma Spring refurbishing([​IMG]1 2 3 ... Last Page)
  7. Feb 13, 2013 at 3:29 AM
    TRDsport253
    Edgewood, Wa
    2021 TRD sport 4x4
  8. Feb 13, 2013 at 7:27 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  9. Feb 13, 2013 at 7:48 AM
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    Does it have to be a hard top? I have a bestop and love it.
  10. Feb 13, 2013 at 7:59 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I have a mid-rise cap and saw a slight decrease in MPG in the city but actually do better on MPG's with the cap on the highway. The 2nd Gen leaf springs suck, the cap will squat them even with the TSB leaf springs. I would look into beefing up the suspension if you plan on going with a hard shell (and I would not consider buying a TSB leaf pack off someone beefing up, they are still a weak leaf spring in my opinion).
  11. Feb 13, 2013 at 8:05 AM
    Teniente
    Teniente Well-Known Member
    Carson City, NV/Ensenada, Baja California, MX
    White 2006 SR5 DCSB 4x4
  12. Feb 13, 2013 at 8:17 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Get a aal for the extra weight. The canopy will give you better traction on snow, help with axle wrap issues, lower your chances of ever having your tailgate stolen, keep your gear dry and safe, give more grip on wet surfaces, and help with vibration issues.
  13. Feb 13, 2013 at 8:20 AM
    Pugga
    Massachusetts
    I gotta ask, how does a shell help with axle wrap? If anything, it makes it worse because of the extra weight, it forces the springs to twist more because every time you accelerate, you're trying to move more weight. The AAL will help counter axle wrap but I believe the addition of a shell would have the opposite effect.
  14. Feb 13, 2013 at 8:21 AM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    OP I highly recommend analyzing exactly what it is you envision using the cap for in the future. If you are going to be wanting to haul loads on top then you may want to look into a commercial-grade cap that can haul more. The comcl caps are heavier than standard plus any extra top load weight should also factor into your decision on rear leaf upgrades. I have the Leer 100RCC which is a heavy cap and I also have the TSB rear springs. After about a year with this setup (plus occasional heavy top loads), the springs have squatted about 3/4" and I now have a slight reverse-rake (5100's at 1.75 up front). I'm looking into the springs that OZ suggested to get my ass back up where it belongs.
    Also, since you are planning on leaving the cap on for good, I'd really suggest going for one with a removable front window so you can clean between it and the cab without having to unbolt and move the shell.
    On the MPG side, I may have lost a bit due to the extra weight, but it wasn't enough to be really noticeable. As to the 4-Runner question, I figure if you want a mom-rocket then buy one, but if you want a truck then stay with what you've got. Would you really want to huck cinderblocks, camping firewood or a full gas can in the back of a 4-Runner?
  15. Feb 13, 2013 at 8:36 AM
    OZ-T
    Peter North
    British Columbia
    You can steal the tailgate just as easy unless you have a Pop n Lock
  16. Feb 13, 2013 at 2:03 PM
    OffroadToy
    Thats been my experience... others may vary.
    How can stealing a tailgate be just as easy when you have a shell back window locked over the top of the tailgate? Seems to me it would at least slow them down or go to a easier truck to rip off. I do agree it's still possible though... that's why i did the tailgate theft mods.
  17. Feb 13, 2013 at 2:21 PM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    On my 01, I was a big jump in mpg. I was always city highway driving but it seems like the cap helped on the highway alot. I averaged about 18.5 overall, and 22 on the highway with a 3.4. It was about 1 mpg better overall and 2 on the highway. People say the mythbusters experiment stated that caps decrease mpg. If you watch the video they were testing it on ford long bed trucks with 8 ft beds. I highly doubt that my 5 ft bed experiences the same aerodynamics than the trucks they tested. My .02. Definitely is more weight back there, but it is rare that I don't have an excessive amount of tools and gear with me to really effect my truck weight wise.
  18. Feb 13, 2013 at 2:42 PM
    TANDJMAN
    TANDJMAN Member
    2012 Trail Teams
    I have a Raider Vagabond Elite and I'm not sure what it weighs, but I doubt it could be any more than 200lbs. I don't really notice any difference in MPG's around town, but having the canopy on actually gives me better mileage on the ighway.
