canopy brake and interior lighting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hanrock, Sep 22, 2013.
  1. Sep 22, 2013 at 9:44 PM
    hanrock
    hanrock [OP] Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    hi i need to find out where is the best place to get power for the brake light and interior light for my canopy on my 2012 dc lb 4x4 i'm not to keen on cutting int the harness if i don't have to thanx in advance for any and all help:)
  2. Sep 22, 2013 at 10:04 PM
    joes06tacoma
    Joe
    Central Coast, CA
    As far as I know you have to cut into the harness for brake lights. The only other way would be to wire it to a trailer plug and have the plug always plugged into your trailer receptacle. I tapped into my left tail light harness, the part that stays with the tail light assembly. After I finished splicing, I put silicone into the splice connectors and wrapped the whole deal with 3M tape. I'm confident in it. However, if there was every any problem, that section of harness would be real easy to replace. Plug and play.
    I ran a wire all the way forward into the cab and used a fuse tap for interior light power. Others have said there is constant power at the trailer harness, I have never looked.
  3. Sep 23, 2013 at 6:58 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I just realized that you can't use the trailer plug for brake lights. Although the turn and brake bulbs are separate on the truck, the trailer plug combines them. If you tap the trailer harness, the camper brake light will flash.
  4. Sep 24, 2013 at 5:12 AM
    hanrock
    craig
    sask
    ok thank you
  5. Sep 24, 2013 at 5:52 AM
    acdronin
    acdronin Well-Known Member
    For the canopy light your best option is to run a wire down between the cab and bed, zip tie it to the frame and run it up to the battery with a fuse and solenoid for a switch. You could run a hot wire and put a switch in the bed somewhere or you could run the switch in the cab.
  6. Sep 24, 2013 at 5:56 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    For my canopy light, I tapped the running light wire at my tail lights. That way, the camper shell lights can't be left on accidentally but the downfall is the parking lights have to be on for the shell light to work. For me, it's perfect but if you camp in it, it could get annoying.
    For the brake light, I tapped the brake wire at the tail light as Joe mentioned above.
