Can't access front U joint zerk
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lawrenccar1, May 27, 2016.
  1. May 27, 2016 at 8:31 AM
    lawrenccar1
    lawrenccar1 [OP] Well-Known Member
    Springfield, Virginia
    2015 4x4 DCSB TRD Off-Road
    No matter how i try i cant get grease gun coupler (s) onto zerk do to clearance issue. Is a needle adapter directly into zerk an option ? Seems if the zerk was turned to the side more there would be enough room. Any ideas ?
  2. May 27, 2016 at 8:54 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Its a little tight but it can be done. Try loosing up the grease gun fitting (unscrew a turn or two), put it on the zerk, then tighten it up once its on the zerk. Loosen up on the fitting to get it off.
  3. May 27, 2016 at 9:04 AM
    lawrenccar1
    yes tried that, the coupler goes in on too much of angle to tighten down enough. coupler hits u joint, i am trying to locate a smaller diameter coupler if possible..
  4. May 27, 2016 at 10:13 AM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    I had no problems doing mine the other day, just pick a different angle and have at it
  5. May 27, 2016 at 3:10 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  6. May 27, 2016 at 3:44 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Did mine the other day too. Not easy but gotter done.
  7. May 28, 2016 at 5:48 AM
    lawrenccar1
    thanks i got it. i got a new coupler and worked,, :)
  8. May 28, 2016 at 10:43 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Once you figure out the process it not bad at all.
    But figuring it out the first time is a PITA.
    Pretty sure the neighbors learned some new words my first go around.
