Can't break rear diff bolts.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jbadjones, Apr 28, 2024.
  1. Apr 28, 2024 at 1:08 PM
    Jbadjones
    Jbadjones [OP] Member
    2020 SR5
    Tried to change my rear differential fluid for the first time since owning the truck. Highly doubtful it has ever been done before.
    I cannot get the fill bolt off. Didn't even try the drain bolt, because whats the use if I can't fill it back up?
    I soaked it in wd40. Regular ratchet, breaker bar, cheater pipe, nothing. What's next? Or do I just suck it up and take it to a shop?
  2. Apr 28, 2024 at 1:12 PM
    roboturner
    roboturner Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
    Butane torch, you can pick it up from Home Depot, get it nice and hot and it’ll break free
    lastcall190, usmc2msu and TheWildMan like this.
  3. Apr 28, 2024 at 1:12 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    WD40 is not a good penetrant. Try some PB Blaster or Kroil and let it soak in good.
  4. Apr 28, 2024 at 1:13 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Smart to get the fill off, before the drain, so you're already making great choices.
    Did you try to remove it with the diff warm/hot from driving, or cold? A little heat may help in this case.
  5. Apr 28, 2024 at 1:16 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Take a hammer and whack the plug straight on. Then loosen with a 6 point socket.
  6. Apr 28, 2024 at 1:27 PM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    i am not trying to be a dick but are you sure you are going the right direction?
  7. Apr 28, 2024 at 1:35 PM
    TheWildMan
    TheWildMan Well-Known Member
    3rd Gen 23 Tacoma OR
    Scrubbed some tires, and knocked a dent out.
    Just dont kill it! Seems obvious, but some folks lack sense / experience.
  8. Apr 28, 2024 at 1:39 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    More penetrant. Give it time. Then some heat and a good whack with a steel hammer tip.
    If 100 ft lbs does not do it, then more penetrant and repeat the above the next day.
    Try to break loose the drain at the same time. No need to wait.
    It will give eventually...
    Stevie17 likes this.
  9. Apr 28, 2024 at 2:00 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    Use a chisel and put it on the outer edge of the plug and whack it a couple times with a hammer in the counter clockwise rotation. Guarantee it will work and the procedure often used in shops. A chance you will need a new plug depending on how bad it is, but usually not.
  10. Apr 28, 2024 at 2:22 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    As stated above... WD-40 is not a penetrant, you need a PB Blaster, Break Away, type penetrator. breaker bar, and a 6 point socket, and a quick snap to the bar, counter clockwise. Righty tighty, Lefty loosey. Ski
    wilcam47 and Stevie17 like this.
  11. Apr 28, 2024 at 2:35 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    While not marketed as a "penetrating" oil, it has been shown to perform as well if not better than penetrating oils.
    https://youtu.be/xUEob2oAKVs?si=4TNBUcGxepkDb1BA
    usmc2msu and soggyBottom like this.
  12. Apr 28, 2024 at 2:39 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    6 point socket and a 1/2" breaker bar.
    The shorter the socket the better.
    It will either strip, or it will break loose.
    If it strips, go to an exhaust shop and have them weld on a nut.
    It will come out then.
  13. Apr 28, 2024 at 2:59 PM
    InThePlains
    InThePlains Well-Known Member
    Tap it with a ball peen hammer. Impact wrench going back and forth.
  14. Apr 28, 2024 at 3:51 PM
    OZ TRD
    Central Coast CA
    And - according to the test outcome, for best results, make sure you losen two rusty lug nuts before attempting the diff...
    o_O
  15. Apr 28, 2024 at 4:09 PM
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    I changed the fluids in my '96 last year. Probably the first time in its lifetime. Plugs loosened with effort using a 1/2" socket and 2' breaker bar. I sprayed them with PB Blaster the day before after tapping them a bit and heating them up.
    Much easier than changing an anode rod in a water heater.
    vaca likes this.
  16. Apr 28, 2024 at 5:28 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    WD40 sucks……..it removes sticker residue, but that’s the only use so have for it.
    wilcam47 likes this.
  17. Apr 28, 2024 at 5:38 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I had to use a Milwaukee M18 (500 ft-lb) on my 4Runner's diff plugs. You can also try heating up the plug with a propane torch.
    e6400ultra likes this.
  18. Apr 28, 2024 at 5:52 PM
    Buck Henry
    The WD40 of my 60s and 70s upbringing was some petroleum based bad ass shit! And it was highly flammable! We used to light one can as a blowtorch (using a 2x4 to hold the nozzle down) and place another can in the path of that high velocity flame.
    When it went off, it shot a huge orange mushroom cloud of flame 30 feet in the air. I guess I'm am partially to blame for them changing the formula to be non-flammable years ago. :) I don’t know what they make it with now, but it ain't no where near the same.
    wilcam47 and Dead-Weight like this.
  19. Apr 28, 2024 at 5:57 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Bullshit, it's WD-40, not WD-41.
    :boink:
  20. Apr 28, 2024 at 6:06 PM
    Buck Henry
    Lol, your right about the WD41 part :) but the blow torch story happened. I'm lucky to be alive man.
    Bertw192[QUOTED] likes this.
