Can't Buy Supercharger Oil in California
Discussion in '1st Gen. Tacomas (1995-2004)' started by eon_blue, Sep 28, 2016.
  1. Sep 30, 2016 at 5:40 PM
    #41
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
    thats where he ended up going John, but good tip
  2. Sep 30, 2016 at 5:41 PM
    #42
    1997tacomav6
    Denver
    Great
    eon_blue[OP] likes this.
  3. Sep 30, 2016 at 7:12 PM
    #43
    eon_blue
    eon_blue [OP] If I would, could you
    Azusa, CA
    I just fabbed together a suction device using an infant syringe and some rubber tubing from home depot. Of course, now its dark outside but I'll give it a shot
  4. Sep 30, 2016 at 8:14 PM
    #44
    eon_blue
    Azusa, CA
    So, did the oil "change" on my supercharger just now.....
    I opened up the oil port, inserted the tube with the syringe tightly affixed to the end (no leaks, 100% suction) and drew back....nothing. No oil came out. I figure, maybe I'm not getting it in or down far enough, so I push a little further, same thing. Just some dark, oily residue that smells like ass. So I decide to see what happens if I try putting some new oil in, sure enough I was able to put in almost a full 4oz bottle before I saw it start to trickle out the opening :eek:
    Up until now, the supercharger has been running fine, no abnormal noises that I can tell other than the occasional 'pinging' from a lack of the 7th injector I figured. But damn, anyone with the supercharger be sure to check the oil in it. TRD says its good for 100k but I wouldn't trust that...
    Took her for a test spin and maybe it's all in my head but it seems to run more smoothly, the whine is louder and clearer than it was before. Really hoping there's no internal damage from the low oil level...
  5. Sep 30, 2016 at 8:42 PM
    #45
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    Only damage is the front nose cone bearings and those are an easy replacement. The internals (rotors) of the sc are not part of the oil so no worries there.
    Btw it's 100k for a rebuild but 30k for oil per TRD.
  6. Sep 30, 2016 at 8:53 PM
    #46
    eon_blue
    Azusa, CA
    Good to know, thanks. And that would make a bit more sense then considering I suspect I've got about 30k on my supercharger now.
  7. Sep 30, 2016 at 9:57 PM
    #47
    SCRunner12
    Robert
    Santa Cruz, CA
    Yeah it's a cheap insurance to change every year just to be safe (depending on your annual mileage).
    eon_blue[QUOTED][OP] likes this.
  8. Mar 15, 2025 at 9:16 AM
    #48
    Truckstop13
    Truckstop13 Well-Known Member
    Los Angeles
    1999 Red TRD Off Road SR5 Extra Cab 4X4
    TRD Supercharger, headers, Cold air intake, MagnaFlow exhaust, ARB front bumper, Kennesaw Mtn rear w/ tire mnt, OME suspension with beefed up rear springs with 2 1/2” lift, 285/75/16 tires, Shell, Contractors rack, Road shower and 120v inverter in cab.
    Super old thread, but I was searching for S/C oil and ran into the same issue. Most sites won’t deliver to Cali. My local Chevy dealer wants $35 plus tax per 4oz bottle. I ended up buying from a Euro parts dealer called fcpeuro.com and it was $42 delivered.
