Can't charge phone via USB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dinki, Aug 1, 2017.
  1. Aug 1, 2017 at 1:07 PM
    dinki
    dinki [OP] Member
    13 PreRunner I4
    I've got a Samsung S4 that won't charge when I plug it into the USB port on my '13. I get a message on the screen saying something like 'USB error' or something similar with some additional information (sorry not near the truck to get it exactly). The weird thing is that it doesn't supply any power to the phone. I'm really only wanting to use the USB port to charge the phone as I don't need it as a storage device. My radio is a 57053. Anyone have any ideas on what I need to do to get the USB to charge?
  2. Aug 1, 2017 at 1:09 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    USB's on this generation truck are for data connectivity and NOT charging because they are current limited USB ports. Sad. :(
    Avsfreak18 likes this.
  3. Aug 1, 2017 at 1:14 PM
    Avsfreak18
    Avsfreak18 Now 5% less disappointing
    Robert
    2015 AC
    Yup. I've had installing a capable USB plug on my todo list for over 2 years now...
  4. Aug 1, 2017 at 1:28 PM
    Kotah
    Kotah Well-Known Member
    TN
    2013 silver trd off-road Dc
    Oem running boards Window vent shades Oem bed mat liner
    My usb port on my 13 charges my phones fine
    Stemmy, uwu and TreyStewart like this.
  5. Aug 1, 2017 at 1:29 PM
    Avsfreak18
    Robert
    2015 AC
    What brand and model of phone?
  6. Aug 1, 2017 at 1:31 PM
    klevbot
    klevbot Active Member
    kyle
    2014 BR Tacoma 4x4 baja
    have you tried a different cord? or someone else's phone to eliminate the possibility of a damaged cord etc?
  7. Aug 1, 2017 at 1:41 PM
    Kotah
    TN
    Samsung galaxy note and a iphone 5
  8. Aug 1, 2017 at 1:42 PM
    Kotah
    TN
    Im going to double check i got to run to store ill post back in a little
  9. Aug 1, 2017 at 1:43 PM
    MattScatt28
    MattScatt28 2017 Seattle Mariners AL West Champs!
    Snoqualmie
    So I had a similar problem. I was stupid and replaced my aux and USB port. Expensive like 50 bucks than I cleaned out my USB port on my phone and it was full of crude. I wasted 50 bucks haha. Get some IPA and clean it out worth a try
  10. Aug 1, 2017 at 1:43 PM
    Avsfreak18
    Robert
    2015 AC
    Hm. Interesting. My Note 4 and S7 both kicked back charging errors...
    Toyko Joe likes this.
  11. Aug 1, 2017 at 2:13 PM
    Toyko Joe
    My LG did not charge, neither did my gal's iPhone 5.
  12. Aug 1, 2017 at 2:30 PM
    Bowhuntercoop
    Bowhuntercoop Well-Known Member
    2025 gx550 overtrail. 2025 limited off-road tundra.
    My iPhone 6 charges and wife's iPhone 7 charge in my 13. He'll even my old iPhone 4 charged in the truck.
  13. Aug 1, 2017 at 2:33 PM
    Kotah
    TN
    Yep just checked mine charging like a champ, your not trying to charge it with the ignition off are you it has to be on to get power to the usb port
  14. Aug 1, 2017 at 3:22 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Never had an issue not charging my iPhone and my wife's S3 and S7. Even with my aftermarket headunit, the OEM port charges still.
  15. Aug 1, 2017 at 4:26 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    My '13 charges my iPhone 5S without any issues.
  16. Aug 1, 2017 at 4:51 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Not true in my case. I charge my iPhone on USB all the time, works fine.
  17. Aug 1, 2017 at 4:57 PM
    Holeshot
    Holeshot Well-Known Member
    Gary
    Alabama
    15 Doublecab TRD Off Road 4 X 4
    Don't know why it would matter, but maybe try one of those little 12 v outlet plugs with a USB port on the end and see if that works.
    As mentioned above ignition must be on for port to be energized.
  18. Aug 1, 2017 at 5:20 PM
    will.carroll7
    will.carroll7 Well-Known Member
    2023 DCSB TRD OR 4x4 LR
    The USB port in the truck can provide about 0.5A to your phone. This is not very much for newer phones (which can draw up to 3A). The port in the A truck provides just enough to keep my Pixel from discharging, but doesn't really charge it much. A 12V adapter that plugs into the outlets would charge your phone faster.
    06Tacooo likes this.
  19. Aug 1, 2017 at 8:27 PM
    potstech
    potstech Well-Known Member
    Midlothian, Va
    2013 DCLB
    Icharge my iphone se and my wifes iphone 6 s plus alind with both of our ipad minis from the usb plug on my 2013. No problems.
  20. Aug 1, 2017 at 9:22 PM
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    I've never tried charging via the USB, I have a 12v charger that I use. But, even with it, the tacoma kills power to the outlets when it's not running.
