Can't click in to 4 low
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SLOH, Aug 18, 2009.
  1. Aug 18, 2009 at 3:27 PM
    SLOH
    SLOH [OP] Well-Known Member
    Scott
    Los Angeles
    07 SR5, dc long bed speedway blue
    2.5 Icon c/o's and 3" AllPro rear suspension kit, 17" XD Series Addict w/ 285/70/R17 BFG KM2's, K&N 63 Series CAI, 13.5'' JL Sub (13TW5v2-2) and 500w Rockford Fosgate amp, limo tint all around, cat back banks exhaust with no muffler or tip, blue dash light mod, "taco" 3rd brake light mod, blue dome-light mod, cb radio and 4' firestik antenna, blacked out hoodscoop(thanks randy), Total Chaos UCA's
    does anyone else have this problem, i can use 4 high fine and can get up most hill climbs with it but i've never been able to use 4low, the damn thing just beeps at me the whole time and never clicks in so i put it back to 4 high and yes i've read the manual for it. It just never clicks in.
  2. Aug 18, 2009 at 3:29 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    If you have a manual trans, you must push the clutch in all the way to the floor and have the trans in nuetral.
  3. Aug 18, 2009 at 3:30 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I only tried to get mine in when I first got it and it worked fine. Had it in neutral then clicked it from 4HI to 4LO. Took a few seconds but it got in fine then.
  4. Aug 18, 2009 at 4:20 PM
    wushaw
    wushaw Well-Known Member
    Texas
    08 AC TRD 4x4 6sp
    It's a push button world ya know......it must be better...bs
  5. Aug 18, 2009 at 4:24 PM
    Brunes
    Brunes abides.
    Rotorhead
    Double check it in neutral and light wheel turns right and left...They can be tight/hard to engage at the start for some folks. I've never had any problems with mine.
  6. Aug 18, 2009 at 4:30 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Even with my automatic, i completely stop , put it in neutral, then go from 4 hi to 4low. if it doesnt seem to catch, throw it in reverse usually works. do the same thing to go back to 4hi again.
    I do this on the first of every month on a straight street. put it in 4 hi, drive alittle, stop, put in 4 low, drive alittle, and back again. keeps everything lubed and you'll get used to how it reacts.
  7. Aug 19, 2009 at 7:02 AM
    SLOH
    Scott
    Los Angeles
    alright, thanks for the advice guys, and yeah i have an automatic, the only thing i haven't tried is the reverse thing so i'll try that out later today but yeah i've had it in neutral before and it just keeps beeping
  8. Aug 19, 2009 at 9:20 AM
    buck
    buck Don't sweat the petty - pet the sweaty
    Ontario, Canada
    08 DC V6 4x4 TRD Indigo Ink
    High-flow coconut smiley-face air freshener.
    In manual trans. Tacomas, you have to make sure that the clutch is fully depressed to engage/disengage the transfer case. The clutch start switch must be contacted before the 4x4 ecu will try to engage the transfer case.
    .... unfortunately I have an auto.... and could not solve my problem.
    Truck would go in and out of 4hi fine, but took a while to get into 4lo. And now it is stuck in 4lo. Swapped the actuator and 4x4 ecu from another truck and it still didn't come out.
    It is currently being evaluated at my mechanics. The actuator arm won't budge. Ballz.
  9. Aug 19, 2009 at 9:24 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Sounds like that should be covered under Powertrain warranty.
  10. Aug 19, 2009 at 9:33 AM
    buck
    Ontario, Canada
    which was up 18K ago :(
  11. Aug 19, 2009 at 9:36 AM
    drew02a
    San Antonio, TX
    118K huh, That BLOWS
  12. Aug 19, 2009 at 10:04 AM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    I had nothing but problems trying to get that piece of shit engineering marvel 4Lo to engage and then disengage once it finally did.
    Here is a trick that worked most of the time before I took it in and the Dumb ass dealer which has managed to get it up to about a 50% success/failure rate.
    Clutch all the way to the floor > Turn piece of shit knob to 4Hi then drive a short distance to verify it is in 4Hi > Stop and push clutch all the way to the floor and turn piece of shit knob to 4Lo > Let out clutch and if the piece of shit system is beeping at you, drive a few feet then turn the truck off and pour a cup of coffee, after several minutes restart the truck and you have a chance that it's no longer beeping, if it is still beeping, repeat above steps and try not to dwell on the dumb ass decision you made when you traded in a perfect working Toyota on a new truck.
  13. Aug 19, 2009 at 10:52 AM
    SLOH
    Scott
    Los Angeles
    yeah thanks for all the advice, the longest i've waited for it to click in was 2 minutes, just parked there in neutral and i got sick of the beeping so i said f it, i'm at work right now so i can't try the reverse thing but i'll definitely keep that in the bean. I'm kinda skeptical now if i even want to attempt to click it into 4LO cause i don't need it right now so why play with it. I'd imagine if it's having this much trouble clicking in it might have that much trouble clicking out which would be no bueno
  14. Aug 19, 2009 at 10:55 AM
    drew02a
    San Antonio, TX
    Mine almost never shifts into 4LO on the fist try, but I usually just pull forward a bit and try again. Doesn't usually take more than twice.
  15. Aug 19, 2009 at 4:25 PM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    Mine sometimes/usually takes a few tries to get it into or out of 4 lo. Even switching from 2 hi to 4 hi and vice versa may take more than one try.
