Can't decide on an amp...
Discussion in 'Audio & Video' started by sirsaechao, Apr 14, 2012.
  1. Apr 14, 2012 at 4:10 PM
    sirsaechao
    sirsaechao [OP] Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Gonna rip out the single 12W3 and go with two 13.5TW5's in a custom sealed box in the rear cab...not sure if I should run HD750 or HD1200. The car shop I get all my stuff from he has a crew cab Titan with two 13.5TW5's with a HD750 is that sounds more then enough for the two subs but they are rated at 600w each...thoughts???
  2. Apr 14, 2012 at 7:20 PM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    Just because they are "rated" for 600w does not mean they need it.
    Get the 750 and have a good day.
  3. Apr 14, 2012 at 9:33 PM
    sirsaechao
    Tim
    CA
    Peak 1200 RMS 200-600 each
  4. Apr 15, 2012 at 10:35 PM
    Highspeed
    Highspeed Well-Known Member
    +42° 52' 21.69", -124° 32' 8.50"
    TRD off road
    A.R.E. cap
    Always better to have too much rather than too little. You'll never regret buying the larger amp but you might regret buying the smaller one especially if you can afford the larger.
  5. Apr 16, 2012 at 7:14 AM
    sirsaechao
    Tim
    CA
    It says optimal right around 300ish so I might just get the HD750.
