Can't disconnect ball joint from upper control arm
Discussion in '1st Gen. Tacomas (1995-2004)' started by ToyotaJim, Feb 17, 2018.
  1. Feb 21, 2018 at 6:58 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I didn't even have to hammer or anything the three prong Puller did its job and the UBJ was left intact.
  2. Feb 21, 2018 at 10:50 AM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    Same here. With my 2 jaw puller and a little pb blaster it was very effortless to get it separated. I literally had the joint separated, boot replaced, and back together in less than 15 min.
  3. Feb 21, 2018 at 11:25 AM
    ToyotaJim
    ToyotaJim [OP] Well-Known Member
    Jimmy
    1999 Tacoma SR5
    Yeah I was beating on it like heck and it didn't budge... finally I decided id do some redneck engineering and put a 2 by 4 under the upper control arm and dropped the jack some... it popped right off with one hit from a hammer. I did put my tire and a jack stand under there just in case. May be a little dangerous but it worked for me.
  4. Feb 21, 2018 at 11:34 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Luckily, last time I took mine off, I was replacing the UCAs/BJs with uniballs, so I just :sawzall:
    If you use the 3-arm puller, it helps to take some bailing wire or something and wrap it around the arms and tighten it down. This will (help) prevent the arms from popping off under extreme loads.
  5. Feb 22, 2018 at 3:05 AM
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    It fit for me but that's because I have one that's larger size. I was just showing an example more so of style. I was able to find one a while back that can expand a lot further to fit. I don't remember where from, but yea I was just showing the style.
    The 3 arm puller is easy peasy as well...more than one way to skin a cat
  6. Feb 22, 2018 at 7:32 AM
    tony2018
    tony2018 Well-Known Member
    didn't realize they had a larger one, cool.
    Russianman92[QUOTED] likes this.
