Can't disengage from 4H to 2H
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BirdPerson42, Jun 9, 2020.
  1. Jun 19, 2020 at 5:04 PM
    Tacohumper13
    Tacohumper13 IG @_.mfa_
    Menifee
    2017 TRD Off-road DCSB 4x4
    6112/5160s w/ camburg UCAs 265/70/17 wildpeaks JP8 conversion kit
    It’s the actuator. Bang on it and it will do the trick. Happened to me when I had a 2nd gen....took me about 3 hrs to replace myself
  2. Jun 19, 2020 at 6:20 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I believe he has physically taken the actuator off and verified it works.
    So, the gear very well maybe worn.
  3. Jun 19, 2020 at 6:51 PM
    BirdPerson42
    BirdPerson42 [OP] Member
    2008 Tacoma TRD offroad
    Yes, I've removed, soldered the motor terminals and made sure it still runs. Cleaned the terminals off. And it'll only slide into 4H randomly like it's just barely catching the gear. I'll find out more tomorrow though when I pull it and start checking it out more.
    TnShooter[QUOTED] likes this.
  4. Jun 25, 2020 at 3:46 PM
    BirdPerson42
    So I got a cheep eBay part and replaced the gear. Looked at wiring and everything tests good. I am now noticing that I don't hear my tcase actuator (suction noise) when I try to switch from 2h to 4h the front dif is disengaged. Now I'd try moving my truck around to see if it pops itself into place but someone decided they didn't like where I was parked and slashed a tire. So once that's figured out I'll have an update. But to anyone that doesn't want to get OEM $400 actuator and has an issue other than the soldering on the motor eBay has an actuator for $80 that fits perfect and comes with a new vacuum hose. I tested it as well and it seems (for now) to work properly.
    TXpro4X4 and TnShooter like this.
  5. Jun 25, 2020 at 6:08 PM
    TnShooter
    Deogee
    STOCK
    Thanks for the update.
    Sorry to hear about the tire, I honestly don’t know what is wrong with people anymore?
    Hope you get it working soon. Keep us updated:thumbsup:
  6. Jun 27, 2020 at 11:13 AM
    BirdPerson42
    Issue hopefully solved after I clean it! The tcase actuator had a tiiiiiiny hole in the vacume line. I just popped the actuator open and mud and water. Plus there is sand on the gear of the lever that engages the gears in the actuator transfer case. Hopefully cleaning it out will fix it.
  7. Jun 27, 2020 at 12:12 PM
    BirdPerson42
    So it ended up being a combo of my original issue with the front actuator and my transfer case actuator being corroded/ filled with mud. But it's all good now! The actuators are easier to take apart than I thought. Overall an easy job
    TnShooter likes this.
  8. Jun 27, 2020 at 12:15 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Link if you have it plz
  9. Jun 27, 2020 at 12:20 PM
    BirdPerson42
    https://www.ebay.com/itm/Front-4WD-...5034-for-Toyota-Tacoma-2005-2019/362787132893
    Again the only reason I replaced the front is because it had a stripped gear. It's worth it to pop it open and check for corrosion or the motor contact points being loose. But this part works for now. If it ever fails I'll just put the gear from the eBay one I to my OEM part. And watch out for those pesky vacuum hoses haha
  10. Jun 27, 2020 at 1:17 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Great news! Thanks for letting us all know the solution!
