Can't downshift into 1st gear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bballrules, Jun 8, 2009.
  1. Jun 8, 2009 at 5:07 PM
    bballrules
    bballrules [OP] Member
    Irvine, CA
    09 PreRunner SR5
    Hey guys, I have a question about driving manual. Whenever I try to put it into 1st from like neutral or second, I can never get it in there. There is like a lock or resistance from keeping it getting into 1st gear.
    An example is going to wal mart. It is crowded in the parking lot and my speed is too slow for second gear. I am going around 3 mph in this situation and i always hear my car lug in 2nd gear. What do you guys do when you are rolling at this low speed? i can only get it into 1st gear when i am coming off a complete stop. what should i do when i am in 2nd gear, 10 mph, then the car stops in front of me and starts rolling making my speed drop to 3 mph? my car does not allow me to put it into 1st gear. should i continue to just let it lug in second gear? i wasn't sure because my whole car is shaking so much. thanks!
  2. Jun 8, 2009 at 5:25 PM
    aaronk
    aaronk Well-Known Member
    2009 Dbl Cab V6 TRD
    Shifting in to 1st from a roll in the Tacoma sucks! As you've seen, it just doesn't like it. Don't lug it, what I do is just slow down enough until it lets me shift in to 1st. Most of the time I really don't need to slow down, but it's only for the truck to allow me to get in to gear. Then just keep it in 1st as your roll around the lot.
  3. Jun 8, 2009 at 5:28 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    That is a Tacoma tranny characteristic. 1st is too low to shift into while rolling. You will also find you may have trouble getting into reverse without shifting into first occasionally. Do the 09's have W59's?
  4. Jun 8, 2009 at 6:20 PM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    I can shift into first while rolling no problem. I have to be under 10 mph or so, but I have no trouble at all.
    The reverse thing is just a synchro thing. If it won't go, just ease out the clutch to move just a hair and it'll drop into reverse no problem
  5. Jun 8, 2009 at 6:40 PM
    bigyetti
    bigyetti Well-Known Member
    mike
    asheville, nc
    08 taco dc 4x4 short bed
    sirius satilite radio, more on the way when i get more money. oh ya removed the secondary filter
    As long as im under 10mph im good .[ try double clutching i have to sometimes it might help.
  6. Jun 8, 2009 at 6:41 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I keep forgetting you guys are second genner's. :D
  7. Jun 8, 2009 at 8:14 PM
    bballrules
    Irvine, CA
    09 PreRunner SR5
    hey, i have the 09 too but i cannot get it in there. what do you mean by double clutching? how can i get into first gear from neutral going less than 10 mph? every time i try to push it in there, it won't let me in. should i force it in there? i'm scared because i don't want to ruin anything. thanks!
  8. Jun 8, 2009 at 9:52 PM
    TacoTacoMan
    TacoTacoMan Well-Known Member
    SoCal
    09 AC Prerunner SR5
    Stock
    release ur clutch and engage it again. I don't find I have a problem going from 2nd to 1st at speeds under 10mph. I think it's just something you gotta get used to.
  9. Jun 8, 2009 at 9:58 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    Clutch in and give the truck a little throttle to match approximately what rpm your truck would otherwise be at in 1st gear, it will pop right into gear.
  10. Jun 8, 2009 at 10:07 PM
    bballrules
    Irvine, CA
    09 PreRunner SR5
    so is this right? in neutral, clutch in, rev a little, shift from neutral to first, clutch out/ease gas? i don't get the order above, were you talking about going from 2nd to first or from neutral to first?
  11. Jun 8, 2009 at 10:17 PM
    SC4333
    Grant
    San Antonio, TX
    2nd to first, or neutral to first. Both will work but I find my self going from neutral to first while using this technique more often.
    You have the order correct. neutral, clutch in, rev match to aprox. rpms of gear desired (1st), and then ease the clutch out after it drops into gear. You can apply a light amount of pressure onto the gear shifter in the direction of 1st while rev matching, once you hit the correct RPM the synchronizer will allow the transmission to drop right into first.
    It might take a bit of practice to get everything down, but it works like a charm after you get a hang of things.
  12. Jun 9, 2009 at 1:23 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Hmm, I don't think I have had this issue... I go from 2nd to 1st with no problem.
  13. Jun 9, 2009 at 1:28 AM
    AFButters
    AFButters Rigger, Please!!
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
    I bought an Auto, to avoid these kinda issues.. Just my .02 ..
  14. Jun 9, 2009 at 4:59 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Most people with vagina's do the same thing
    (no offense to the ladies with vagina's)
    JL911 likes this.
  15. Jun 9, 2009 at 7:30 AM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    I'd rather DRIVE my truck than be a passenger.:D
    BTW How's that No Hope Pope thing working out for ya? Enjoying all them army folks?:devil:
  16. Jun 9, 2009 at 6:42 PM
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    I've found that it actually works better if you:
    1) Shift to neutral
    2) Let the clutch OUT
    3) Rev the engine to the approximate RPM you expect to be turning in 1st gear.
    4) Push the clutch in
    5) Shift to 1st (should go in EASY)
    6) Let the clutch out
    It sounds worse than it is... you can do this in a couple of seconds.
    I may be wrong, but I think this works by getting the input shaft in the transmission spinning at close to the same speed as the output shaft so the 1st gear synchro doesn't have to work so hard to do the same thing. Doing it this way you accomplish the same thing as reving the engine with the clutch IN (get the engine RPM's up to where they need to be) and you ALSO get the transmission input shaft spinning faster so the tranny will engage 1st gear easier. 1st gear is really low in these things so the first gear synchro has to work pretty hard to get the input shaft spun up otherwise. If you just push the clutch in and push hard - forcing it into first, you're putting a lot of wear on that synchro. You'll hear it whining as the input shaft spins up.
    This is not necessary when downshifting to other gears - I guess because the ratios are closer together between the other gears (unless you're going from like 5th to 2nd while still going pretty fast - same thing applies then).
    Don't know if I explained that well, but I KNOW it works. Just try it.
  17. Feb 20, 2014 at 1:11 PM
    egres
    egres Well-Known Member
    DELCO PA
    13 singel cab - 2WD - manual - 17K before tax:)
    Bench-seat covers $180 (Can't believe its not leather),Bed Liner $375 (Bed rug), Roof rack $180 (Rhino-rack 2500 Series, plus DK clamps and pads), Modified Bed extender $85 (Extend-A-Truck 944 Truck Bed Extender), Hood lift assist $80 (RedlineTuning), Hood light $53 (tacomaworld.com âtacodaneâ), Hitch receiver $120 (Curt Manufacturing 13323 Class III Receiver), T connector for trailer $43 (CURT Manufacturing 55513 T-Connector), Manuel tailgate lock $30 (gatekeeper tailgate lock), Tailgate assist $28 (Sachs SG329900EZ Lift Support), Tailgate lock $67 (Pop & Lock Tailgate Lock Tailgate Lock PL5301), Spare tire lock $12 (Trimax ST30 Trimaflex Spare Tire Cable Lock), Hardwired battery float charger $20 (Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps) , Vin # Glass etching $33 (vinguard.org), Easy oil drain plug $30 (Fumoto Engine Oil Drain Valve), Floor mats $80 (Husky Liners 2-Piece Front Liner 2-Piece Front Liner), out of space :)
    Men, I have same problem. I have to stop to shift to 1st. gear.
  18. Feb 20, 2014 at 1:16 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    ^^ Correct.
  19. Feb 20, 2014 at 1:35 PM
    egres
    DELCO PA
    Is there a way around it? Is it a manual or electric feature that prevents shifting into 1st?
  20. Feb 20, 2014 at 1:40 PM
    foxhead
    foxhead Well-Known Member
    Andrew
    Bay Area, Ca and Bozeman, Montana for college
    That's what I do and it hasn't failed me yet!
