Cant figure out exactly what gearing i have in my diff, some help would be awesome!
Discussion in '1st Gen. Tacomas (1995-2004)' started by John Cheong, Feb 17, 2012.
  1. Feb 17, 2012 at 8:15 PM
    John Cheong
    John Cheong [OP] Active Member
    East Bay, CA
    2001 SR5 PreRunner
    33" falken rocky mountian A/T, 3.5" fabtech lift, Deck plate mod, Painted badges.
    ok i have a 2001 tacoma TRD prerunner with an electric locking diff. the axle code is B03A. ive been looking around and ive come up with a bunch of different answers...4.10,4.56, 3.55. i have no idea for what the gearing is with the e-locker. lemme get your advice!:D
  2. Mar 11, 2012 at 1:42 PM
    tacopyro
    tacopyro Forever learning...
    SoCal
    01 Taco Pre SR5 V6 - 4WD
    Roll n Lock Cover and Stainless Step sides. New Mods. AFE Air Filter, PS Mag-Filter, Bilstein HD rear and 5100s Front. Michelins LTX MS2. Taurus E-Fan with FK50. Tundra Brake Upgrade. External Tranny Cooler. HO-Alt CS144 Mod, OMD Leaf Springs. Bull Bar. 4WD VF3AM Transfer Case, ADD/Manual Hubs. 4wd conversion complete Future Mods. rear sway bar, box the rear frame. I Love my Taco!
    i only have a possible answer to your gear ratio. i have the same diff code. and i think its a 4.1
    check this link: http://goo.gl/qbiuO
    CK
  3. Mar 11, 2012 at 1:53 PM
    valon5150
    valon5150 Well-Known Member
    Steven
    redding
    01 taco turd
    all pro lift, 33s, home made sliders, bumpers, skids
    More then likely 4.10
  4. Mar 11, 2012 at 2:01 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Same as mine B03A. 4:10 gears
  5. Mar 12, 2012 at 6:52 AM
    wesrunner
    wesrunner Team 4Runner
    Wes
    Louisiana
    It's paid for.
    1999 T4R 4WD V6, Deck plate, B&M trans cooler, LED guages and dome lights, LED reverse lights, 2.5" spacer lift, highway tires.
    Me too! :D
  6. Mar 13, 2012 at 6:20 PM
    tacopyro
    SoCal
  7. Mar 13, 2012 at 6:43 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    There arent any factory e-lockers with 4.56. So you can eliminate that possibility.
  8. Mar 13, 2012 at 7:29 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    A = 7.5" ring gear
    B = 8" ring gear
    Next two digits:
    01 = 3:42
    02 = 3:58
    03 = 4:10
    04 = 4:56
    05 = 3:15
    06 = 3:91
    07 = 4.30
    Last digit:
    A = 2 Pinion, Open
    B = 4 Pinion, Open
    C = 2 Pinion OEM Limited Slip
  9. Mar 14, 2012 at 10:29 AM
    iDrew
    iDrew I spend too much on vehicles...
    Andrew
    Edmond, OK
    '16 TRD Off-Road DCSB
    STOCK AF
    Looks like I have myself some factory 4.56 gears. Is that a good thing?
  10. Mar 14, 2012 at 11:24 AM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    I think most, if not all, 4cyl autos had 4.56. Something to do with the automatic having taller gears than the manual. :confused: Something like that. So basically if we had 4.10 or 3.xx whatever we would be revving way to high at highway speeds. But dont quote me. haha
  11. Mar 18, 2012 at 6:19 AM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    You would be revving way lower and have no power. 3.73 or so would save you gas but the truck would be a dog.
  12. Mar 18, 2012 at 8:43 AM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    I said dont quote me. hahaha
  13. Mar 18, 2012 at 8:52 AM
    RAT PRODUCTS
    Farmington, MN
    Just adding to your driveretain knowledge.
  14. Mar 18, 2012 at 7:04 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    haha
    I knew the reason for the 4cyl autos have 4.56 was something like that.
    Ill put it in the brain for later use. haha
