Can't figure this hick-up out.
Discussion in '1st Gen. Tacomas (1995-2004)' started by PapaD, Jul 25, 2011.
  1. Sep 15, 2015 at 2:49 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Pretty cool. I want to go try this
  2. Apr 18, 2016 at 5:40 AM
    REV04
    REV04 New Member
    Robin
    Occasional throttle lag in maintaining speeds, (when on off throttle coasting). Six months Mechanic trying to diagnose problems, only happened twice when he drove it. Changed all coils, spark plugs wires and fuel filter. 2004 Toyota Tacoma with 225207 miles on it.
    I have same problem with my 2004 Toyota Tacoma 200,000 + miles.
    Cutting out around 1500 to 2500 rpm, pump gas pedal a few times. It's super scary when in the fast lane on Turnpike. Loose all power.
    Doesn't do it all the time, off and on for 6 months, and only did it twice for Mechanic.
    He explains it as "falling on its face".
    I do my own oil changes every 4000. Miles. Trimming belt replaced at 1500.000 miles.
    Since November Mechanic changed fuel filter, spark plugs, wires, coils and unrelated water pump hoses and serpentine belt.
    Problem still persist.
    I read every word on this site and I'm going to get sea foam on way home and do the 100 pump on the pedal.
    Thank you I have new Hope
  3. Apr 18, 2016 at 2:11 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Seafoam is garbage compared to other fuel cleaners. If you really want to clean the shit out of stuff, get a bottle of B12 Chemtool or Techron concentrate. I usually use a dose every oil change.
    Also, not sure the "100 pump" trick will work since you are Throttle By Wire.
  4. Apr 26, 2016 at 1:48 PM
    DSGB
    DSGB Member
    Columbus, GA
    03 SR5 Double Cab 4WD
    Rough Country 2.5" suspension lift, Line-X bedliner, chrome nerf bars, DVD player, leather interior
    My '03 DC started doing what is described in this thread last summer. It was intermittent and aggravating! Well, it started doing it again a couple weeks ago. Usually just a slight hesitation when accelerating from a stop and sometimes when cruising at lower RPMs. I ran across this thread and tried it last week. No problems so far!
    Thanks DblCabMN!
  5. May 4, 2016 at 8:32 PM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    Nice to hear it helped! If i recall correctly, eventually my problem came back. Found a guy parting out his engine and bought the upper plenum and throttlebody w/tps from him for a crazy low price. Has been solid ever since. IIRC the replacement for the 03/04's requires the whole TB to be replaced at like $700. So, keep an eye out for a deal :)
  6. Aug 8, 2016 at 1:01 PM
    Jclow801
    Jclow801 Active Member
    Justin
    2013 Pyrite Mica TRD OR DCSB
    IVD Stage 2, CVT Mt Rainier Pioneer
    jesus, were you able to find a solution to your problem? I'm experiencing a similar issue, and also have an 02.
  7. Jul 7, 2017 at 8:22 AM
    04doublecablimi
    04doublecablimi Member
    OMG! I owe someone some beer! My truck has been hesitating and it was driving me crazy. Here's a Post I highjacked about it: https://www.tacomaworld.com/threads/2003-tacoma-hesitates-while-driving.435305/#post-15540577
    I had replaced fuel filter, spark plugs and wires, most of the hoses, replaced PVC, cleaned MAF sensor. Never suspected the TPS. Just did the gas pedal pump yesterday and so far no hesitation (I have only been driving it today).
    Thank you, thank you, thank you! This should be re-written as a sticky somewhere!
    cruiserguy likes this.
  8. Apr 18, 2019 at 6:32 PM
    NavMar
    NavMar New Member
    2003 Tacoma 4x4 TRD
    DblCabMN you are awesome!!! I replaced or cleaned all the usual suspects except fuel pump .New plugs, wires, O2 sensors, gas cap, cleaned EGR, gas inlet and inspected, MAF, PCV, fuel cleaners/additives, even new exhaust, but THIS seems to have worked!!!
  9. Apr 19, 2019 at 10:29 AM
    Zerofear66
    Zerofear66 Well-Known Member
    2022 TRD Off Road Lunar Rock, 2014 Tundra Crew Max TRD 5.7L
    Will this work on 02 Tacoma 3.4?
  10. Apr 19, 2019 at 11:24 AM
    GoJo
    GoJo Well-Known Member
    Utah
    I have done it on my 03 - 3.4 and it worked for my issue
  11. Sep 5, 2019 at 12:14 PM
    jimgraham1973
    jimgraham1973 New Member
    Jim
    2003 Toyota Tacoma
    I completed the 100 pedal and it worked for my issue on my 03 3.4 perfectly! Thanks for posting!!!!
    TashcomerTexas and GoJo like this.
  12. Sep 5, 2019 at 1:34 PM
    TashcomerTexas
    That’s interesting. I still need to try this
    jimgraham1973[QUOTED] likes this.
  13. Apr 4, 2023 at 1:15 PM
    Bluecord
    Bluecord Well-Known Member
    Jeff
    Louisiana
    2003 Tacoma 4x4 TRD Lunar Mist Metallic
    Old thread, but I've done this twice on my 2003 3.4 probably 3-4 years apart. Worked both times, but is there a way to take apart and clean the TPS thoroughly so that this problem doesn't come back?
  14. Apr 4, 2023 at 1:37 PM
    GoJo
    Utah
    Not that I am aware of, the pedal pushing repeatedly is essentially that cleaning method. I do it probably twice a year at most, when I start to notice any issues coming back I just sit in the drive way one day upon getting home and pump the pedal 100ish times and call it good. Has worked ever since I discovered this thread.
