Can't figure this out. Going crazy
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dr. Emmett Brown, Sep 16, 2019.
  1. Sep 16, 2019 at 8:20 PM
    Dr. Emmett Brown
    Dr. Emmett Brown [OP] Well-Known Member
    Noise doesn't sound like it's coming from rear of truck like everyone keeps saying it's the rear diff howl.
    It sounds like it's coming from the front driver side.
    Sounds worst going downhill cruising and turning.
    Not really grinding noise but I can feel some minor vibrations constantly.
    Happens mostly at 50-60mph. Lifted front and rear 2.5".
    I've had driveline vibrations at 9mph while accelerating ever since I put on DAKAR HD pack. I have 3* shims and carrier bearing drop with no success. Might take off both adjustments and see if vibes go away. I put the shims on when I put the leaf pack in as a precaution but it sounds like the leaf packs lready come with the center pin hole slightly adjusted for the drive shaft re-correction angle.
    Not sure if possibly a bad pinion bearing due to the driveline vibes??
    TRD Sport short bed 4wd.
  2. Sep 16, 2019 at 8:24 PM
    tcjacado
    tcjacado Well-Known Member
    How are the pads and rotors looking? Caliper possibly sticking?
  3. Sep 16, 2019 at 8:25 PM
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    Does is go away if you switch to 4WD?
  4. Sep 16, 2019 at 8:26 PM
    Dr. Emmett Brown
    Been holding off on that mostly because my symptoms didn't quite match the description of every one else's but might be looking into that very soon.
    Mo86 likes this.
  5. Sep 16, 2019 at 8:26 PM
    Dr. Emmett Brown
    When I jack up the front and spin the wheels they seem to rotate fine.
    tcjacado[QUOTED] likes this.
  6. Sep 16, 2019 at 8:26 PM
    Dr. Emmett Brown
    Nope. Still the same.
  7. Sep 16, 2019 at 8:27 PM
    tcjacado
    CV joint on the axle maybe?
  8. Sep 16, 2019 at 8:27 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Perhaps you can take the truck to a quality mechanic.....
    Joe23 likes this.
  9. Sep 16, 2019 at 8:28 PM
    Dr. Emmett Brown
    My truck is still well under warranty so the dealer will be the first option.
    tcjacado likes this.
  10. Sep 16, 2019 at 8:28 PM
    tcjacado
    Only servco in Hawaii and they don't have the greatest reputation.
    Hobbs[QUOTED] likes this.
  11. Sep 16, 2019 at 8:28 PM
    Dr. Emmett Brown
    The one I live right next to hasn't ever given me problems but I guess we will see
  12. Sep 16, 2019 at 8:29 PM
    Dr. Emmett Brown
    Appreciate that. Wish it drove as nice as it looks though. Haha.
    BlazinBlueTaco likes this.
  13. Sep 16, 2019 at 8:31 PM
    tcjacado
    Whatever it is, its rotational, correct... think of everything that's involved in rotation. Maybe a wheel bearing starting to go out. Since is doing under load while turning.
  14. Sep 16, 2019 at 8:32 PM
    Dr. Emmett Brown
    That's what I keep thinking and leaning towards but I just don't get how a wheel bearing can go out on a truck with only 20k miles on it and rims that are 0 offset which seems even better on the hubs than stock configuration?! :annoyed:
  15. Sep 16, 2019 at 8:33 PM
    Dr. Emmett Brown
    I haven't seen anyone with a negative review of the bushing swap so I might just do it and get it over with.
  16. Sep 16, 2019 at 8:34 PM
    tcjacado
    These 3rd gens are very temperamental with any change. I just got my truck fixed in the front... no more squeaks or chunks.
  17. Sep 16, 2019 at 8:34 PM
    Dr. Emmett Brown
    And now the OCD kicks in because I hear all similar noises every where I go! The AC in the building I'm in right now makes a howling noise. Haha
  18. Sep 16, 2019 at 8:37 PM
    tcjacado
    Fixed the rack and pinion (new one), changed pads and rotors, and put in new shocks.
  19. Sep 16, 2019 at 8:40 PM
    Dr. Emmett Brown
    Yup me too
  20. Sep 16, 2019 at 8:42 PM
    tcjacado
    I haven't notice this with my ac... although it has broken twice. Just had it in for the blower recall.... hopefully it won't happen again.
