Can't figure this out!! I will GIVE 50$ to who ever can help me out!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AMartin, Sep 7, 2016.
  1. Sep 7, 2016 at 5:39 PM
    #41
    cc350
    cc350 Retired Member
    Mine did the same thing. It was a bad drivers side caliber.
  2. Sep 7, 2016 at 5:39 PM
    #42
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Did the carrier being get changed? I had one go years ago. It was hard as he'll pin Ponting that bad vibration.
  3. Sep 7, 2016 at 5:39 PM
    #43
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Too easy. Do you have the factory roof racks installed? I suspect yes. Take some swim noodles and cut them too size to fit over the rails. Zip tie them in place and go for a ride to see if the noise is gone. PM me on how I can collect the $50.
  4. Sep 7, 2016 at 5:41 PM
    #44
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Good way to explode a tire. They should not be run up to speed with no weight on them
  5. Sep 7, 2016 at 5:52 PM
    #45
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Sounds like you have done all the right things to eliminate potential sources. Check and torque every fastener associated with the drive train and suspension. Leaf u bolts, carrier bolts, cross member bolts, etc. There is a torque thread here on TW. Are you getting any unusual tire wear?
    bornruffian likes this.
  6. Sep 7, 2016 at 6:01 PM
    #46
    AMartin
    AMartin [OP] Well-Known Member
    Andre
    New Brunswick
    2009 TRD sport DCLB
    3" Bilstain lift, Anytime Fog, Skid Plate, Procomp 7036, Cooper STmaxx, Heated Seats, Interior Plugs.
    I know right!! My couper STmaxx have almost 20 000km and the wear could not be better.
    Thanks for the reply.
  7. Sep 7, 2016 at 6:10 PM
    #47
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I'll give you $50 to not start a thread saying you'll pay someone $50 if they help you :annoyed:
  8. Sep 7, 2016 at 6:15 PM
    #48
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Any wheeling damage? Bent rear axle shaft?
  9. Sep 7, 2016 at 6:43 PM
    #49
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
  10. Sep 7, 2016 at 6:50 PM
    #50
    AMartin
    Andre
    New Brunswick
    2009 TRD sport DCLB
    I don't wheel the truck, never seen worst then dirt roads, not hard on the truck at all either.
  11. Sep 7, 2016 at 8:42 PM
    #51
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Do you have the factory roof racks?
  12. Sep 7, 2016 at 8:44 PM
    #52
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    what could go wrong...;)
  13. Sep 8, 2016 at 3:44 AM
    #53
    AMartin
    Andre
    New Brunswick
    2009 TRD sport DCLB
    I don't have a roof rack lol.
  14. Sep 8, 2016 at 4:09 AM
    #54
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Just throwing this out there, but aggressive tires can just straight up cause vibrations. I had none on stock tires and then switched to some mud terrains and my passenger seat looks like there was an earthquake going on when I got above 65MPH. Now? Everything I have probably causes vibrations, bad aerodynamics/aggressive tires/aftermarket suspension/curvature of the earth/lack of 50$/vegans complaining/bad wheel bearing/soon to be solid motor mounts/etc etc etc
  15. Sep 8, 2016 at 4:22 AM
    #55
    ecotecin
    ecotecin Wait, whut........
    WV
    2014 DCSB sold (2020 Chevy Silverado Crew Cab)
    I know this sounds tupid but check your tailgate. My brother had a ford that would get a vibration so bad it felt like it was going to just make the truck fall apart, one day we had gotten some gravel and after we were done we left the tailgate down and drove it up the road to take it to the car wash and there was no vibration. So to check it, we put it back up, and drove back down the road, it was back, put it down drove back up the road and it was gone. Looked closely and one side was bent about a quarter of an inch out, and i guess that was enough to cause the wind aerodynamics to go crazy. Only done it at certain speeds as well. Best of luck to you!!!!
  16. Sep 8, 2016 at 4:26 AM
    #56
    AMartin
    Andre
    New Brunswick
    2009 TRD sport DCLB
    First thing I did wen it started is put back on my stock wheels with summer tires, didn't change anything. Thanks.
  17. Sep 8, 2016 at 4:28 AM
    #57
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    I'd check the calipers again...for sticking.
    New or not.
  18. Sep 8, 2016 at 4:38 AM
    #58
    AMartin
    Andre
    New Brunswick
    2009 TRD sport DCLB
    I will have a look at it, and going to try tapping the brakes while it vibrates see if it changes anything.
  19. Sep 8, 2016 at 4:48 AM
    #59
    gearcruncher
    Canadain bumper technician
    Tapping the brakes at highway speeds will also turn your torque converter clutch off for a brief moment . If the vibe goes away when you manipulate the brake switch you have an engine misfire or your converter clutch is chattering .
    If your vibration is as violent as you describe at 110 -120 kph and you have narrowed it down to a vibration that is faster than wheel speed , there is only the driveshaft that spins faster than your wheels .
    With this said , I am leaning toward a drive-line issue or drive line shimmy
  20. Sep 8, 2016 at 8:14 AM
    #60
    AMartin
    Andre
    New Brunswick
    2009 TRD sport DCLB
    I will be testing that on the highway as soon as I have the chance. Definitely faster then a tire vibration. It pretty much can't be the rear drive shaft though, because I had it off and went for a test drive in 4HI and the vibration was the exact same.
    Im am going to jack the 4 wheels off the ground and ride it in 4HI to 120km/h or so and see if it vibrates.
