Can't find build for 2014 fogs
Discussion in 'Lighting' started by Vandy321, Jan 23, 2021.
  1. Jan 23, 2021 at 11:16 AM
    Vandy321
    Vandy321 [OP] Well-Known Member
    CO
    2014 DCLB
    Just looking to replace my stock bulbs in the fogs. Going to pick up a set of Nokya Hyper Yellows, whatever bulb won't burn up in the stock harness. Is it an H10 or H11 for the 2014?
  2. Jan 24, 2021 at 7:13 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    An H11 came in them from the factory. Truth be told though, you're not going to get much of a bump in performance from a higher wattage bulb swap unless you upgrade the harness. And in case you're wondering, a drop in LED bulb - although it will draw less power - will not significantly improve your performance either. It will however run the risk of bothering oncoming drivers with increased glare. The biggest bang for your buck is to replace the entire housing with an LED pod. Here's the complete run down on the best candidates:
    The LED SAE J583 Fog Pod & Fog Light Review | Tacoma World
  3. Jan 24, 2021 at 7:19 AM
    Vandy321
    CO
    2014 DCLB
    Thanks for the info. Yeah, I read a few threads on swapping everything, harness included, not really that appealing to me for the $.
    i've just got 1 factory bulb thats out. Just needed a replacement figured I'd grab a yellow bulb over the white. $20 for a Hella or Nokya seemed about right.
    H11 it is, I found them in the stock 42w if that is the better option then a 55w burning things up.
  4. Jan 24, 2021 at 7:28 AM
    Too Stroked
    Tom
    42 watt bulbs should draw 3.5 amps each for a total of 7 amps. 55 watt bulbs should draw 4.6 amps each for a total of 9.2 amps. I don't think that will burn up your factory harness.
    Vandy321[QUOTED][OP] likes this.
