Can't find spicer u joints!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vpcustoms, Sep 29, 2015.
  1. Sep 29, 2015 at 1:01 PM
    vpcustoms
    vpcustoms [OP] Well-Known Member
    2017 Double Cab 4X4 TRD Sport
    I need to replace my u joints and would like to go with spicers but can not find them anywhere. Called 4wheelparts and guy said they don't show part number for my 06 dc 4X4. Dealer wants $80 a piece!! Wtf? Any help would be appreciated. Thanks
  2. Sep 29, 2015 at 3:17 PM
    SoCal Hillbilly
    SoCal Hillbilly Well-Known Member
    Eric
    San Diego
    2013 DCSB
    Call Spicer and get the correct part numbers. Be sure to have the part number off your drive shaft. Then call San Diego Friction products. I got a carrier bearing for $80 ($280 at dealer) and u-joints for $20 each ($100 at dealer).
    http://spicerparts.com/
    http://sandiegofriction.com/
    PzTank, Tarzan13 and DoorDing like this.
  3. Sep 29, 2015 at 5:22 PM
    vpcustoms
    Called spicer today but they were closed. I will try back in the morning. How hard was it to change your carrier bearing. I guess I should do it while I have the drive shaft off. Thanks for the reply man.
  4. Sep 29, 2015 at 5:29 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Definitely do the CB while you have the shaft off.
    FYI the u joints on my 4x4 rear shaft are
    1.063 X 1.063 Inch bearing caps
    3.620 X 3.620 bodies.
    should be able to pruze spicers site n figure out the parts you need
  5. Sep 29, 2015 at 5:40 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    Get the u joints on Amazon.
    5-153x for the front two at 17 a piece, and 5-1330-1x for the rears at 25 and change a piece. They fit even if amazon says they don't.
    There are some threads somewhere on here that have all the u joint part numbers, but the info is scattered.
    How many miles are on yours? If you grease them semi regularly and don't keep them submerged they will last a long time. My back ones have 112k. I changed the fronts because the skids would make it a pain to do trail repairs on them, but they were kept as spares as they are still tight.
    SR-71A likes this.
  6. Sep 29, 2015 at 6:05 PM
    SoCal Hillbilly
    Eric
    San Diego
    2013 DCSB
    I would, its easy. Just need a puller and good vise to hold everything. When you call spicer get the yoke nut. Its should be replaced when you take off the old one.
    This video helped me. https://www.youtube.com/watch?v=JurluoSxJHI
    MTopp likes this.
  7. Sep 30, 2015 at 8:18 PM
    vpcustoms
    Thanks all for the quick replies. Talked to a guy at spicer and after giving him the number off of my driveshaft like SoCal Hillbilly suggested he gave me a part number (5-1330-1x) and I will be ordering from Amazon today. This site is hands down a life saver. Thanks again.
  8. Sep 30, 2015 at 8:21 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    are these spicer u joints suppose to be top of the line?
  9. Sep 30, 2015 at 8:28 PM
    vpcustoms
    I have done some research and as far as I can tell these are what the truck came with. I am replacing all 3 on my driveshaft at 128,000 miles. If you try to get these from the dealer they are $80 a piece. $25 on Amazon like Hartford mentioned.
  10. Sep 30, 2015 at 9:04 PM
    ramonortiz55
    Ramon
    Texas
    stock
    so theyre like OEM ujoints?
  11. Oct 1, 2015 at 3:21 AM
    vpcustoms
    Correct
  12. Oct 1, 2015 at 4:21 AM
    gearcruncher
    Canadain bumper technician
    Some of you guys dont have any grease Zerks . If I was ordering a factory universal joint from the aftermarket , try and be sure you get Zerks for your new u-joints .
    Read what Spicer has to say about greasing your driveline
    http://www2.dana.com/pdf/J3299-2-DSSP.PDF
    MTopp, PzTank and SR-71A like this.
  13. Oct 1, 2015 at 6:49 PM
    Hartford
    Maine
    2011 Acc Cab 5spd
    What about your front drive shaft? Might as well do that one too.
  14. Oct 2, 2015 at 8:19 AM
    SoCal Hillbilly
    Eric
    San Diego
    2013 DCSB
    I went with non-grease able ujoints this time, just tired of dealing with it. I havent had much issue in the past.
    Its interesting how Toyota says service your drive line every 30k but spicers says 5k.
  15. Oct 2, 2015 at 11:58 AM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    Spicer 5-1330-1X is pretty much the same as the factory U-joint with grease zerks on the cap and all.
    Rock Auto carries it too but you won't see it listed under the Tacoma. You can find it if you search manually or lookup a Ford truck. I don't know why automotive application guides don't show it listed for 2nd gen Tacomas
  16. Jun 9, 2017 at 6:32 PM
    iambluetaco
    iambluetaco Active Member
    Nelson
    08 trd 4 dr
    Hi im reviving this thread in the sakes of fixing my vibration issues at 103k mi , started with a squeal or chirp it stopped but vibrations are still there under throttle only, im pretty sure its my center carrier support ive founf it to be RPC Part SPICER 5002334 but i want to change our my ujoint while in the process therefore i just need some clarification as to how many. is Spicer 5153x QTY 2 front shaft required and Spicer 51330-1x QTY 3 rear shaft required . os that correct. also is my center bearing correct?
    thanks
  17. Sep 1, 2017 at 5:37 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  18. Mar 27, 2018 at 10:54 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Bump for old thread. Does anyone have the Spicer yoke nut and the bearing ?
  19. Apr 11, 2018 at 12:45 PM
    jtbow
    jtbow Member
    Fairbanks, AK
    2020 TRD Pro
    Prinsu Cab rack, Smartcap
    Reddawn, Are you looking for the flange yoke or do you mean the carrier bearing and the nut that holds it down?
  20. Jun 25, 2019 at 10:29 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
