Can't Find Squealing Sound
Discussion in '1st Gen. Tacomas (1995-2004)' started by goldtaco1, Apr 16, 2025.
  1. Apr 16, 2025 at 10:32 PM
    goldtaco1
    goldtaco1 [OP] Member
    Zach
    2001 Tacoma, 4x4
    About a month ago my truck started making a squealing noise on startup but would go away after a couple seconds. The sound comes back when i'm driving slow, reversing or holding a turn. I replaced all of my belts and tensioners along with cleaned my steering res and installed a brand new steering pump. Just installed brand new wheel bearings as well. I can't figure out where the sound is coming from and would love some help. It is an extrmely loud and high pitched sound you can hear from far away.
    Any ideas?
  2. Apr 17, 2025 at 1:09 AM
    mit88
    mit88 Well-Known Member
    Planet earth
    Check your engine harmonic balancer to see if the rubber on it is damaged. Good luck!
  3. Apr 17, 2025 at 8:02 AM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    maybe the tension on the belts are a bit loose. Tighten them up a little.
    rocknbil likes this.
  4. Apr 17, 2025 at 8:48 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    I had this and it appears to be common. Slightly tighten up the alternator belt a little at a time. Be sure to loosen the lock bolt (big one up front) before tightening the tensioner (under the alternator.)
    <TL;DR>
    This drove me nuts for months. Replaced belt. Still happened. New belts. Still there. Presumed it was coming from the bearing, replaced alternator. Still there. I tightened the belts manually to spec, thought I had it right. Began tightening the alternator belt down, little by little. It's been gone for over a year.
    Edit: if the squealing doesn't start to decrease at some point, it's something else, don't blow out your alternator bearing going too tight. Mine was particularly annoying, I wouldn't hear from it for months but when winter came it was reliably squeaky on startup so I managed to figure it out.
  5. Apr 19, 2025 at 9:53 AM
    goldtaco1
    Zach
    2001 Tacoma, 4x4
    I'll give this a try, that makes the most sense to me. I've spent so much money replacing everything I thought it was that I've practically built myself a new truck
    Black97v6MT likes this.
  6. Apr 25, 2025 at 4:50 PM
    goldtaco1
    Zach
    2001 Tacoma, 4x4
    Update: after tensioning and replacing the belts, tensioners and idlers, steering pump, and wheel bearings, I gave up and took it to a shop. Their diagnosis you might ask? BUILT UP BRAKE DUST! hasn't made the sound since cleaning off the rotors. As embarrassing as it is to say that, at least I've now replaced most of the major wear parts on the truck
    Black97v6MT and Moonrman like this.
  7. Apr 25, 2025 at 5:57 PM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    Ahhhh, the old brake dust - shotgun parts strategy. Well it's all refreshed!
  8. Apr 26, 2025 at 7:28 AM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    do you have any pics of this BUILT UP BRAKE DUST that would make such a squeal upon startup and not even moving?
    that i gotta see...
    JustADriver and rocknbil like this.
  9. Apr 27, 2025 at 2:55 PM
    rocknbil
    Bill
    Agreed, inquiring minds want to know . . . how brake dust will affect a stationary truck. It would make sense if it's rolling but you said on startup. This is why I have trust issues with mechanics, maybe that's just what they told you. In a way it's like replacing transmission fluid makes your air conditioner work again. :D
  10. Apr 27, 2025 at 3:00 PM
    goldtaco1
    Zach
    2001 Tacoma, 4x4
    I probably should've clarified, my alternator was making the sounds on startup so i fixed that prior to taking it into the shop.
    rocknbil, JustADriver and Black97v6MT like this.
