can't find the output wire of the brake switch
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Burk2.0, Jan 24, 2024.
  1. Jan 24, 2024 at 2:16 AM
    Burk2.0
    Burk2.0 [OP] New Member
    2022 white tacoma sr 2x4 2.7L
    full towing package, fog lights, bed cover, roof rack, step bars
    this type of thread has been around before, but my situation is different. I have the 2022 2.7L sr base model with the SR5 upgrade but still an SR. no frills and does its job quite nicely. I just bought a 2024 camper I want to pull behind it that ways 2200 lbs. still very capable of doing so but stopping with that extra weight on a hill was scarry. so some mods added a trany cooler. added the hitch of course and this model does not have a factory wiring for towing so added an aftermarket wire module for trailer lights. now I'm adding the aftermarket Curt brake controller in the center consul ran all the wires from the 7 pin to the cab but the last wire that is eluding me is the brake switch to the controller. there are 4 wires coming out of the switch but none of them react like ford or chevy and turn on the checker light when the pedal is pushed.
    so can anyone tell me which wire I need to run to the red wire on the brake controller I have never had this much problem installing a brake controller on any other vehicle before
  2. Jan 24, 2024 at 2:51 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I’ll see if I can locate the wire
    I used a RedArc Liberty controller…….its a plug and play for the tacoma
  3. Jan 24, 2024 at 10:48 AM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    I believe the OP is saying he does not have any functions/features of the "Toyota Towing Package" as his truck is a low trim level. He has added items and is stuck on the last one - the Brake function to drive his Brake Controller.
    OP here is a schematic of what Toyota does:
    It seems you already have wired in the 7-wire trailer plug (T12) and now need to emulate the Trailer Brake Control connector (T7).
  4. Oct 12, 2024 at 9:33 AM
    ryoerger
    ryoerger New Member
    Rick
    Tacoma 2021 4-Wheel Drive
    I've downloaded the schematic you posted, and I am trying to figure out what to do next. Can someone help?
  5. Oct 12, 2024 at 4:39 PM
    Toycoma2021
    Don't know about help:
    What have you done with the RED wire on the Brake controller and what is its function? A schematic of the controller would help. What is a "checker light"?
    "there are 4 wires coming out of the switch but none of them react like ford or chevy and turn on the checker light when the pedal is pushed.
    so can anyone tell me which wire I need to run to the red wire on the brake controller I have never had this much problem installing a brake controller on any other vehicle before."
