Can't find zerk fittings on drive shaft
Discussion in '3rd Gen. Tacomas (2016-2023)' started by soggyBottom, Jan 13, 2022.
  1. Jan 13, 2022 at 12:41 PM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    I have a 2018 Tacoma. I've seen zerk fittings to grease the drive shaft on other (older) Tacoma's but I don't see any on mine. I've spun and spun the drive shaft but I don't see any.
    What am I missing? Aren't there supposed to be 5?
  2. Jan 13, 2022 at 12:50 PM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Dont remember the time frame, but I believe that in late 2017 or 2018 they moved to sealed joints/non greaseable. If anything you'd only have the 2 zerks on the front of the shaft, but I've seen posts of 2020's and newer having zero zerks. (This may be wrong info, or only partly correct, but there are definitely threads here talking about it in the 3rd gen section)
    gudujarlson and eurowner like this.
  3. Jan 13, 2022 at 12:51 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Front drive shift only, by front diff. My 18 sport only has one zerk.
  4. Jan 13, 2022 at 12:53 PM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    No more zerks
  5. Jan 13, 2022 at 1:20 PM
    soggyBottom
    I found 2 on the front but none on the rear.
  6. Jan 13, 2022 at 1:21 PM
    TacoMike
    TacoMike Well-Known Member
    Pennsylvania
    '19 SR AC Utility 4x4
    This ^
    818_Taco_4x4 likes this.
  7. Jan 13, 2022 at 1:28 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    2 on the front and none on the rear on my 2017.
    shakerhood likes this.
  8. Jan 13, 2022 at 1:37 PM
    Gord0
    Gord0 Well-Known Member
    You have to use Bluetooth, get with the times…!
    tacovagon likes this.
  9. Jan 13, 2022 at 1:52 PM
    Clearwater Bill
    Billy
    Largo Florida
    Park of the no dipstick/lifetime fluids package. :D
  10. Jan 13, 2022 at 2:54 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Rear zerks went away June/July of 2016.
  11. Jan 13, 2022 at 2:57 PM
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    I have none on my 20
  12. Jan 13, 2022 at 3:07 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Ah yes wireless lubricants, Nickel Anti-seize actually developed that technology years ago it's the only logical explanation for how you cannot even touch the stuff and still get it all over you. Hell opening a new can by yourself is rolling the dice on a 50/50 of becoming the next silver surfer!
  13. Jan 13, 2022 at 3:14 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  14. Jan 13, 2022 at 3:36 PM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Just like draining coolant or oil then doing something else up top guarantees it'll end up in the pan or bucket. It could be across the room and that bolt you drop will make it in somehow.
    shakerhood and Key-Rei[QUOTED] like this.
  15. Jan 13, 2022 at 6:36 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I was trying to remove the battery from my calculator so l could get the number, somehow it shot out bounced off the end table and straight down the HVAC Grate.
    hiPSI likes this.
