Can't fit enough lube in rear end
Discussion in '1st Gen. Tacomas (1995-2004)' started by dankgus, Jul 16, 2023.
  1. Jul 16, 2023 at 2:57 PM
    dankgus
    dankgus [OP] Well-Known Member
    Dan
    2002 3.4l Tacoma
    We just replaced the diff on a 2002 Tacoma (4wd with elocker).
    Everything I read says 3.1qts of oil in the rear end, with the non e-locker being 2.7qts.
    The thing is, I can't fit more than about 2.5 qts in before it reaches the absolute max. I can look in with a flashlight and see the level is even with the bottom of the fill plug. Add any more and it starts overflowing.
    The videos I see just show a guy filling it and saying "there you go, all done!".
    The truck isn't *exactly* level, but fairly close I'd say. We took it around the block just now for the first time in months, I'll check the level after I eat lunch.
    Any thoughts?
  2. Jul 16, 2023 at 2:58 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Send it. If you fill it til it's coming out the fill hole it's as full as it's gonna get.
    vern650, Area51Runner and Digiratus like this.
  3. Jul 16, 2023 at 2:59 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    It's full if it's to the bottom of the fill plug. Don't overthink it.
    Area51Runner, wilcam47 and Wulf like this.
  4. Jul 16, 2023 at 3:01 PM
    dankgus
    Dan
    2002 3.4l Tacoma
    True, which is why I'm not too concerned.
    BUT.. What about after a few drives and the oil disperses more into the axle tubes from sloshing around? Refill to full if the level checks lower?
    wilcam47 and Mikeh80 like this.
  5. Jul 16, 2023 at 3:03 PM
    Wulf
    rock raisin
    Checking it again after a test drive is a good idea but I doubt the level will show much lower if at all. The axle tubes may hold a few oz at best
    I think the capacity in the manual is wrong or was taken with the pinion angle set at 0 rather than with the pinion angle the axle is installed with under a stock truck.
  6. Jul 16, 2023 at 3:06 PM
    dankgus
    Dan
    2002 3.4l Tacoma
    Yeah, it's hard to envision exactly what might rest in the tubes, when the diff is full of oil. When we had the axles out I looked inside the tubes with a flashlight and it looked like there were ridges in the tube, maybe even to discourage oil from flowing to each end. Idk.
  7. Jul 17, 2023 at 7:56 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Remember, when you drain it, you don't get all the oil out... you get most of it out. A little more than half a quart is still in there - coating every surface, trapped in small pockets between gears, etc. So, when you put new oil in, you can only fit (apparently) 2.5qts. You'll find the same to be true with all fluids - the capacity in the manual is from "dry" when the truck is built at the factory.
    Get it to the fill hole and you're good to go! :thumbsup:
    Area51Runner and Superdave1.0 like this.
  8. Jul 17, 2023 at 8:08 AM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    The title is amazing! :rofl::anonymous:
    Laxtoy, DK117, amyracecar and 9 others like this.
  9. Jul 17, 2023 at 11:13 AM
    dankgus
    Dan
    2002 3.4l Tacoma
    When doing rear end work, lube is very important!
  10. Jul 17, 2023 at 11:15 AM
    dankgus
    Dan
    2002 3.4l Tacoma
    That's the thing, we replaced the diff and cleaned out the housing. There was zero lube in before the fill. I think one of the other responses may be on to something - the angle of the rear end. The truck is lifted a bit so naturally the angle of the rear end is altered.
    Whatever the reason, I checked the level yesterday after a test drive and was able to put a smidge more lube in. Full is full, I'm okay with it.
  11. Jul 17, 2023 at 11:19 AM
    svendough
    svendough Well-Known Member
    Colorado
    2020 Cement DCSB OR
    Skinny rubber, Bilstein lift, iKamper
    That's what she said.
  12. Jul 17, 2023 at 11:35 AM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Absolutely!!
    amyracecar likes this.
  13. Jul 17, 2023 at 12:14 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    As long as the oil spills out of the fill hole you're good to go.
    Unless you're using angle shims, the angle of the 3rd member doesn't not change when you lift the truck - drive line angle, sure, but the axle housing does not. Angle shims are usually in the 2 or 3 degree range. Not really going to make a massive difference in the amount of gear oil you can get in there.
  14. Jul 17, 2023 at 12:39 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Saw title, clicked, disappointed
    :pout:
    Laxtoy, Kevins60, amyracecar and 3 others like this.
  15. Jul 17, 2023 at 4:02 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Yeah, like he said , make sure the vents clean otherwise your new oil will be running out the drums....
  16. Jul 17, 2023 at 4:27 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    QFT ... content does not disappoint either.
    unsub'd
  17. Jul 17, 2023 at 5:07 PM
    Rachelsdaddy
    Southern NH
    I was gonna say "try harder" lol
    wilcam47 and MQQSE[QUOTED] like this.
  18. Jul 17, 2023 at 5:07 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    :fistbump: :laugh:
    svendough and wilcam47 like this.
  19. Jul 18, 2023 at 12:32 PM
    amyracecar
    amyracecar suck it up buttercup
    Virginia Applejack
    SouthEast USA
    2013 AC V6 MT OR Spruce/Mica
    This thread is GREAT!
    From the title
    To all the responses tryin to be serious and help
    But MOSTLY to all the jokes about the thread name!!
    wilcam47 likes this.
  20. Jul 18, 2023 at 4:25 PM
    Tacomahound555
    Tacomahound555 Well-Known Member
    Will someone give this man a hand?
