Cant get a firm pedal after bleeding brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mnudo200827, Sep 18, 2010.
  1. Sep 18, 2010 at 10:00 PM
    JAG
    JAG Well-Known Member
    Glad you got it fixed!
  2. Sep 19, 2010 at 4:29 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    "they were holding down pedal cause they were telling me they were" What does that mean ?
  3. Sep 19, 2010 at 5:39 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2
    My husband and I work together on this. When he's ready, he'll say *DOWN* and I'll push my foot down on the brake till it hits the floor and say *DOWN* and leave my foot there. He'll open up the bleeder and let it flow. He'll close the bleeder and say *UP* and I know to let my foot off the brake and I'll say *UP*. We'll repeat this process several times for each wheel.
    I can tell by the 'pedal feel' that he's getting the air bubbles out just by how firm the pedal feels during the bleeding process.
  4. Sep 19, 2010 at 5:43 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    I gave up on the two-people approach and got a vacuume bleeder...very simple and faster than pumping the pedal.
  5. Sep 30, 2010 at 6:45 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    Something is still messed up with my brakes. I installed front brake lines and bled the shit out of them doing it in the proper fashion you all describe. It got better but only to a point. Just the other day I bought a vacuum bleeder and now my brakes feel worse.
    There's something strange though because when I pump up the vacuum everything is good. Than as soon as I crack open the bleeder I get more air than I do oil. Thing is I've bled a shit ton of oil through each bleeder and the result is the same. It's like air leaks into the bleeder when I open it. Maybe I need to put some grease around the bleeder to make a better seal.
    ideas?
  6. Sep 30, 2010 at 9:50 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I just replaced my rear brake lines and bled them. I was very careful because the Haynes/Chiltons manual says something roughly like this:
    "If you get air into the master cylinder, the car will need to be towed to the dealer to have the master cylinder bled with special equipment."
    How much fluid drained out of the rear brake lines while you had them off for replacement? Could air have escaped all the way to the master cylinder? As soon as I disconnected mine, I clamped off the old lines with a vice grip to seal it while I attached the new line to the "brake" end, and then took off the clamped line at the "master cylinder" end only when I was immediately ready to thread on the new line that was already threaded on to the "brake" end.
    I didn't say that very well but the point is that I made sure the line to the master cylinder was open to the air for a very short period of time to minimize the amount of fluid escaping and air sneaking in.
  7. Sep 30, 2010 at 9:52 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    As I read your post again, I also wonder if you've simply got a leak in the line??
  8. Sep 30, 2010 at 11:06 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    I doubt it because I've been driving it this way for a month now and other than a spongy brake pedal everything seems to remain constant. Haven't needed to add oil nor has the problem gotten worse just by driving. I think the master cylinder must have air in it. Is there no way to bleed the air out of the master cylinder using normal garage tools?
    I think I'll just take it to toyota and pay their F'ing $100 to flush the brake lines. That's bull! One day they'll make cars that the owner can't even change his own oil I bet. Anything to make a buck.
  9. Oct 1, 2010 at 10:37 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
  10. Oct 1, 2010 at 10:50 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    you start from the r/r to bleed the brakes then go to the l/r
    then the r/f then l/f
    G.T. and DirtyArmor like this.
  11. Oct 1, 2010 at 7:46 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Yup, been there, done that. Same result :(
  12. Oct 1, 2010 at 7:46 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
  13. Oct 1, 2010 at 7:58 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    I've dealt with bleeding brakes alot. Everyone's suggestions on here are exacly right.
    To bleed the master cylinder all you need to do is follow the same process as when you bleed the brake calipers. Have someone press the brake pedal and then crack open the lines at the master cylinder until the fluid shoots out solid with no bubbling. Do one line at a time, one line is for the front brakes, the other is for the rear brakes.
    Also, after you get the bleeding part done, I would go find a dirt lot or road and do some ABS stops and get your ABS pump to activate, this can help firm up the pedal.
  14. Oct 1, 2010 at 8:13 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Question
    1) When you say bleed the lines coming from the master cylinder, you mean just loosen the line until solid oil squirts out the threads? I mean its not really a bleeder valve in the true sense, correct?
    2) What do you recommend more, a vaccum gun, or the old method (brake pedal pumping). Everyone told me this vacuum tool was the thing to use if you wanted to spend some money. However, these dam bleeders are sucking air around the threads.
  15. Oct 2, 2010 at 8:28 AM
    #35
    NelsonTacoma
    Tucson, AZ
    1) Just loosen the line like a 1/4 turn while someone presses and holds the brake pedal down, when the fluid comes out in a solid stream it's good to go. Just like a regular bleeder valve. No it is not a regular bleeder valve, but this is how you bleed a master cylinder. I do this all the time at work (I'm ASE certified in Braking systems).
    2) I personally like the old fashioned way with 2 people. It's never failed me before. It's how I do it at work. The vacuum bleeders do work, but you have to be patient with them.
    REDdawn6 likes this.
