Can't get above 2500 rpm...Solved!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by bandersnatch, Oct 6, 2023.
  1. Oct 6, 2023 at 3:55 PM
    bandersnatch
    bandersnatch [OP] Active Member
    Ross
    1999 Tacoma TRD
    Recently purchased a 1999 Tacoma TRD 2wd 5vz. 220k miles
    It drives around town great, on the interstate it is great. But, I have no passing power and I lose speed on steep inclines. Can't seem to get above 2500 rpm. No CEL or codes
    What I have done over the past 2 weeks:
    New spark plugs (NKG)
    New vacuum lines (not all, but a lot)
    New fuel filter
    New catalytic converter
    New thermostat (old one was stuck open)
    Oil change
    Drive shaft center bearing
    Thoughts on the lack of power?
    Solution: The timing belt had jumped a few teeth. New water pump and timing belt with proper timing.
  2. Oct 6, 2023 at 4:11 PM
    Bishop84
    Bishop84 Well-Known Member
    Unfortunately its a pain to diagnose.
    You need to check fuel pressure, which is difficult because it needs to be a threaded fuel line style. (cant suggest any off the top of my head)
    Next the MAF is a suspect for sure, you typically measure the current or watch the current on a scan tool.
    Last a vacuum check is a good idea to eliminate anything in the exhaust. (new doesnt mean good)
    https://www.youtube.com/watch?v=d-jp1IIJVVk
  3. Oct 6, 2023 at 5:44 PM
    Clucky
    Clucky Well-Known Member
    W
    WC to EC back to WC
    00 SR5 Stock 5 Speed
    & 12 TRD Stock 6 Speed
    Can you rev it above 2500 in neutral? If so, I'd consider compression check.
    treyus30 likes this.
  4. Oct 6, 2023 at 8:44 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Pull the battery terminal for 10s and observe changes
  5. Oct 6, 2023 at 8:48 PM
    1997tacomav6
    Denver
    If you can't rev pass 2500 in Neutral it could be cam or crankshaft sensors
  6. Oct 7, 2023 at 4:30 PM
    bandersnatch
    Ross
    1999 Tacoma TRD
    Today I checked the MAF sensor and cleaned it. It appears to be ok.
    I will check compression, vacuum, and fuel pressure this weekend when I can get out to my BIL's house (mechanic).
    Will follow up with results.
    Thanks for all the suggestions
    RustyGreen likes this.
  7. Oct 9, 2023 at 2:17 PM
    bandersnatch
    Ross
    1999 Tacoma TRD
    Today I circled back around to the MAF. I pulled it all the way out and gave it a full cleaning with MAF cleaner. After cleaning, I am still averaging 6.5-7 g/sec at idle. I believe that I should be around 3.4-4 g/sec.
    Also, I am able to get up to 4000rpm when I turn off O/D.
    With O/D on i can hit 2600 rpm with a MAF of 55 g/sec
    With O/D off at 4000 rpm the MAF is about 70 g/sec
    I am questioning my MAF sensor now...Thoughts?
  8. Oct 9, 2023 at 3:33 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Man, I hate just tossing parts at an issue
    bench test the MAF
    I found lots of videos out there
    One might be your taco specific
  9. Oct 9, 2023 at 6:43 PM
    gumbo-taco
    gumbo-taco Well-Known Member
    NC
    2004 DC Offroad
    ^I’ll second this. Similar issues a while back. Fine around town but zero power/revs only 2500-2800 for highway speed. Did the MAF route, etc. changed the crank position sensor. Boom-night and day.
    1997tacomav6[QUOTED] likes this.
  10. Oct 10, 2023 at 2:38 AM
    bandersnatch
    Ross
    1999 Tacoma TRD
    Did this happen without getting a CEL?
  11. Oct 11, 2023 at 12:17 PM
    gumbo-taco
    NC
    2004 DC Offroad
    Yes - no CEL. Just no power above 2500-2800. Now revs freely and can actually achieve highway speed if needed.
  12. Oct 11, 2023 at 1:26 PM
    bandersnatch
    Ross
    1999 Tacoma TRD
    Thanks for the info. Ordered a new cam sensor and crank sensor.
    Will report back after install.
  13. Oct 12, 2023 at 8:01 PM
    gumbo-taco
    NC
    2004 DC Offroad
    Best of luck
  14. Oct 13, 2023 at 3:29 PM
    ControlCar
    Steven
    Sugar Land TX
    Very interested in result
    GL!
  15. Oct 14, 2023 at 9:57 AM
    bandersnatch
    Ross
    1999 Tacoma TRD
    Success! Can't say if it was the cam sensor or the crank sensor, but I now have full power back.
    The downside, I now have a P0505 code Idle Control System Malfunction. Suggestions?
    1997tacomav6 and RustyGreen like this.
  16. Oct 14, 2023 at 10:23 AM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
  17. Oct 14, 2023 at 2:44 PM
    1997tacomav6
    Denver
    If it was working before maybe just a vacuum leak
  18. Oct 14, 2023 at 4:17 PM
    bandersnatch
    Ross
    1999 Tacoma TRD
    Pulled the throttle body and did a deep clean on it and the IAC. Reset the ecu and went for a 30 min drive. No Codes :)
    Will follow up in a few days, but it seems that things are good.
    m3bassman and RustyGreen like this.
  19. Nov 5, 2023 at 2:21 PM
    bandersnatch
    Ross
    1999 Tacoma TRD
    Ok, while the cam and crank sensor made a noticeable improvement, It turns out that my timing belt had slipped a few teeth.
    Just finished water pump and timing belt, and with proper timing, the truck drives amazingly!
    Like moving from a 4cyl to a 6cyl.
    Thanks for all your help!
    leid and gumbo-taco like this.
