Can't get correct amount of diff fluid in rear diff.
Discussion in '1st Gen. Tacomas (1995-2004)' started by chvymechanic, Jun 20, 2014.
  1. Jun 20, 2014 at 3:31 PM
    chvymechanic
    chvymechanic [OP] Well-Known Member
    Thomas
    New Hampshire
    04 Limited TRD Off Road 4x4 Xtra Cab
    Stuff and Thangs
    I'm in the process of changing my rear differential fluid I have the old fluid drained out, and am now filling it up with new fluid the factory service manual says 2.8 quarts for short model or 3.18 quarts for extra long model with rear locker. I have an extra cab TRD with locker and I can only get about 2.5 quarts in.
    Any and all input on why this is would be greatly appreciated. Thanks
  2. Jun 20, 2014 at 3:36 PM
    82 yotaman
    82 yotaman H.O.G Hunter Of Gunman
    BUBBA
    Northern colorado
    1982 toyta pickup/2013 toy MGM dcab 4x4 trd
    avs bugshield, avs inchannel vent visors, weather techs, trd shift knob, tailgate theft mod, windows tinted to 20%, wet okole front and back and black level 8 guardians wrapped in 265/75/R16 Duratracs oil catch can mod interior LED's, pop & lock pl5500, Leer 180 topper, OME full lift with Arb bullbar
    Fill till oil is coming out of fill hole, drive it around the block a few times check oil level if good you're done.
  3. Jun 20, 2014 at 3:37 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    and if it ain't good, put in somemore. :)
  4. Jun 20, 2014 at 3:38 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2. After a little ride you will probably have to add a little more then call it good.
  5. Jun 20, 2014 at 3:40 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Fill axle with oil until it starts to come out the fill hole. Replace fill plug. Wait five minutes and add some more if needed.
  6. Jun 20, 2014 at 4:32 PM
    chvymechanic
    Thomas
    New Hampshire
    Stuff and Thangs
    Thanks for the speedy replies!! Should I be at all worried if even after the steps mentioned above I dont have the specified amount according to the FSM?
    Thanks
  7. Jun 20, 2014 at 4:47 PM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    TRD Off Road
    N-Fab tubular steps. Excalibur AL2050-EDPB security system. LT265/75R/16E1 123Q B Goodyear Duratrac's.
    As long as it's trickling out of the fill hole you're good...
  8. Jun 20, 2014 at 4:47 PM
    tbturner47
    tbturner47 Well-Known Member
    Travis
    Lenoir, NC
    '07 Indigo Ink Off Road
    Supercharger
    As long as its full I dont see a problem. When you drained the oil did everything look ok? Have you noticed any issues from your rear axle?
    I wouldn't sweat it
  9. Jun 20, 2014 at 4:52 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    Full it until it dribbles out, let is get into the axle tubes, and top it up. If it's dribbling out of the fill plug when on a level surfce you're good to go
  10. Jun 20, 2014 at 5:37 PM
    chvymechanic
    Thomas
    New Hampshire
    Stuff and Thangs
    No problems with rear axle at all, old fluid looked good but of course I wasn't smart enough to measure it before dumping it into the rest of the used oils. Its full right now I'll drive it a bit and then top it off in the morning. Thanks for all the input. I have a bit of a problem over-thinking things.
    Thanks again for all the input!
  11. Jun 20, 2014 at 5:48 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    You're a Chevy Mechanic?
  12. Jun 20, 2014 at 6:56 PM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    Well, somebody had to ask! :facepalm:
  13. Jun 20, 2014 at 7:12 PM
    tomtom
    The Desert SW
    2012 FJ
    You should not be worried.
  14. Jun 20, 2014 at 7:27 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    The amounts given in the owners manual and fsm are the same called out in the Chiltons manual. They say the capacities called out are "approximate" and to add as necessary to bring to appropriate level which they say to be at the bottom of the plug opening. The Toyota Factory Service Manual says to add as nessesary to get the level within 5mm (0 to 0.20 in.) of the bottom of the filler plug opening.
  15. Jun 20, 2014 at 11:51 PM
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    I found the problem :D
  16. Jun 21, 2014 at 5:57 AM
    chvymechanic
    Thomas
    New Hampshire
    Stuff and Thangs
    Haha, no I used to be, also used to be a Chevy truck fan then wised up and got my first Toyota in 2009, now I have 3. Thanks again for all the advise.
  17. Jun 21, 2014 at 6:30 AM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    If when you drained the old, if the axle was not level, some of the oil was down in the lower of the two axle tubes.
  18. Jul 9, 2014 at 3:14 PM
    jackbower6864
    jackbower6864 Member
